Post by mizunoblackox on Dec 11, 2009 16:14:27 GMT
The left channel of my x10 V3 went out and I found some burnt marks on two of the output transistors. As I reckon that it's a matter of time the other 2 transistors for right channel will also go, I decided to replace all 4 output transitor.
But I made a mistake of not noting down which of the 2 transistors are JE340 (PNP) which other 2 are JE350. Appreciate fellow forumers' advise on whether output transistors labelled TR206, TR207, TR106, TR107 on the circuit board are JE340 or JE350.
Thks
Post by PinkFloyd on Dec 11, 2009 21:12:20 GMT
The left channel of my x10 V3 went out and I found some burnt marks on two of the output transistors. As I reckon that it's a matter of time the other 2 transistors for right channel will also go, I decided to replace all 4 output transitor. But I made a mistake of not noting down which of the 2 transistors are JE340 (PNP) which other 2 are JE350. Appreciate fellow forumers' advise on whether output transistors labelled TR206, TR207, TR106, TR107 on the circuit board are JE340 or JE350. Thks If you can wait a few days I have an X-10 V3 coming in for an upgrade, I'll sort you out with the EXACT details when I have it in front of me. Mike.
Post by mizunoblackox on Dec 12, 2009 1:20:27 GMT
Hi Pinkfloyd Look forward to your advice..really appreciate it
Post by PinkFloyd on Dec 18, 2009 21:49:17 GMT
Should be here any day now, will post as soon as I get the info.
