wadiaman
Measure twice.......cut once
Post by wadiaman on Aug 8, 2011 10:03:38 GMT
Mod's as per various posts on this forum,these include....... IRL 510 Mosfets fitted,also LM317A,both with extra heatsinks. Upgraded bias trimpots and 470uF cathode caps fitted under board. 35v 6800uF power cap fitted.Samwha VA 2200uF/130 deg C output caps fitted and Wima 3.3uF/50v bypass caps fitted. 100 ohm "dummy load" resistors fitted to H/P jack socket. Input selector switch removed. Heat proof neoprene insulated strips fitted behind input/output sockets to prevent shorting with long pin RCA plugs. Stock 6922 EH Russian Electroharmonix valve. Extended S/steel corner posts fitted to accommodate mods and top plate slotted for easy access to trimpots.Similarly bottom plate spaced out to accommodate cathode cap's. Will be supplied with "Stotronics" SM power supply,output 24v-2A,with IEC socket. Does NOT have Frans's heater power supply mod ! Pic' as below. PRICE £50 delivered UK by Royal Mail Special Delivery,next day.
wadiaman
Post by wadiaman on Aug 14, 2011 10:55:18 GMT
Price reduced............£40 delivered UK.........is there anybody out there ?
Captain
Beam me up Scotty!
Post by Captain on Sept 10, 2011 16:33:04 GMT
pm sent
wadiaman
Post by wadiaman on Sept 18, 2011 14:37:21 GMT
Sorry for late reply,been away on hol's.........pm sent !
wadiaman
Post by wadiaman on Oct 28, 2011 12:28:12 GMT
This is still up for sale........at £35 now,it's gotta be worth that......come on you lot !!
