Post by PinkFloyd on Oct 5, 2009 21:34:09 GMT
Any of you guys tried Clone CD? I find it simple and it does the job ;D
Post by FritzS on Oct 6, 2009 2:21:58 GMT
I normally use the LG BluRay writer, as the rips sound better than those from the other Pioneer DVD drive. DESPITE identical checksums ! (both calibrated by EAC server) Alex, if two music file's exact bit per bit the same, they could not sound different - the only one difference they reside on different places on the harddisk. There is no reason why they could sound different Please test the Windiff.exe utility from Microsoft to compare two files bit per bit support.microsoft.com/?scid=kb%3Ben-us%3B159214&x=10&y=11
Post by Deleted on Oct 6, 2009 3:18:53 GMT
Post by FritzS on Oct 6, 2009 18:28:11 GMT
If the files are bit by bit equal - the only difference could be jitter caused from the PC hardware - conventional HD's they have different seek time, the music files could be fragment, etc.
SSD have no mechanics, and have the same seek time, the same delay - less jitter.
Post by Deleted on Oct 6, 2009 20:58:00 GMT
Check out this quote from Computer Audiophile : I just checked on newegg, and the article seems correct about similar performance, although it was comparing the vertex to agility, not the vertex turbo. the turbo IS marginally faster than the vertex, if 10 Mb/sec counts as marginal. I'll call tomorrow and see if I can switch my order, I think. www.newegg.com/Product/Product.aspx?Item=N82E16820227462&cm_re=oc... The Agility 120 Gb is $259 after $30 mail-in rebate, whereas the (only) 60 Gb Vertex Turbo I ordered is $249. The Agility goes up to 230 Mb/sec read, and up to 135 Mb/sec write with the Vertex Turbo being 10 Mb/sec faster for each. Both SSDs come with 64 Mb cache. The Agility 60 GB (same specs) is only $169 after rebate. that's cheap enough for any audiophile to afford, IMO.
Post by Deleted on Oct 7, 2009 4:58:30 GMT
Really ? I deliberately chose a review from a German source. It was one of very many. TweakPC (Germany) “The OCZ Vertex shows a marked improvement over the last generation of SSDs. The performance almost makes the mouth water. While reading the economic SSD up to 250 MB/second and write 128k blocks from their maximum of nearly 200 MB/sec. These are truly outstanding values in this test. If you are looking for maximum performance for a system disk, the OCZ Vertex is the SSD you are looking for. A Windows 7 Boot Time on an SSD of just 17.9 seconds speaks for itself and earns our Performance Award for the OCZ Vertex.”
Post by Deleted on Oct 24, 2009 12:52:22 GMT
I have just received confirmation from the developer of the XXHE playback software, that 2 of them were able to hear differences between 2 .wav files with identical checksums that I uploaded. Peter St. will now be doing some indepth analysis to try and find out the reasons for these audible differences. Many thanks for the continuing support by many RG members in this mad crusade of mine. Alex The link to this thread is : www.computeraudiophile.com/content/Windows-7-anyone-using-it-yet#comment-29013
Post by Deleted on Nov 9, 2009 0:38:17 GMT
I have been playing with EAC, after getting to know its quirks and get freedb working (had me going for a while).
I've set it to rip from my laptops standard DVDR/W and dump .wav straight to a pretty standard USB pen.
These have been compared to the same tracks ripped using WMP also dumping .wav directly to said pen.
Listening via the HA NG27 there is a difference, not enough to select one as "better" than the other, but subtle differences for sure.
I then dumped both versions of the tracks back down to a CDR and listened via the HiFi setup (Meridian 506.24/Nordost Blue Heaven/MF xcanv2 with mods and pinkie) but the same headphones. Hit random and off we go. Skipping to get like for like, hang on folks, this is more obvious, one version is more fluid, the other sounding a tad restrained. Ran through a few times, finally noting the track numbers I prefered, to be checked against the track listing back on the laptop.
Well, waddya know, EAC every time!
If I can tell this on my limited ripping hardware, I am not surprised others have been getting excited when improving/tweaking the hardware as well.
It's obvious that there is a lot of mileage here. The only result that comes out negative is that the original CD still sounds better via the Hifi setup. If the guys here, with better PC setups than the basic stuff I'm using, claim they can improve on the orgininal disc, I won't argue based on the obove findings.
