Post by ALVIN on Jun 26, 2009 13:26:00 GMT
Hello, -- Is there any way you could make \ produce totally clear face plates for the X-10D and X- LP\S units ? With a purple L.E.D inside, they would look BLOODY AWESOME!! ---------- I would buy a few for sure. They would have to be heavy duty in construction and quite precision made to accept the 2 screws holes and Cristal clear of coarse. --------- Think about it!!
Post by ALVIN on Jul 5, 2009 3:21:20 GMT
"Hello" Earth to mars, anybody out there?
Post by Deleted on Jul 5, 2009 6:53:10 GMT
Hello, -- Is there any way you could make \ produce totally clear face plates for the X-10D and X- LP\S units ? With a purple L.E.D inside, they would look BLOODY AWESOME!! ---------- I would buy a few for sure. They would have to be heavy duty in construction and quite precision made to accept the 2 screws holes and Cristal clear of coarse. --------- Think about it!! Alvin If they are not of irregular shape, you masy be able to get your local Perspex supplier to cut a couple of pieces for you. You would need to drill a couple of very fine starter holes first , as Perspex cracks easily . SandyK
Post by merton on Jul 5, 2009 7:07:08 GMT
make sure the bit is sharp as hell and that you go slow. doing it in 100 plus degree weather would help as well i think.
Post by robertkd on Jul 5, 2009 10:53:48 GMT
I'd probably add use a bit of wd40 on the drill bit as well
