Post by jonclancy on Mar 16, 2011 21:47:20 GMT
As I have finally got my DIY amp up and running, the time has come to say farewell to my pair of Arcam D290P power amps.
One I have owned from new (94-ish), and the other I bought from eBay a few years ago. Both are in very good condition, but no boxes. Both shorting links for mono (not bridged) operation are present. Rated output is 70WPC into 8 Ohms.
Both amps have been re-capped using premium parts (Panasonics, not boutique) and have a pair of socketed LM49710 (like a single 4562) doing the biz on the front end.
Both units' 2 x 10 000uF power supply reservoir caps have been replaced, too.
NOW ON EBAY.
Update:
Amps all boxed and ready to go - one box at 14Kg. UK courier delivery around £9.80 standard, £23.35 express saver (next day PM) and £26.14 express (next day noon), dependant on courier used.
Can send medium res pics, or hi-res on CD, and also .pdf of service and user manuals.
Thanks for looking!
Jon
Post by XTRProf on Mar 17, 2011 8:23:03 GMT
What diy amp you have now? The class A? But that is just not enough power at 15W at 8ohms.
Post by Deleted on Mar 17, 2011 8:58:45 GMT
What diy amp you have now? The class A? But that is just not enough power at 15W at 8ohms. Chong Jon doesn't have the 15W Class A yet, although it may be on his agenda. You would be surprised at how loud a 15W/Channel, solid state Class A design can sound, even in comparison with valve amplifiers of double the power.It can actually deliver 25-30W into 4 ohm loads, although above 7.5W into 4 ohms it operates in Class AB. The 15W Class A design has a much greater power bandwidth than a typical valve amplifier design too, as it can also go down to DC if offset correctors are used, and the HF response is much greater than the vast majority of valve designs. The LF response will also obviously depend on how low the speakers can go. My DCM QED 8ohm (nominal) speakers are only 87dB sensitivity at 1W and 1 metre, yet I have never been able to use anywhere near full power in a domestic situation. Alex
Post by jonclancy on Mar 19, 2011 14:05:30 GMT
..and I thought I had got some interest..!!! My DIY amp is a stereo MyrefC, designed by Mauro Penasa and PCBs a Twisted Pair clone from the Uriah/Peter DIYA buy. I have a second amp case to drill out, and I bi-amp my IPLs www.diyaudio.com/forums/multi-way/82947-ipl-speakers-nearing-completion-wow.htmlThese are 89dB sensitive, IIRC. And yes, I do intend to try Class A amplification. I have chassis ready for that, as I was, and still intend to build some Pass designs. Cheers Jon PS Apologies for any late/no replies, as I am trying to recover my Mac from a meltdown. Nearly done, but need to take delivery of another back up HDD before I can use the thing again!
Post by gover1 on May 26, 2011 16:08:55 GMT
Jon, are these still available? pretty interested if so
Post by jonclancy on May 30, 2011 23:15:12 GMT
Jon, are these still available? pretty interested if so Indeed, they are. If you PM me, I can arrange to get some photos emailed over... Thanks for your interest!! Cheers Jon
Post by jonclancy on Sept 1, 2011 20:08:46 GMT
OK, I'm going to bump this up before these go on the 'Bay!!
Thanks for looking!!
Jon
Post by XTRProf on Sept 2, 2011 5:06:20 GMT
Eh? I thought this was already sold?
Post by jonclancy on Sept 2, 2011 12:54:15 GMT
Nope - didn't hear anything back from the chap above. His last login was to make that post.
So, still boxed and waiting to go. I've got my eye on some serious eBay purchasing that needs to be funded.
Post by jonclancy on Sept 3, 2011 9:51:12 GMT
Now on the 'Bay!
Jon
