jeremy
Attached are the EAC reports from the normal CD version, and the Blu-spec version CD.
Obviously, they do sound different, or Sony would not have gone to all the trouble to include both discs of the same content.
Normal CD version.
Exact Audio Copy V0.99 prebeta 4 from 23. January 2008
EAC extraction logfile from 12. March 2009, 10:19
Unknown Artist / Unknown Title
Used drive : HL-DT-STBD-RE GGW-H20L Adapter: 6 ID: 0
Read mode : Secure
Utilize accurate stream : Yes
Defeat audio cache : Yes
Make use of C2 pointers : No
Read offset correction : 667
Overread into Lead-In and Lead-Out : No
Fill up missing offset samples with silence : Yes
Delete leading and trailing silent blocks : No
Null samples used in CRC calculations : No
Used interface : Native Win32 interface for Win NT & 2000
Gap handling : Not detected, thus appended to previous track
Used output format : Internal WAV Routines
Sample format : 44.100 Hz; 16 Bit; Stereo
TOC of the extracted CD
Track | Start | Length | Start sector | End sector
1 | 0:00.00 | 6:11.52 | 0 | 27876
2 | 6:11.52 | 2:34.00 | 27877 | 39426
3 | 8:45.52 | 4:21.01 | 39427 | 59002
4 | 13:06.53 | 4:09.64 | 59003 | 77741
5 | 17:16.42 | 5:55.16 | 77742 | 104382
6 | 23:11.58 | 3:07.39 | 104383 | 118446
7 | 26:19.22 | 3:52.48 | 118447 | 135894
8 | 30:11.70 | 4:15.24 | 135895 | 155043
9 | 34:27.19 | 4:49.02 | 155044 | 176720
10 | 39:16.21 | 3:28.69 | 176721 | 192389
11 | 42:45.15 | 3:51.63 | 192390 | 209777
12 | 46:37.03 | 3:42.41 | 209778 | 226468
13 | 50:19.44 | 4:51.74 | 226469 | 248367
14 | 55:11.43 | 3:52.39 | 248368 | 265806
15 | 59:04.07 | 3:22.26 | 265807 | 280982
16 | 62:26.33 | 4:58.56 | 280983 | 303388
17 | 67:25.14 | 4:00.19 | 303389 | 321407
Track 1
Filename G:\AUDIO\Blu-spec CD-Rock CD version LG BD\Track01.wav
Peak level 93.2 %
Track quality 100.0 %
Test CRC 281CA5AC
Copy CRC 281CA5AC
Track not present in AccurateRip database
Copy OK
Track 2
Filename G:\AUDIO\Blu-spec CD-Rock CD version LG BD\Track02.wav
Peak level 100.0 %
Test CRC FE9FEF1C
Copy CRC FE9FEF1C
Copy OK
Track 3
Filename G:\AUDIO\Blu-spec CD-Rock CD version LG BD\Track03.wav
Peak level 82.7 %
Track quality 99.9 %
Test CRC 300F054F
Copy CRC 300F054F
Copy OK
Track 4
Filename G:\AUDIO\Blu-spec CD-Rock CD version LG BD\Track04.wav
Peak level 96.5 %
Test CRC 988D97E8
Copy CRC 988D97E8
Copy OK
Track 5
Filename G:\AUDIO\Blu-spec CD-Rock CD version LG BD\Track05.wav
Peak level 100.0 %
Test CRC 17369A9A
Copy CRC 17369A9A
Copy OK
Track 6
Filename G:\AUDIO\Blu-spec CD-Rock CD version LG BD\Track06.wav
Peak level 94.2 %
Test CRC 6635DEE2
Copy CRC 6635DEE2
Copy OK
Track 7
Filename G:\AUDIO\Blu-spec CD-Rock CD version LG BD\Track07.wav
Peak level 97.9 %
Test CRC 2A4533E4
Copy CRC 2A4533E4
Copy OK
Track 8
Filename G:\AUDIO\Blu-spec CD-Rock CD version LG BD\Track08.wav
Peak level 77.2 %
Test CRC C2133030
Copy CRC C2133030
Copy OK
Track 9
Filename G:\AUDIO\Blu-spec CD-Rock CD version LG BD\Track09.wav
Peak level 85.2 %
Test CRC B2A76E79
Copy CRC B2A76E79
Copy OK
Track 10
Filename G:\AUDIO\Blu-spec CD-Rock CD version LG BD\Track10.wav
Peak level 83.1 %
Test CRC 79E62B53
Copy CRC 79E62B53
Copy OK
Track 11
Filename G:\AUDIO\Blu-spec CD-Rock CD version LG BD\Track11.wav
Peak level 99.9 %
Test CRC CCB049B8
Copy CRC CCB049B8
Copy OK
Track 12
Filename G:\AUDIO\Blu-spec CD-Rock CD version LG BD\Track12.wav
Peak level 100.0 %
Test CRC 874F6163
Copy CRC 874F6163
Copy OK
Track 13
Filename G:\AUDIO\Blu-spec CD-Rock CD version LG BD\Track13.wav
Peak level 100.0 %
Test CRC 2CFB1E10
Copy CRC 2CFB1E10
Copy OK
Track 14
Filename G:\AUDIO\Blu-spec CD-Rock CD version LG BD\Track14.wav
Peak level 85.0 %
Test CRC 0AAC9AC1
Copy CRC 0AAC9AC1
Copy OK
Track 15
Filename G:\AUDIO\Blu-spec CD-Rock CD version LG BD\Track15.wav
Peak level 100.0 %
Test CRC 3F6A9DFC
Copy CRC 3F6A9DFC
Copy OK
Track 16
Filename G:\AUDIO\Blu-spec CD-Rock CD version LG BD\Track16.wav
Peak level 96.5 %
Test CRC E520840C
Copy CRC E520840C
Copy OK
Track 17
Filename G:\AUDIO\Blu-spec CD-Rock CD version LG BD\Track17.wav
Peak level 94.3 %
Test CRC 35179C47
Copy CRC 35179C47
Copy OK
None of the tracks are present in the AccurateRip database
No errors occurred
End of status report
Blu-spec version.
EAC extraction logfile from 10. March 2009, 22:17
Read mode : Secure
Track 1
Filename G:\AUDIO\Blu-Spec CD-Rock (BD version)\Track01.wav
Peak level 93.2 %
Test CRC 281CA5AC
Copy CRC 281CA5AC
Copy OK
Track 2
Filename G:\AUDIO\Blu-Spec CD-Rock (BD version)\Track02.wav
Peak level 100.0 %
Test CRC FE9FEF1C
Copy CRC FE9FEF1C
Copy OK
Track 3
Filename G:\AUDIO\Blu-Spec CD-Rock (BD version)\Track03.wav
Peak level 82.7 %
Test CRC 300F054F
Copy CRC 300F054F
Copy OK
Track 4
Filename G:\AUDIO\Blu-Spec CD-Rock (BD version)\Track04.wav
Peak level 96.5 %
Test CRC 988D97E8
Copy CRC 988D97E8
Copy OK
Track 5
Filename G:\AUDIO\Blu-Spec CD-Rock (BD version)\Track05.wav
Peak level 100.0 %
Test CRC 17369A9A
Copy CRC 17369A9A
Copy OK
Track 6
Filename G:\AUDIO\Blu-Spec CD-Rock (BD version)\Track06.wav
Peak level 94.2 %
Test CRC 6635DEE2
Copy CRC 6635DEE2
Copy OK
Track 7
Filename G:\AUDIO\Blu-Spec CD-Rock (BD version)\Track07.wav
Peak level 97.9 %
Test CRC 2A4533E4
Copy CRC 2A4533E4
Copy OK
Track 8
Filename G:\AUDIO\Blu-Spec CD-Rock (BD version)\Track08.wav
Peak level 77.2 %
Test CRC C2133030
Copy CRC C2133030
Copy OK
Track 9
Filename G:\AUDIO\Blu-Spec CD-Rock (BD version)\Track09.wav
Peak level 85.2 %
Test CRC B2A76E79
Copy CRC B2A76E79
Copy OK
Track 10
Filename G:\AUDIO\Blu-Spec CD-Rock (BD version)\Track10.wav
Peak level 83.1 %
Test CRC 79E62B53
Copy CRC 79E62B53
Copy OK
Track 11
Filename G:\AUDIO\Blu-Spec CD-Rock (BD version)\Track11.wav
Peak level 99.9 %
Test CRC CCB049B8
Copy CRC CCB049B8
Copy OK
Track 12
Filename G:\AUDIO\Blu-Spec CD-Rock (BD version)\Track12.wav
Peak level 100.0 %
Test CRC 874F6163
Copy CRC 874F6163
Copy OK
Track 13
Filename G:\AUDIO\Blu-Spec CD-Rock (BD version)\Track13.wav
Peak level 100.0 %
Test CRC 2CFB1E10
Copy CRC 2CFB1E10
Copy OK
Track 14
Filename G:\AUDIO\Blu-Spec CD-Rock (BD version)\Track14.wav
Peak level 85.0 %
Test CRC 0AAC9AC1
Copy CRC 0AAC9AC1
Copy OK
Track 15
Filename G:\AUDIO\Blu-Spec CD-Rock (BD version)\Track15.wav
Peak level 100.0 %
Test CRC 3F6A9DFC
Copy CRC 3F6A9DFC
Copy OK
Track 16
Filename G:\AUDIO\Blu-Spec CD-Rock (BD version)\Track16.wav
Peak level 96.5 %
Test CRC E520840C
Copy CRC E520840C
Copy OK
Track 17
Filename G:\AUDIO\Blu-Spec CD-Rock (BD version)\Track17.wav
Peak level 94.3 %
Test CRC 35179C47
Copy CRC 35179C47
Copy OK
No errors occurred
