Mike, have you measured the output in mW of this amp? Thanks.
What output resistors does it have and which HP (impedance) do you want the numbers for.
The power levels are dependant of those 2 values.
Here are the powers for a Panda with a NO (0 Ohm) output resistor (rounded off values):
HP impedance ....Class-A......Class-AB
32 Ohm ..............640mW.......3,125mW
64 Ohm ..............1,280mW ...1,560mW
150 Ohm ............670mW ......670mW
300 Ohm ............330mW ......330mW
600 Ohm.............170mW ......170mW
Here are the powers for a Panda with a 10 Ohm output resistor (rounded off values):
32 Ohm ..............640mW.......1,800mW
64 Ohm ..............1,170mW ...1,170mW
150 Ohm ............580mW ......580mW
300 Ohm ............310mW ......310mW
Here are the powers for a Panda with a 22 Ohm output resistor (rounded off values):
32 Ohm ..............640mW.......1,100mW
64 Ohm ..............640mW ......870mW
150 Ohm ............510mW ......510mW
300 Ohm ............290mW ......290mW
600 Ohm.............160mW ......160mW
Here are the powers for a Panda with a 47 Ohm output resistor (rounded off values):
32 Ohm ..............500mW.......500mW
64 Ohm ..............500mW ......500mW
150 Ohm ............380mW ......380mW
300 Ohm ............250mW ......250mW
600 Ohm.............140mW ......140mW
Here are the powers for a Panda with a 75 Ohm output resistor (rounded off values):
32 Ohm ..............280mW.......280mW
64 Ohm ..............330mW ......330mW
150 Ohm ............300mW ......300mW
300 Ohm ............210mW ......210mW
600 Ohm.............130mW ......130mW
Here are the powers for a Panda with a 120 Ohm output resistor (rounded off values):
32 Ohm ..............140mW.......140mW
64 Ohm ..............190mW ......190mW
150 Ohm ............200mW ......200mW
300 Ohm ............170mW ......170mW
600 Ohm.............120mW ......120mW
So pick your headphone impedance and you will have a pretty good idea.
NOTE: Most headphones can handle a power of around 100mW to 200mW.
You can clearly see that a higher output resistance of the amp leads to safer values for all headphones where 0 Ohm or low Ohmic values can seriously overdrive (destroy) low Ohmic headphones !
High Ohmic headphones are always in the 'safe zone' with this amp.
Amps with a 120 Ohm output resistor in the output are also always in the 'safe zone'.
Some headphones, however, perform sonically better at lower output resistances but you must be aware that these low output resistance values can destroy low Ohmic headphones.
are the goalposts moved again when using the LCD2 for example, surely these could handle the panda with no output resistor, or am i missing the point?
