USB leads
Aug 19, 2011 20:00:54 GMT
Post by Deleted on Aug 19, 2011 20:00:54 GMT
(My second bash at this, I wrote what turned out to be a huge screed and then lost the lot! Oh well, maybe a more condensed version this time....)
Even without going silly expensive there is a huge range of claimed quality available.
I was reminded of this during a conversation with Claus, where he pointed out that the USB A-B that comes with the Mini-Ape is particularly good, working well where others fail.
I dug out an old USB hub that used to always be glitchy, popped on the Apes lead and voila! Faultless.
I tried again with the HA INFO NG27 supplied lead and it too worked without any hick-ups.
So, off I went in search of inexpensive HQ USB leads from the stores. First stop was a computer store, they tried to sell me the twin-of-NG27lead for a cool €40!
The search continued until I found the Vivanco 45200. Virtually identical again, save for colour and for the ferrite being at the B end rather than the A, for a far more reasonable €9.95.
I ran it through the same hub test and is passed faultlessly.
I now intend to buy a couple more, cut the 5vbus cores and hear if it makes any difference over a standard lead.
For the touchy-feely amoung us, the standard lead tends to have thin outer insulation, no ferrite and if you roll the cable between your fingers you can feel the cores "grinding" within, a little like an internet cable.
These better ones have a ferrite and obviously have thicker outer insulation that holds the inner insulations and cores firmly in place.
