MF Upgrade for X-CAN v2 £169
Sept 3, 2011 13:35:42 GMT
Post by pcourtney1 on Sept 3, 2011 13:35:42 GMT
When MF introduced the X-CAN in 1995 they were snapped up by many, including myself, I think I paid £125 or so for the amp, obviously it was built to a price point that MF thought would stand up to a certain amount of scrutiny in the Hi-Fi press at the time, and while most of the reviews were positive, it was quite clear that improvements could be made, and many like Sid (with Mike's help) proved that better sq could be had with a little hard work.
imageevent.com/sidandcoke/musicalfidelityxcanv1mods
and how some good quality part replacements, the V1 could sound as good as the V2
www.rock-grotto.co.uk/Neilxcan2.htm
The V2 arrived on the scene in 2000
www.rock-grotto.co.uk/xreviews.htm
Not too long after many were tube rolling their V2's
www.rock-grotto.co.uk/valvetest.htm
and even Antony Michaelson at MF was getting asked about how the stock X-CAN could be improved, and they sat down and came up with the £169 upgrade offer
X-CAN upgrade schedule
Realign volume control
Replace all audio path electrolytics with low ESR, high temp. type
Replace bypass caps from ceramic to polycarbonate/polyester
Pure copper noise nulling screen fitted to PSU caps
Bypass PSU electrolytics with polycarbonate/polyester type
Replace ceramic bypass caps with polycarbonate/polyester type
Replace regulators with selected premium types
Precision re-bias
Replace PSU caps with low ESR high temp type
Replace 2x ECC88 tubes with precision matched pairs
Heater current, audio characteristics and transconductance matched
Replace 4x medium power output transistors with precision matched pairs
Log owner name, model and serial number in Musical Fidelity archives & Issue certificate signed by Antony Michaelson
Soak test for 48 hours Cost; £169 inc VAT
So what do you get for your money, let's see :
The published specs for my stock V2 are -
Output Power 1W into 32 ohms
Input Impedance 47KOhms
THD <0.015% 20Hz-20kHz unweighted
THD <0.005% 20Hz-20kHz A Weighted
S/N Ratio >96dB unweighted ref. full output
S/N Ration >108dB A Weighted ref. ful output
Freq Response 30Hz to 75kHz <+/- 1.0dB
The upgrade certificate signed by Antony Michaelson for my upgraded V2 states :
Output Power greater than 1.5W into 32 ohms
THD <0.008% 20Hz-20kHz unweighted
THD <0.003% 20Hz-20kHz A Weighted
S/N Ratio >99dB unweighted ref. full output
S/N Ration >112dB A Weighted ref. ful output
Freq Response 10Hz to 100kHz <+/- 3.0dB
Matched Pair of 6922EH Tubes electro-harmonix
so some worthy and measurable performance improvements !
So I set about comparing a stock V1 and stock V2 with the upgraded V2, the headphones I used for most of this testing were the AKG K-340 (400ohm) , they just sound nice on my bonce, and it has been difficult to replace them, that said in the last 48 hours I have also been using the Superlux HD-661 and whilst they do not give me that bigger jazz club sound, the 661's do provide a more "Recording Studio" sound, smaller room sound, but pleasant enough all the same, if you catch my drift.
Well, I can report that (as expected) , the upgraded V2 sounds better than the stock V2, and the stock V2 sounds a lot better than the stock V1
What I was surprised with however, is that the upgraded V2 did not (to my ears) sound that much better than the stock V2, well not £169 quids worth anyway, you would be better off buying a second V2 on ebay, and have some change to boot.
I am looking forward to sending one of my stock V2's to Mike, and kindly asking him to upgrade the hell out of it for me according to the tried an tested RG Recipe, then I will be able to A/B both upgraded V2 amps, I cannot wait to hear them both and report back.
some pictures of the PCB hosted on Photobucket
s1133.photobucket.com/albums/m595/Peter_Cix/MF%20X-CAN%20V2/
I need a better macro zoom camera, that's for sure, so apologies for the pics
Precision re-bias
