Post by PinkFloyd on May 7, 2007 20:39:58 GMT
make a tread+toroid power supply (will a tread work?) Only if it outputs 12V "AC"
Post by PinkFloyd on May 7, 2007 20:44:03 GMT
Hi Mike, I would like to thank you for the great job you made on my X-CANv2. I simply love the way it sounds with my hd650!! Thank you Gianluca Hi Gianluca, I was beginning to wonder if you'd received her back.... thanks for posting Glad you like the transformation, as with all X-CAN v2's which have been modded expect the sound to get even better over a period of about 500 hours. How long have you had her powered up since receiving her back in Paris? All the best. Mike.
Post by gianix on May 8, 2007 10:58:40 GMT
Hi Mike,
I have her powered since i received, maybe 4 days. it already sounds better than my darkvoice 336i with the sylvania 6SN7W metal base and the RCA 6AS7GT grey plates. I tryed the K1000 too and I think it's not so bad, but I'm still looking for a better amp for this headphone.
All the best
Gianluca
Post by benke on May 20, 2007 16:34:33 GMT
Hi everyone, new to the forum, been reading posts for a few days now and decided that it was time to register. I changed to Mullard E88CC tubes 4 years ago after reading "X-CAN V2 Valve Audition " and since then i was hooked on tweaks.
A question to those with modded X-can V2's, primary the change given by "X-Can V2 upgrade kit now available".
How, in which way do you belive the sound has change (if it has at all), meatier bass, sweeter highs, more detail and so on?
As i said above i got the Mullard tubes and i'm thinking of sending the V2 to Mike for a full mod and just want to check in which direction (feel) the sound will go.
Post by PinkFloyd on May 20, 2007 22:36:46 GMT
Hi everyone, new to the forum, been reading posts for a few days now and decided that it was time to register. I changed to Mullard E88CC tubes 4 years ago after reading "X-CAN V2 Valve Audition " and since then i was hooked on tweaks. A question to those with modded X-can V2's, primary the change given by "X-Can V2 upgrade kit now available". How, in which way do you belive the sound has change (if it has at all), meatier bass, sweeter highs, more detail and so on? As i said above i got the Mullard tubes and i'm thinking of sending the V2 to Mike for a full mod and just want to check in which direction (feel) the sound will go. Hi Benke, Welcome to the forum your question is not one I would like to answer as doing so would be blowing my own trumpet and I don't like doing that...... I'm sure others will chip in and give their impressions before / after the mods. I still perform the mods because I feel they work wonders, if I didn't I certainly wouldn't be wasting my time, and other people's money, doing them...... Hopefully someone will chip in here with an independent opinion I don't publish personal feedback in a "testimonial" style, never have / never will.... each X-Canv2 / v3 I mod is kept personal and I work on it as if it were my own
FauDrei
Post by FauDrei on May 21, 2007 23:15:04 GMT
Hi Benke, Started myself with tubes, rolled two-three pairs until Ian kindly spared me a couple of his fabulous 6922's... I was surprised by the change and that incited my curiosity for other tweaks. In my opinion, you should definitely try a PSU electrolytic capacitors change (which turns music body into Music Body), get rid of input capacitors (which rediscovered highs) and change output capacitors for 1000uF non-polar ones (which ads and tightens the base even for low impedance phones). Ultrafast diodes do their part too (V2 responses "faster" and more precise to the feeded music). As for the various bypasses - matter of personal taste (I like them and recommend them, Mike likes them less lately)... Heck, you should try everything that is included in Mike's kit... If you are not handy with soldering iron (neither was I, but it did not stop me;) - he will do it for you for a really reasonable amount of money (and modding of your V2 will be documented in this very thread). So, to put it in just few words: Just do it. V3P.S. Oh, yes... do not forget to get rid of the standard wallwart - a good improvement by itself is just to feed your V2 with 1,5-2 A instead of 0,5 A of required 12 V AC. P.P.S. Mike, we can talk about my fee later...
Post by Deleted on May 22, 2007 0:00:09 GMT
Cheeky bugger ! What fee ? Mike should charge YOU for all the recommendations he has already made. other than (perhaps?) getting rid of the input capacitors, which are often there for a damn good reason. The designer of the equipment HAS to put them there in case of a DC component coming from the source equipment. Electrolytic coupling capacitors, even non polar types have been known to exhibit leakage. All the other suggested mods have been done many times over by Mike and other forum members. BTW, Mike accepts Paypal, cash, and bottles of wine. SandyK
Post by PinkFloyd on May 22, 2007 9:21:01 GMT
Removing the input caps isn't anything new, have been waffling on about them for years.... first time I removed them was around about 1997 on a v2. If you're sure there's no DC at your source outputs then remove them... same goes with the v3 www.rock-grotto.co.uk/x-can-v3-tweaks.htm
Post by PinkFloyd on May 22, 2007 9:24:13 GMT
Removing the input caps isn't anything new, have been waffling on about them for years.... first time I removed them was around about 1997 on a v2. If you're sure there's no DC at your source outputs then remove them... same goes with the v3 www.rock-grotto.co.uk/x-can-v3-tweaks.htm That reminds me.... must update that tweaks page, got a few more things to add to it
Post by Deleted on May 22, 2007 10:48:20 GMT
I'm not against removing input capacitors, I am suggesting though, that you be sure there is no DC coming out of the previous component. FTR, my solid state preamplifier is completely DC coupled. i.e. No input or output capacitors.It does sound better.My amplifier,however, does have a quality polypropylene capacitor in the input, just to be on the safe side. That way, in the unlikely event that the preamp blows up, the Power amplifier should still be O.K. SandyK
Post by PinkFloyd on Jun 15, 2007 19:04:30 GMT
Post by nirvana11 on Jun 30, 2007 23:34:18 GMT
well got these back initially mistakenly used an acoustic zen krakatoa power cord for the x-psu driving the x-10d's, a mistake, as well OTT for the purpose , created a muddy 'dark chocolate' (Naim?) kind of sound, 10 days later tried a much cheaper silver-copper cable into the X-PSU instead, much better, these modded x-10ds transformed cd playback, which is a complicated CD transport>Trichord jitter reducer>Electrocomp. DAC arrangement, with the x-10D in the chain (last) vastly improved on the sound much more immediate silky better soundstage much more 'present' & expressive, vocals in the room - many thanks v grateful had 2 x-10d's that were basically fu***** & Musical Fidelity said they were uneconomical to repair when i took them in with an A1000 that needed repair - had them transformed by Pinkie, well worthwhile! Modded X-10D sits between DAC outputs & Integrated amp, X-10D now used for TV & radio via DAC through Sony freeview set top box with optical out, & DVD Player digital outs for movies (modded x-10d has great effect for movie sound) & music : everything is basically 'pinkified' ! havent put back in cases yet so may have to send them back again soon! many thx! david
Post by PinkFloyd on Jul 17, 2007 18:02:41 GMT
Post by PinkFloyd on Jul 25, 2007 17:09:39 GMT
Post by PinkFloyd on Jul 25, 2007 17:51:20 GMT
No glue? What are the white circles on the board for? Felt pads Miguel...... won't do any damage and every little bit of damping helps No glue "yet" I haven't finished testing this one.
Post by PinkFloyd on Sept 10, 2007 10:26:16 GMT
Post by Deleted on Sept 10, 2007 21:47:28 GMT
Miguel The pictures were fine last night, and still are this morning, at my end. Certainly not your amplifier ! Does yours use 80s and 5Y3 s ? They glow better ! Alex
Post by PinkFloyd on Nov 2, 2007 13:12:06 GMT
Post by PinkFloyd on Feb 22, 2008 20:03:43 GMT
Post by PinkFloyd on Mar 6, 2008 14:40:23 GMT
Post by PinkFloyd on Mar 8, 2008 21:00:41 GMT
Post by leo on Mar 8, 2008 22:26:36 GMT
Some nice looking work there Mike!
Post by clundbe on Mar 9, 2008 10:33:29 GMT
My baby looking so fine. The scottish wizzard has done it again! Thanks Mike!
Post by PinkFloyd on Mar 29, 2008 17:04:24 GMT
29th March 2008 - Stephen Lamb's X-Can v2 Panasonic FM, EVOX Rifa, Samwha VA, ELNA RE2, UF4007 ultrafast diodes, 470uF output caps, input caps removed 24K gold plated jumpers fitted, Russian 6H23N (1984), new ALPS pot, purple LED, Jalco pro socket and fluted black knob. Had to funky angle the EVOX cap, the series I ordered are pretty "big"
Post by PinkFloyd on Mar 29, 2008 17:16:11 GMT
Some nice looking work there Mike! Cheers Leo! No wonder I go through a lot of soldering irons ;D
