Post by jonclancy on Jan 20, 2012 16:32:28 GMT
Anyone know of a good source for these, please?? There are running at about 20p each on eBay and RS!!! Madness!!!
Post by Deleted on Jan 20, 2012 22:44:33 GMT
Anyone know of a good source for these, please?? There are running at about 20p each on eBay and RS!!! Madness!!! Jon Jaycar has packs of 25 for between AU$9 and $10 , but that will not help you much. We are far better served for over the counter bits and pieces by Jaycar, Altronics and their resellers etc. Regards Alex
Post by Will on Jan 21, 2012 9:05:44 GMT
Post by leo on Jan 21, 2012 9:54:13 GMT
Post by Deleted on Jan 21, 2012 10:33:20 GMT
Anyone know of a good source for these, please?? There are running at about 20p each on eBay and RS!!! Madness!!! Hi John I've been getting mine from Maplins. they have a good range of them. take care
Post by jonclancy on Jan 21, 2012 17:18:51 GMT
Anyone know of a good source for these, please?? There are running at about 20p each on eBay and RS!!! Madness!!! Jon Jaycar has packs of 25 for between AU$9 and $10 , but that will not help you much. We are far better served for over the counter bits and pieces by Jaycar, Altronics and their resellers etc. Regards Alex 26p from Alex (at current conversion rate) 22 and 24p from Will's links. 25 to 27p from Leo's links. Thanks for taking the time to post some links guys. I still think we're in the wrong business!! these things should be a couple of pence each. Especialy is a machine is churning them out. I was watching the 3 axis CNC machine at Prodrive knocking out complex delrin clips (about one a minute) a few months ago. Six quid on stand-offs for my headphone amp chassis is daft!! BTW, I have drilled and tapped the last two holes on the front plate (Neutrik jack screws). So that's all the metalwork done on the Class A for now. I'll sort some box work out for the trafos in due course, but want to get some decent microphone cable to use as the umbilical next. Cheers Jon
Post by jonclancy on Jan 21, 2012 17:53:24 GMT
After that rant, I found 100 off M3 x 6mm tapped on eBay. With postage that'll make them just over 5p each. I also ordered some M3 x 6mm button cap stainless screws. I already have 10mm ones. If my calcs are correct, I'll be OK with the thickness of the ally case and the pcbs (1.6 - 3mm range). Hurrah!
Post by jonclancy on Feb 27, 2012 0:33:51 GMT
Even better - just got 100 for a tenner delivered from eBay. The 6mm ones were a little short, so I now have some 12mm on the way from HK. Not to mention I won some Bourns trimmers at an unrepeatable price. Enough for Will's boards and more.
