Post by aerogater on Feb 3, 2013 4:03:16 GMT
Hi all, I would like to order 10 please.
Aerogater......10
Tally so far;
shaun..........04 themystical...02 DaveK..........04 steveecrane..04 PinkFloyd......04 4est............10 rafalkac........04 juke.............02 cj................04 hirez69........06 Listener..........04 Aerogater........10
TOTAL>>>>>058
Thanks in advance
Pat
Post by Deleted on Feb 3, 2013 4:27:17 GMT
Hi Pat Whereabouts in Sydney are you from ? I am from Ermington close to West Ryde You have piqued my curiosity as to where you are going to use them all. The guys here love seeing photos and details of interesting projects, so please share with us your finished projects. Kind Regards Alex P.S. Aussies get one shoved in an envelope free of charge on request via a PM with mailing details. Most of this lot has gone with Jon back to the U.K. for distribution.Greg Erskine from Sydney designed the dual PCBs and had them manufactured.
Post by aerogater on Feb 3, 2013 5:07:33 GMT
Hi Alex,
I am in Kogarah; I have a number of headphone amp projects (M3, B22, PPAv2, Panda, Twisted pear Ventus, MiniMax, SCHA amp...) waiting to be built. I am just too busy to built them due to work, so you could say that I collect them more than I built them.
I have recently finish modding my Musical Fidelity series over the Christmas/New year holiday.
X-Can V2, X-Can V3, V-Can V1 (Thanks to Mike's kits and my own tweaks, I made a dual to quad op-amp adaptor on Vero board, op-amp rolling in progress..)
V-PSU and V-DAC mods are ongoing among other things...
I will try to put up some pics when I can.
Cheers mate Pat
P.S. Good to hear about the postage, will PM you later.
Post by Will on Feb 3, 2013 8:29:18 GMT
Now you've got my attention! Er, Jeffc, come on down and tell all Cheers, Hi Chris This should help rockgrotto.proboards.com/index.cgi?action=display&board=talk&thread=4179&page=12#106227I've done the exact same thing on the GE PCB I've built for my musicPC. I'm using a lt1084-12 which supplies the motherboard via the JLH, as per normal. When I read Jeff's post I thought 'I'll be nabbing that idea!!' Once things settle a bit, I should be able to build the bits up and prove them As an idea for the future, I'd love to see an version of Greg's JLH as a single, with heavier rail traces for higher current By the way, I've had the pleasure of using a few of the previous version of Greg's dual JLH pcb's, and they are lovely, so would definitely recommend these if you want some.
Post by Deleted on Feb 3, 2013 8:47:53 GMT
Hi Will Due to additional Input and Output terminals available on Greg's latest PCB, you are able to have both In and Out wires on the Input side, without any voltage drops through the 2oz. copper tracks. Also, if you are careful, you will be able to cut this PCB into 2 individual single PCBs. Regarding Jeff's use with a laptop, you could also use the relay and PW5 Current Limiting method that I used for the internal JLH inside my PC ,that supplies my LG BR writer. Regards Alex
Post by gommer on Feb 3, 2013 11:22:42 GMT
I'll join too this time, 4 pieces please:
shaun..........04 themystical..02 DaveK..........04 steveecrane.04 PinkFloyd......04 4est.............10 rafalkac........04 juke..............02 cj..................04 hirez69.........06 Listener........04 Aerogater.....10 gommer........04
TOTAL>>>>>062
Cheers, Marc
Post by jonclancy on Feb 3, 2013 11:25:02 GMT
Good work!! Keep 'em coming.
If you're on another forum and you know of anyone who might need these boards, please point them here.
Ta!
Post by cyteen on Feb 3, 2013 15:10:05 GMT
shaun............04 themystical.....02 DaveK............04 steveecrane....04 PinkFloyd.......04 4est...............10 rafalkac..........04 juke................02 cj...................04 hirez69...........06 Listener..........04 Aerogater.......10 gommer..........04 cyteen............02
TOTAL>>>>>064
Post by etoiledusoir on Feb 3, 2013 17:06:25 GMT
shaun............04 themystical.....02 DaveK............04 steveecrane....04 PinkFloyd.......04 4est...............10 rafalkac..........04 juke................02 cj...................04 hirez69...........06 Listener..........04 Aerogater.......10 gommer..........04 cyteen............02 etoiledusoir....02
TOTAL>>>>>066
Post by Telstar on Feb 3, 2013 18:12:42 GMT
shaun............04 themystical.....02 DaveK............04 steveecrane....04 PinkFloyd.......04 4est...............10 rafalkac..........04 juke................02 cj...................04 hirez69...........06 Listener..........04 Aerogater.......10 gommer..........04 cyteen............02 etoiledusoir.....02 Telstar............02
TOTAL>>>>>068
Post by Deleted on Feb 4, 2013 1:47:52 GMT
welcome etoiledusoir
Post by pagan on Feb 4, 2013 3:04:45 GMT
Hi Will Due to additional Input and Output terminals available on Greg's latest PCB, you are able to have both In and Out wires on the Input side, without any voltage drops through the 2oz. copper tracks. Also, if you are careful, you will be able to cut this PCB into 2 individual single PCBs. Regarding Jeff's use with a laptop, you could also use the relay and PW5 Current Limiting method that I used for the internal JLH inside my PC ,that supplies my LG BR writer. Regards Alex And besides cutting them in half, They can be configured as "+/-" or "+/+" or "-/-" allan
Post by Deleted on Feb 4, 2013 5:18:28 GMT
Hi Will Due to additional Input and Output terminals available on Greg's latest PCB, you are able to have both In and Out wires on the Input side, without any voltage drops through the 2oz. copper tracks. Also, if you are careful, you will be able to cut this PCB into 2 individual single PCBs. Regarding Jeff's use with a laptop, you could also use the relay and PW5 Current Limiting method that I used for the internal JLH inside my PC ,that supplies my LG BR writer. Regards Alex And besides cutting them in half, They can be configured as "+/-" or "+/+" or "-/-" allan IF you can believe a Westie, that posssibly shops at Woolworths at Mt. Druitt, then the JLH will also work at reduced current capability with suitable component changes, as high as + and -55V . Alex
Post by seavan on Feb 5, 2013 4:21:17 GMT
shaun............04 themystical.....02 DaveK............04 steveecrane....04 PinkFloyd.......04 4est...............10 rafalkac..........04 juke................02 cj...................04 hirez69...........06 Listener..........04 Aerogater.......10 gommer..........04 cyteen............02 etoiledusoir.....02 Telstar............02 TOTAL>>>>>068 I will take 6 please. NEW TOTAL 074. Thank you!
Post by porfido on Feb 5, 2013 13:42:38 GMT
shaun............04 themystical.....02 DaveK............04 steveecrane....04 PinkFloyd.......04 4est...............10 rafalkac..........04 juke................02 cj...................04 hirez69...........06 Listener..........04 Aerogater.......10 gommer..........04 cyteen............02 etoiledusoir.....02 Telstar............02 Porfido.........04 Seavan..........06 TOTAL>>>>>078 Hi guys! 4 for me, please...
Post by jonclancy on Feb 5, 2013 22:48:56 GMT
Hurry up and do the last 20 will you lot?
Post by Deleted on Feb 5, 2013 22:56:19 GMT
shaun............08 themystical.....02 DaveK............04 steveecrane....04 PinkFloyd.......04 4est...............10 rafalkac..........04 juke................02 cj...................04 hirez69...........06 Listener..........04 Aerogater.......10 gommer..........04 cyteen............02 etoiledusoir.....02 Telstar............02 Porfido.........04 Seavan..........06 TOTAL>>>>>082 Jon i'll take four more if that's OK with you Read more: rockgrotto.proboards.com/thread/8851/ripple-eater-boards-limited-availablilty?page=2##ixzz2K4HpHiug
Post by mkusan on Feb 6, 2013 8:16:19 GMT
Hi Jon, Would love to get my hands on two boards please, I saw your post over on diyaudio and decided to join.
shaun............08 themystical.....02 DaveK............04 steveecrane....04 PinkFloyd.......04 4est...............10 rafalkac..........04 juke................02 cj...................04 hirez69...........06 Listener..........04 Aerogater.......10 gommer..........04 cyteen............02 etoiledusoir.....02 Telstar............02 Porfido.........04 Seavan..........06 mkusan..........02 TOTAL>>>>>084
Post by Deleted on Feb 6, 2013 10:09:18 GMT
OK Jon, I'll up my order to speed things up, didn't want to 'book' too many and deprive anyone but looks like its tapering off now.
shaun............08 themystical.....02 DaveK............04 steveecrane....04 PinkFloyd.......04 4est...............10 rafalkac..........04 juke................06 cj...................04 hirez69...........06 Listener..........04 Aerogater.......10 gommer..........04 cyteen............02 etoiledusoir.....02 Telstar............02 Porfido.........04 Seavan..........06 mkusan..........02 TOTAL>>>>>088
Post by Telstar on Feb 6, 2013 16:36:23 GMT
I have found 4 single channel JLH boards in my stash so two are more than enough for me i think.
Post by Deleted on Feb 6, 2013 20:15:07 GMT
Jon, Have you got enough orders to go ahead now or do you still need a few more? Dave
pingu
Post by pingu on Feb 7, 2013 11:16:09 GMT
Put me down for10 boards pls. Martin
pingu
Post by pingu on Feb 7, 2013 11:20:11 GMT
shaun............08 themystical.....02 DaveK............04 steveecrane....04 PinkFloyd.......04 4est...............10 rafalkac..........04 juke................06 cj...................04 hirez69...........06 Listener..........04 Aerogater.......10 gommer..........04 cyteen............02 etoiledusoir.....02 Telstar............02 Porfido.........04 Seavan..........06 mkusan..........02 pingu.............10 TOTAL>>>>>098 Read more: rockgrotto.proboards.com/post/126612/quote/8851?page=2#ixzz2KD9d5LNMNot sure how to get on list but see above post i will take 10 if yo have any left Martin
pingu
Post by pingu on Feb 7, 2013 11:44:00 GMT
shaun............08 themystical.....02 DaveK............04 steveecrane....04 PinkFloyd.......04 4est...............10 rafalkac..........04 juke................06 cj...................04 hirez69...........06 Listener..........04 Aerogater.......10 gommer..........04 cyteen............02 etoiledusoir.....02 Telstar............02 Porfido.........04 Seavan..........06 mkusan..........02 pingu...........10 TOTAL>>>>>098 doh done it now Read more: rockgrotto.proboards.com/thread/8851/ripple-eater-boards-limited-availablilty?page=2#ixzz2KDFhOCCu
Post by Deleted on Feb 7, 2013 12:04:29 GMT
pingu I edited it for you. Regards Alex
