Post by Deleted on Apr 6, 2012 12:10:52 GMT
When I first drilled the panel for this I made a mess of it, big surprise I then read Jon's post some time later and drilled a new hole over to the side, which looks a lot better. I then hit on the idea of getting a little engraved plaque to cover my butchery, its a little larger than I needed and maybe a bit thicker metal than ideal but in the rack it looks fine. Then just recently I finally added a 'mains on' LED and two for the Buffalo's indicators. I got little 3mm LED s/s holders off Ebay. They look a lot neater than the pictures, because of the magnification, my excuse anyway. I thought it worked out as an inexpensive way to save having to get a new front panel all the way from Italy. Syd
Post by xerxes on Apr 6, 2012 12:16:32 GMT
Nice job, where did you get the engraved plaque?
Post by Deleted on Apr 6, 2012 13:13:41 GMT
Nice job, where did you get the engraved plaque? x2 on both counts
Post by Deleted on Apr 6, 2012 15:29:11 GMT
Thanks guys, it certainly rescued a wreck, and made the whole thing look less home made. I can only find his email address - engravingworld@btconnect.com. I remembered that I contacted him direct to see if he would do non-standard sizes. The s/s plaque was £12 and I got a brass one to put on a separate PSU for my Pierre Lurne CD player, to match the one on the actual CD player, for £8. I initially thought this a bit expensive, until I looked at getting Hifi 2000 to do some work There's loads of people on eBay doing these plaques. Syd
Post by jonclancy on Apr 7, 2012 21:49:29 GMT
Very tidy finish there, Syd!
Post by Deleted on Apr 7, 2012 23:25:24 GMT
Hi Syd great work the 2000 stuff can be a little pricey if you just need one part so good thinking on that front. take care
