Post by gommer on Jun 3, 2013 17:07:50 GMT
Hello again,
@syd, I've removed you from the list. It doesn't affect total price too much, so i think it'll be OK.
Total price for buying 100 pieces (or 50 where appropriate) of all semiconductors (including the 3V3 zener and SF12, 2 versions of BC327 and BC337: -25 and -40) and then dividing the cost amongst all currently interested, results in a total of €12.77 per channel or €25.54 total per amp. That's reasonable for dividing the cost amongst only 6 amps. If more people are interested in matched sets, then the price goes down.
The BOM price per HA PCB (excluding resistors and PCB) is now at €36,5 or €73 per amp. I'll need to check for the PCB price, which I can as size is final.
I'll keep this open a bit longer. I can't order the PCB yet anyway, as there's a small error in the layout/schematic that Will has sent me. Meanwhile, I'll have a look at the PSU PCB and parts.
Cheers, Marc
Post by jeffc on Jun 3, 2013 20:38:26 GMT
Hi Marc, I'll take Syds 2 x boards in the GB if that's OK. Being my luck I'll stuff up the 3 mm thick PCBs attending to mods to my Class A HA and these could come in very handy. Or I have most parts to build a dedicated Pre should I ever get bored in retirement.... cheers.. jeffc PS. Just to qualify, sorry, I'd only need the PCBs... and maybe the dual transistors in the way of components.
Post by Deleted on Jun 3, 2013 21:29:22 GMT
Is this any help Marc? I don't know if you are offering only full kit sets or cherry picking too but this should hopefully give both options? It should, in theory, a case of copying the table and adding your info.(First time doing a proboards table so not sure) PART REF
| VALUE | DEVICE | Quantity per stereo pair
| asdiasx | gommer | pingu | spirit |
| | C1
| 100PF
| polystyrene
| 2
| C2
| 68PF
| polystyrene
| 2
| C3,4,6,10,18,19,20
| 100nf
| MKT
| 14
| C5,7,8,9,11,21,22
| 100uf
| lytic
| 14
| C16
| 1uf
| MKT
| 2
| C17
| 3u3
| MKT
| 2
| D1 | SF12 | Diode | 2 |
| D2 | c3v3 | Zener diode
| 2 |
| T1 | BC559 | TO92 | 2 |
| T2 | LS352 | Dual | 2 |
| T3 | LS313 | Dual | 2 |
| T4 | BC558B | TO92 | 2 |
| T5 | BC557B | TO92 | 2 |
| T6 & T8
| BC547 | TO92 | 4 |
| T7 | BC549C | TO92 | 2 |
| T9 | BC337 | TO92 | 2 |
| T10 | BC327 | TO92 | 2 |
| T11 | 2SA1930 | TO220 | 2 |
| T12 | 2SC5171 | TO220 | 2 |
| VR1 | 78L15 | TO92 | 2 |
| VR2 | 79L15 | TO92 | 2 |
| IC1 | OPA134 | DIP8 | 2 |
| CONNECTORS | vertical 2 way
| 5mm pitch
| 10 |
| HEATSINKS | twin fin
| 25.5mm pitch
| 4 |
| TRIMMER | 500r | bournes | 4 |
Post by Deleted on Jun 3, 2013 21:52:53 GMT
I've removed you from the list. It doesn't affect total price too much, so i think it'll be OK.Cheers, Marc Thanks Marc, sorry for the hassle, I meant what I said, if it messes up your discounts I'll pay my share. So when you're finalising just PM me. Syd
Post by gommer on Jun 4, 2013 20:29:58 GMT
Alright, I've decided what to do. Thanks Chris for your courageous effort, but editing these forum tables will be a nightmare and it would remain impossible to simple copy paste from a spreadsheet.
So, I'll be tidying up my spreadsheet and use Chris's idea to format it and drop that on Google docs. You'll be able to edit the requested numbers yourselves and see the price change in real time.
It'll be a lot easier to cherry pick individual items this way, you're all welcome to do so. I'll post as soon as it's finished and online.
Cheers, Marc
Post by gommer on Jun 5, 2013 12:45:06 GMT
Here you go, order at will in this spreadsheetBut PLEASE, only edit order numbers for yourselves in the 'Orders' tab. You'll find that the spreadsheet auto updates price per part and totals per participant. In the 'BOM' sheet you'll find the BOM (duh) with links to the exact items that i intend to buy. As indicated above, you're welcome to select individual items. If you intend to order complete sets, then select the set, for your convenience. You can additionally order extra items on top of the set if you want. All items bought in bulk (typically 100 or 50) will be matched in pairs or quads, as appropriate. Cheers, Marc
Post by Deleted on Jun 5, 2013 13:58:52 GMT
thanks Marc
Post by gommer on Jun 5, 2013 14:14:22 GMT
You're welcome. BTW, price of PCB's is at zero for the moment, but they're not free
Post by gommer on Jun 5, 2013 14:58:51 GMT
Hi Marc, I'll take Syds 2 x boards in the GB if that's OK. Hi Jeff, You're welcome to add yourself to the spreadsheet now. Just add your name in the first tab and fill in the numbers. You're my Guinea pig Cheers, Marc
Post by asdiasx on Jun 5, 2013 17:52:11 GMT
Hi everybody! I'm in! Shaun, thanks for the reminder! Rgds
Post by gommer on Jun 5, 2013 21:20:56 GMT
Update: HA PCB price has been added (also roughly adapting to ordered numbers).
Post by Deleted on Jun 5, 2013 22:28:17 GMT
Very slick work Marc.
Post by Spirit on Jun 6, 2013 5:21:00 GMT
Very slick work Marc. wot 'e sed. Cheers Marc!
Post by jeffc on Jun 6, 2013 9:57:52 GMT
Thanks Marc... guinea pig.. hey I better be careful then to add and not delete.. cheers.. jeffc
Post by gommer on Jun 6, 2013 10:30:44 GMT
Hehe, it seems it turned out OK and you've just made the PCB price drop
Post by gommer on Jun 6, 2013 19:44:41 GMT
New update: price estimate for PSU PCB added (also with auto price update).
Next I want to add the BOM for PSU PCB. Does anyone care to help me with that, as I've missed the discussions on this subject. I don't get any further than 2x LM317...
Cheers, Marc
Post by Will on Jun 6, 2013 20:14:52 GMT
Hi Marc,
I think Jon did a quick BOM in the original HA thread (for the pcb I sent you) - Have a quick look there whilst I see If I can find the right file to generate the BOM for you.
Post by gommer on Jun 6, 2013 20:17:37 GMT
Cheers Will, I'll check it out tomorrow.
Post by gommer on Jun 7, 2013 12:23:50 GMT
Aha, found it here and onwards.
pingu
Post by pingu on Jun 12, 2013 23:59:08 GMT
Aha, found it here and onwards. Adding a late "Thanks" Marc a really nice bit of work. Well done Martin
pingu
Post by pingu on Jun 17, 2013 11:43:34 GMT
Aha, found it here and onwards. Hi, Not sure if this is any help now but Shaun posted this on the the thread earlier. If this is the PSU board you are using H4004 for the bridge (saving my last two SF12 for you know what) U5/6/7/8 IN4007 C1 470pf 100V C2/3 2200UF 35V low ESR C3/8 10UF 50V Suntans . Sorry about the leaning tower of power on the photo. C4/6 100UF 50V Panasonic FC. R1/4 100R ½ W R5/6 Unpopulated R2/3 2K bourns type multi-turn trimmers Regs are LM317/337 Read more: rockgrotto.proboards.com/thread/8894/class-pcb-parts-group-buy?page=6#ixzz2WTKwqfmoSorry for the late reply have been looking for the list from Shaun it's a bit diffrent from Jon's list. Hope it helps and not complicates things Martin
Post by Deleted on Jun 17, 2013 12:12:41 GMT
Martin A couple of points. I used the SF12 in the bridge rectifier section , and they sounded better than 1N4004 etc. The faster UF400x may be an improvement over the 1N400x though. I don't recommend low ESR designated capacitors for the PSU filter caps. It's O.K. to have capacitors there that have relatively low ESR, but not stated to be low ESR. Low ESR capacitors use a different formulation which ensures a very low impedance at 100kHz, but often leads to added sibilance. With the JLHs, it is best to use a 2,200uF 10V low ESR in parallel with a normal 2,200uF 16V electrolytic on each supply rail for the same reason.
Regards Alex
pingu
Post by pingu on Jun 17, 2013 13:21:33 GMT
Thanks Alex,
1) I used SF14s for PSU, not sure of the caps may have been low ESR not sure will have to check.
2) Yes I used caps as described for the JLH RE but as there is no current limiter first stage I used 4.700Ufs, some one recomended that set up I think somewhere on here
Thanks Alex Martin
Post by Deleted on Jun 17, 2013 21:52:14 GMT
Thanks Alex, 1) I used SF14s for PSU, not sure of the caps may have been low ESR not sure will have to check. 2) Yes I used caps as described for the JLH RE but as there is no current limiter first stage I used 4.700Ufs, some one recomended that set up I think somewhere on here Thanks Alex Martin Hi Martin The SC (Jaycar) HA's JLHs can do without the CL section, and use 4,700uF electros, but the Class A HA/preamp needs the CL section installed, and only 2,200uF capacitors. To use 4,700uF may result in a Toshiba device overheating during the initial stabilisation period, and possible "hunting" of the output voltage of over plus and minus several millivolts.. Regards Alex
pingu
Post by pingu on Jun 18, 2013 0:00:20 GMT
Hi Alex, Thanks for the information the couple of JLH's I have built seem stable, at least on a DMM reading to 2 decimal places and all seems cool. I have run them for a about 10 days on and of at various voltages fron 12v to 20v (+/-), but with no load of course as I have not yey finished the small Brice HA from HFW mag. I will rebuild the other pair as you suggest to use with this HA including the CL and diffrent caps. Thanks for the info much appreciated. Martin
