Post by musicmanic on Aug 29, 2011 15:03:47 GMT
If I use a Y-Splitter to use 2 heaphone amps which are 24 ohms and 300 ohms would I be getting a serial load of 324 Ohms and would that compromise either of the headphones sound?
Thanks
Post by PinkFloyd on Aug 29, 2011 22:26:07 GMT
If I use a Y-Splitter to use 2 heaphone amps which are 24 ohms and 300 ohms would I be getting a serial load of 324 Ohms and would that compromise either of the headphones sound? Thanks Are you serious?
Post by clausdk on Aug 29, 2011 22:46:36 GMT
I use a y-splitter in the headout on a player, when I have more than one phone to burnin, have not really tested the sound, but it does not sound bad..
putting two headphones in one output should lower the ohms AFAIK
Be carefull that you do not put two or more lowohms phones to the amp, if the ohms gets to low the amp. will not like it..
Note: I only do this when my phones are apr. the same ohms.
I suspect that you are not talking about using two amps, but two phones in one amp.
Post by musicmanic on Aug 29, 2011 23:42:38 GMT
I was just asking!! I think you've answered my question in your Scottish way. ;D
Post by musicmanic on Aug 29, 2011 23:45:01 GMT
I suspect that you are not talking about using two amps, but two phones in one amp. Yes. I was just thinking of a headphone splitter, for multiple listeners.
Post by musicmanic on Aug 30, 2011 4:36:44 GMT
Post by PinkFloyd on Aug 30, 2011 6:36:42 GMT
I was just asking!! I think you've answered my question in your Scottish way. ;D Claus is Danish
Post by clausdk on Aug 30, 2011 9:22:25 GMT
I suspect that you are not talking about using two amps, but two phones in one amp. Yes. I was just thinking of a headphone splitter, for multiple listeners. Then it should not cause any problems, but if a leightweight and a heavyweight is used with the same amp. the soundpressure would be very different in the two cans.. Oh and the splitter is parralel not serial, so the load would be somewhere between the ohm numbers, some people now how this is calculated, i do not
Post by mrarroyo on Aug 30, 2011 10:15:55 GMT
(R1*R2)/(R1 + R2)
Post by musicmanic on Aug 30, 2011 19:35:10 GMT
I was just asking!! I think you've answered my question in your Scottish way. ;D Claus is Danish It was meant for you. Got quotes mixed.
Post by PinkFloyd on Aug 30, 2011 19:59:34 GMT
James... that part has arrived so I'll make your adaptor up tomorrow....
Z
Post by Z on Aug 30, 2011 22:11:49 GMT
is he talking about hooking two amps to one headphone?
i wanna see what happens! do it!
Post by Deleted on Aug 30, 2011 22:35:14 GMT
is he talking about hooking two amps to one headphone? i wanna see what happens! do it! READ THE THREAD !
Post by musicmanic on Aug 31, 2011 0:34:06 GMT
is he talking about hooking two amps to one headphone? i wanna see what happens! do it! I'll tell you what. Why don't you try it and let me know.
Post by musicmanic on Aug 31, 2011 0:35:27 GMT
James... that part has arrived so I'll make your adaptor up tomorrow.... Thanks mate. Much appreciated. Love the amp and little pinkie. Will order some backup tubes soon too.
Post by Deleted on Aug 31, 2011 0:56:21 GMT
is he talking about hooking two amps to one headphone? i wanna see what happens! do it! I'll tell you what. Why don't you try it and let me know. He wouldn't know how to ! ;D
Post by Deleted on Aug 31, 2011 1:04:49 GMT
If it was a permanent thing, it would be better to short circuit the existing 33 ohm output resistor , increase the capacitance of the 220uF output capacitor to 470uF or 1,000uF, and from the outgoing side of the capacitor connect 2 x 33 0hm resistors to individual headphone sockets. Alex
Post by mrarroyo on Aug 31, 2011 10:14:36 GMT
Or buy a 2nd amp to really help the economy!
Post by PinkFloyd on Aug 31, 2011 21:27:21 GMT
James... that part has arrived so I'll make your adaptor up tomorrow.... Thanks mate. Much appreciated. Love the amp and little pinkie. Will order some backup tubes soon too. Hi James, Tried a few values out with the 7506 and, to my ears, 80R was the best.... Built you up an adaptor using Neutrik Jack / socket / evolution OFC Pro cable and 1% RC55 resistors. Should do the trick nicely
Post by musicmanic on Aug 31, 2011 23:50:01 GMT
Hey Mike that looks beautiful too! Thanks very much. Can't wait to try the Sony's with it.
Hope your tooth is better.
Regards,
James
