M1-Dac and M1-HPA Advice
Jan 28, 2011 9:35:25 GMT
Post by jezuz on Jan 28, 2011 9:35:25 GMT
After reading a guide from solderdude about resistance and impedance, I feel somewhat smarter.
rockgrotto.proboards.com/index.cgi?board=b&action=display&thread=6057
Nothing is stronger than the weakest link, that's what often gets said.
Now the M1 set looks fine and it apparently fits perfectly to HD650 which I like. My current ones are dying and I'm buying a new set as replacement until august when I get HD800.
Now to the issue.
M1-HPA looks fine:
Output
Output Power 1.1W into 32Ω
Output impedance less than 1Ω
Output level 5.2V rms max
Frequency response 15Hz to 75kHz -3dB max.
Signal to noise >109dB “A”- wtd
Total harmonic distortion <0.008% 10Hz to 20kHz
Connections
Line level input 1 pair RCA line in left and right
Line level outputs 1 pair RCA line out left and right
1 pair RCA pre-out left and right
Digital input 1 USB type ‘B’ connector for computer/PDA
Power requirement
Mains voltages 90-250VAC 50/60Hz
Consumption 25 Watts
M1-DAC do not.
Output
Output impedance 47 ohms
Output, digital 0dB level RCA output - 2.2V r.m.s. nominal (RCA) 4.4V (XLR)
DAC
DAC circuit 24 bit Delta-Sigma (bit stream) dual differential 8x over-sampling to 192kHz Total correlated jitter <12 picoseconds peak to peak Linearity <0.1dB down to -96dB Frequency response 10Hz to 20 kHz -0.1dB max.
Channel separation >105dB 20 Hz to 20 kHz
Signal to noise >119dB “A”- wtd.
Total harmonic distortion <0.0025% 10Hz to 20 kHz
Connections
Line level outputs 1 pair line level RCA (phono), left and right
1 pair line level XLR (balanced), left and right
Digital inputs 1 XLR AES balanced digital input
1 RCA coaxial connector SPDIF 32-192 kbps (16-24 bit stereo PCM)
1 TOSLINK optical connector 32-96 kbps (16-24 bit stereo PCM)
1 USB type ‘B’ connector for computer/PDA 32-48 kbps
Power requirement
Mains voltages 115/230VAC 50/60Hz (factory pre-set) 100VAC 50/60Hz (alternative)
Consumption 10 Watts maximum
The M1-dac seems to be for low-ohm headphones. Is it possible that my understanding is wrong and that the low power flow through it doesn't matter when connecting it to M1-HPA?
As I see it, buying the M1-Dac could burden the MPA and then I wouldn't get the best possible sound in my HD650. I'm aware that MF use cheap parts, but that what everyone do today unless you pay good for it.
And I like this dac due to that it can handle 24/192 through USB, while it reviews looks good. I do happen to have:
1 x Optical + 1 x Coaxial S/PDIF Output
On my motherboard, but I have never used and don't know the difference.
www.asus.se/product.aspx?P_ID=G7JoxzAEXsQwDt7G
Is it any good alternative to change out the M1-Dac with or is it just my imagination?
I'm not the smartest one when it comes to this field, it's my first Dac and HPA. Any help would do a lot, I always look for the best possible option towards a certain price. I were going to have bought these yesterday, but I feel a asleep(so might as well ask).
And the upgrade MF got for Dacs seems expensive while the X-series is cheap.
Now to the issue.
M1-HPA looks fine:
Output
Connections
Power requirement
M1-DAC do not.
Output
DAC
Connections
Power requirement
