Post by gommer on Feb 14, 2013 12:46:15 GMT
Hi Jon,
The package arrived today. Who says surface mail is slow? Nice looking PCB's, tinier then i expected, they should fit almost everywhere.
Thanks again.
Cheers, Marc
Post by Deleted on Feb 14, 2013 12:57:18 GMT
Hi Jon, The package arrived today. Who says surface mail is slow? Nice looking PCB's, tinier then i expected, they should fit almost everywhere. Thanks again. Cheers, Marc Hi Marc For even tighter spaces, you can cut them down the centre ( carefully!) and stack one on top of the other. Don't forget to use a J506 FET instead of the 10K resistor for operation at +5V or +3.3V You could also use a selected N-FET such as the 2N5484 with a current of around 1.5mA when G and S are tied, (e.g. test with something like +15V and a 100 ohm drain resistor) or trim the current to 1.5mA approx.with a resistor in series with the Source lead. Kind Regards Alex
Post by hirez69 on Feb 14, 2013 19:32:34 GMT
Hi Jon & Alex PM sent yesterday and today Many thanks hirez69 IIRC, still to hear from: steveecrane....04 PinkFloyd.......04 hirez69...........06 Listener..........04 etoiledusoir.....02 Telstar............02 Porfido.........04 Seavan..........06
pingu
Post by pingu on Feb 16, 2013 0:54:02 GMT
Hi Jon, Boards arrived Tuesday but have been away untill tonight. All unpacked and safe thanks. Bartin
pingu
Post by pingu on Feb 16, 2013 22:44:57 GMT
Hi All, Maybe this is one for Alex. Pls excuse me if this is a no brainer I am only a keen beginner. I am just ordering the bits for a few of the boards, to make them "generic" to fit a couple of psu's I intended to make the 500/550ma version using a large wattage resist (or may lower wattage paralleled) for R12/112. Will the listed transistors be OK, especially the 2sc5171 and 2sc1930 used for Q6 & Q106 and the listed diodes (1N4148's)? They will be used on cpu's from 12v to 20volt +/- Any help advice greatly appreciated Martin
Post by Deleted on Feb 16, 2013 23:15:56 GMT
Hi All, Maybe this is one for Alex. Pls excuse me if this is a no brainer I am only a keen beginner. I am just ordering the bits for a few of the boards, to make them "generic" to fit a couple of psu's I intended to make the 500/550ma version using a large wattage resist (or may lower wattage paralleled) for R12/112. Will the listed transistors be OK, especially the 2sc5171 and 2sc1930 used for Q6 & Q106 and the listed diodes (1N4148's)? They will be used on cpu's from 12v to 20volt +/- Any help advice greatly appreciated Martin A .5W or 1W resistor is all that is needed there. Don't forget that there will be several hundred mV drop through the JLH when the current limiter is used. If you are using voltage regulators such as the LM78xx/LM79xx or the LM317T/LM337T ahead of it, then best results will be obtained with the Current Limiter section bypassed. The original CL circuit can be quite touchy to get right at more than the originally published 100mA maximum limit. With the CL bypassed, provided that a small heatsink is fitted to the 2sa/2sc device with the 33 ohm emitter resistor, it can even handle 2A at +12V. Do NOT use it with aPC's SMPS unless you protect the JLH at start up using something like a relay and PW5 resistor as posted in another thread. Regards Alex
pingu
Post by pingu on Feb 17, 2013 1:24:31 GMT
Thanks Alex, I understand and yes as they will be used with regulated psu's as you mention so I will just bypass the limiters, seems the easiest way to do things. Just a couple of HA's and a phono so 550ma will be the max I think I will need so a simple approach sounds good. Passed a couple of boards on to son in law so will let him see your comments too.
I see in the article a diode can also be connected across R9... or maybe that is a different approach. Thanks for the advise about PC's I have read that but will not be using them on that type of psu at the moment however will keep it in mind. Thanks Martin
Post by Deleted on Feb 17, 2013 1:37:03 GMT
Thanks Alex, I understand and yes as they will be used with regulated psu's as you mention so I will just bypass the limiters, seems the easiest way to do things. Just a couple of HA's and a phono so 550ma will be the max I think I will need so a simple approach sounds good. Passed a couple of boards on to son in law so will let him see your comments too. I see in the article a diode can also be connected across R9... or maybe that is a different approach. Thanks for the advise about PC's I have read that but will not be using them on that type of psu at the moment however will keep it in mind. Thanks Martin Hi Martin Forget about that diode. There is no provision for it on Greg's latest PCBs anyway. Seeing that you will be bypassing the CL section, I recommend using a 4,700uF 10V low ESR electro and a normal 4,700uF 16V in parallel on both halves of the PCB. Just remember that it takes around 48 hours of use to fully stabilise.If you have a bench PSU you can condition it before using it in your project. Anything from 5V to 15V will do for that. Kind Regards Alex
pingu
Post by pingu on Feb 17, 2013 13:19:16 GMT
Hi Alex, Thanks for the information. I think I'll use your method and bypass the c/l circuit all together, that will save changing Q3 & Q5. Where would the 4,700uF caps go, on the initial input in place of the c/l circuits or elsewhere? (observing polarity of course) Bearing in mind I may be using one board on a 20v psu should I keep one cap to 10v low ESR and up the other to 4,700uF >30v? Thanks for details about burning in I'll hook them up to a +/- 12v 200ma psu for a few days before I use them.
All the Best Martin
Post by 4est on Feb 17, 2013 15:49:51 GMT
Just a quick note to say "thanks" to Jon! Boards arrived yesterday safe and sound.
I appreciate your providing this opportunity to all of us...
Forrest
Post by mkusan on Feb 20, 2013 9:18:44 GMT
My boards arrived as well, thanks Jon. One question, anyone used ripple eater as a psu for a cd clock?
thanks marko
Post by Deleted on Feb 20, 2013 9:39:19 GMT
I haven't used one directly with a CD clock although it should work quite well. I use them preceding a simple zener and opamp PSU as in the attached photo. I also have one preceding a Paul Hynes 3.3V regulator to supply a DIR9001 with squeaky clean power., and others feeding the DAC PCB as in the photo with +5V, and + and - 15V. I also use them in Class A preamps and headphone amplifiers, as well as supplying the fronr end of a 15W/Ch Class A amplifier as in the DIY thread here. Regards Alex URL=http://imageshack.us/photo/my-images/228/scdacs31082012.jpg/] [/URL]
Post by mkusan on Feb 20, 2013 10:50:49 GMT
I was thinking about using either The Flea or ripple eater for the clock. By looking at your pictures I am now tempted to use both Thank you Alex Marko
Post by Deleted on Feb 20, 2013 11:18:53 GMT
I was thinking about using either The Flea or ripple eater for the clock. By looking at your pictures I am now tempted to use both Thank you Alex Marko Marko The attached may be of interest. With my X-DAC V3 I use an external + and -15V PSU with a JLH, and in the X-DAC V3 itself, I use the "Cricket"(single version) to supply a Vanguard .3PPM 24.576MHZ TCXO See the simplofied version of something a bit like a PFM flea that several of us use in conjunction with a JLH rockgrotto.proboards.com/thread/4477/new-hq-diy-dac?page=3#page=4
Post by mkusan on Feb 20, 2013 12:26:11 GMT
Alex, this is certainly of interest. I would just need the TCXO, everything else I have readily available. Low jitter clock with low noise psu for £12.95 sounds good to me.
Thanks again Marko
Post by Deleted on Feb 20, 2013 12:56:30 GMT
Hi Will,
Boards rolled up today.
Many thanks.
Post by Deleted on Feb 20, 2013 13:04:01 GMT
Alex, this is certainly of interest. I would just need the TCXO, everything else I have readily available. Low jitter clock with low noise psu for £12.95 sounds good to me. Thanks again Marko Marko You will see a "Cricket" and .3PPM TCXO fitted inside an X-DAC V3 at the link Regards Alex rockgrotto.proboards.com/thread/8115/extreme-dac-v3-revisited
Post by jonclancy on Feb 21, 2013 15:37:09 GMT
PinkFloyd and hirez69: your boards went in the post this morning.
Post by Deleted on Feb 22, 2013 18:36:01 GMT
Hi All Here is a quick snap of my Greg’s JLH board Build. Without CL and waiting for the C1/101 C2/202 film caps which are on the way by snail mail. Just to point aot that nearly all of the hard work was done long before I had my hands on these boards. So a big thanks again to (in no particular order) Greg, Jon, will and Alex for all of the hard work put into thiese and the mighty single boards. Take care
Post by steveecrane on Feb 26, 2013 21:52:23 GMT
Jon, Just PM'd you with a note and an apology vis-a-vis this: IIRC, still to hear from: steveecrane....04 PinkFloyd.......04 hirez69...........06 Listener..........04 etoiledusoir.....02 Telstar............02 Porfido.........04 Seavan..........06 Will set about paying you tomorrow...
Post by Deleted on Feb 27, 2013 17:17:10 GMT
Hi All Does anyone have a link to the single sided JLH build manual? From memory it gave a nice little explanation of how the circuit works which could be of interest to new builders. Just a thought Take care
Post by Deleted on Feb 27, 2013 18:51:13 GMT
Hi One!
I have the old word file that Dave "canjunkie" originally sent out. I tried pasting up into a skydrive word file but it made a total balls up of it, losing all the diagrams and pictures.
If you know another to create a linkable file I'm all ears!
Aha! sorted.
Making thread in saucerful....
Post by Deleted on Feb 27, 2013 20:28:46 GMT
Hi One! I have the old word file that Dave "canjunkie" originally sent out. I tried pasting up into a skydrive word file but it made a total balls up of it, losing all the diagrams and pictures. If you know another to create a linkable file I'm all ears! Aha! sorted. Making thread in saucerful.... How's it going Two Hi Chris I’ve just found this on the build guide and support thread www.gt6.co.uk/JLHPSRR/John%20Linsley%20Hood%20ripple%20Eater%20-%20Rock%20Grotto%20Charity%20Edition.htmlIt has a really well written overview of the circuit, great build tips and some interesting historical stuff and even though it’s for the RG single board it’s a must read for anyone building for the first time. Great stuff And the support thread is here should anyone wish to have a read through rockgrotto.proboards.com/thread/5645Think I’ll just pop off for some reading edit i found the full manual over on DIYA for the second GB but it's in booble docs so i can't open it. ho hum Thanks again Chris Take care
Post by jonclancy on Feb 28, 2013 10:25:32 GMT
Post by Deleted on Feb 28, 2013 11:13:09 GMT
Hi Jon
Thanks for the above links but unfortunately I’m having problems with the Google docs download.
It keeps asking for a password.
Take care
