Post by Spirit on Aug 10, 2009 5:30:56 GMT
Ripping machine will have sata optical drive, yes. Audio will then be stored on SSD [on playback machine]. Movies I'll just stream over ethernet.
You cite an old example where the designers disputed your findings... I'm assuming there are (now) widely accepted logical explanations for the resultant difference in sound...
I think Robert's viewpoint is perfectly reasonable. If the 1s and 0s are identical, [as identical checksums would suggest...] why should they sound any different?
I couldn't pick any audible differences between the two blu-spec cds. Perhaps I'll have more chance of hearing the differences others seem to be when I build a buffalo.
Post by Deleted on Aug 10, 2009 6:33:36 GMT
Phil No, the differences are still unexplained. They didn't show up on some measurements that were done recently by Jeremy with the SCULD build in DIYAudio. Alex
Post by robertkd on Aug 10, 2009 9:07:36 GMT
Alex,
to clarify a point I said bit perfect, whilst checksums are quick and fairly accurate they are not totally accurate however the chances of 2 or more errors over the data block giving the same value are extraordinarily low.
I did however specify at the "binary level" as in a bitwise comparison of the data files, but as explained above the checksum method is a reasonable enough assurance that the files are indeed identical.
Robert
jkeny
Post by jkeny on Aug 10, 2009 9:18:23 GMT
Robert, Why don't you do a binary Diff check to ensure thay are identical & then have a listen?
Post by leo on Aug 10, 2009 13:53:12 GMT
I heard the difference using the crappy pc sound card going into the Headphone amp driving HD250 II's, the difference in the main speaker system using the dac is more clear Placebo effect doesn't work with me, it either sounds different or it don't, in this case for me it sounded different , sometimes you just have to keep an open mind
Post by leo on Aug 10, 2009 13:57:42 GMT
P.S. I intend uploading anther 24/192 track for evaluation purposes only,if there is any interest. I believe that it will sound markedly superior to what you hear from the majority of SACD/DVD-A players. I had in mind track 6 from a famous "Eagles" album That would be very interesting! I have that album, its one of those things which really wakes the Sabre up, can't imagine it sounding even better than it does now
Post by robertkd on Aug 10, 2009 13:59:02 GMT
Sorry Robertkd, I don't understand what you are saying here - can you elaborate? The problem I have with all of digital is that it is an abstraction of reality & requires a lot of technical/mathematical expertise to know how well that abstraction represents reality. I don't have this expertise & my simplistic mind tells me that with magnetoresistance disk heads, NZRI encoding, Reed-Solomon error correction, etc that there are a lot of opportunities for the precious audio signal to be corrupted. Well here's the thing reed-solomon, 8-14 modulation, data interlacing and so forth are all designed to protect the integrity of the data carried on a CD DA, the point I was making is that for each byte of data that makes up the information has actually been interpreted form encoded information from the data stream from the optical block. That is after processing data from the optical block and decoding and removal of other system information the actual 8bits is a resultant of a look up table, the same goes for each and every 8bit byte that is output for subsequent A to D (whether presented serial or parallel) that's a different issue data is buffered in RAM form a disk read e.g. from disk cache, to system memory and usually buffered in system RAM by OS services as well as by the application. You may note the disk activity light flashes momentary this indicates the data is buffered. (it's such a slow data rate for most systems) well for data it is black and white rather one's and zero's for example the instructions that make up a computer program are precise instructions that is near enough ain't good enough, e.g. the instruction to push a data value to the stack is not the same as and-ing the data items in 2 of the CPU registers. as for variation on the voltage levels all this is taken care of by the chip interfaces and data error detection and correction mechanisms. not really the analogue material was digitised at the source assuming after post production and processing this "data" is then encoded and used to make a CD DA (process of making glass masters and stampers &etc) the system CD DA reader and decoding including any error detection/correction is designed to deliver this "data" after all the same process is used in CD Data with minor variations including data block length what happens to this data after it is delivered may well be another story (rave mode off ) Robert some basic info makbit.com/articles/cd-overview.pdf
jkeny
Post by jkeny on Aug 10, 2009 15:11:32 GMT
I had a long reply ready for sending but I re-read your post and realised that addressing each point would only dig us deeper into the digital mire.
So let me summarise my position - I agree I don't know how a bit perfect copy of audio data can sound different to another bit perfect copy of the same data given all other factors being equal. I could envisage it if the timing of the data was also recorded but this is not the case. So I remain open minded about this & believe those that experience this difference & look forward to testing this myself.
My first stab at the mechanisms that might be at play here are that the digitised data is different from one another in a way that doesn't effect it's bit perfectness. What? There's a certain agreed tolerance to the voltages that represent a 1 and a 0. What if one file was recorded and some of the bits were at the very edge of this tolerance. The other file was recorded with all bits right in the middle of the tolerance range. Would the playback of the first file (remember we are now involved in a D/A conversion & timing is crucial) involve a different electrical melee then the playback of the second file? Would this not change the playback?
One thing I'm sure of is that audio reproduction is an exquisitely sensitive process which, in digital form, consists of both data & timing. The ear's sensitivity to this timing has gradually been revealed to be far greater than was originally envisaged.
So my issues about the PC as a HiFi music player is that there is so much going on inside the PC box which can ultimately effect the D/A timing. I don't believe we have identified all those issues yet.
So maybe this is the point - the ear/brain or more correctly, psychoacoustics & how we perceive sounds nuances is still not fully understood and we can't just say that if it can't be measured, it can't be perceived because patently this is ultimately an unscientific stance even though we might think science supports it. The underlying premise of all science is that we are using the best theory at the moment but it's only a theory about reality & not reality itself!
Post by Deleted on Aug 10, 2009 21:29:15 GMT
Leo You should receive an email from filemail in around 21/2 hours time. If anybody not on the list of usual suspects would like to download this fabulous 24/192 track for evaluation, please PM me and I will provide a download link. Alex
Post by PinkFloyd on Aug 10, 2009 22:04:05 GMT
I had a long reply ready for sending but I re-read your post and realised that addressing each point would only dig us deeper into the digital mire. So let me summarise my position - I agree I don't know how a bit perfect copy of audio data can sound different to another bit perfect copy of the same data given all other factors being equal. I could envisage it if the timing of the data was also recorded but this is not the case. So I remain open minded about this & believe those that experience this difference & look forward to testing this myself. My first stab at the mechanisms that might be at play here are that the digitised data is different from one another in a way that doesn't effect it's bit perfectness. What? There's a certain agreed tolerance to the voltages that represent a 1 and a 0. What if one file was recorded and some of the bits were at the very edge of this tolerance. The other file was recorded with all bits right in the middle of the tolerance range. Would the playback of the first file (remember we are now involved in a D/A conversion & timing is crucial) involve a different electrical melee then the playback of the second file? Would this not change the playback? One thing I'm sure of is that audio reproduction is an exquisitely sensitive process which, in digital form, consists of both data & timing. The ear's sensitivity to this timing has gradually been revealed to be far greater than was originally envisaged. So my issues about the PC as a HiFi music player is that there is so much going on inside the PC box which can ultimately effect the D/A timing. I don't believe we have identified all those issues yet. So maybe this is the point - the ear/brain or more correctly, psychoacoustics & how we perceive sounds nuances is still not fully understood and we can't just say that if it can't be measured, it can't be perceived because patently this is ultimately an unscientific stance even though we might think science supports it. The underlying premise of all science is that we are using the best theory at the moment but it's only a theory about reality & not reality itself! Nice post
jkeny
Post by jkeny on Aug 10, 2009 22:41:06 GMT
Thanks Can I ask what setting I use to get auto-email notification when I'm PMed? Looked all through my profile but can't see any relevant field.
Post by Deleted on Aug 10, 2009 22:48:21 GMT
Thanks Can I ask what setting I use to get auto-email notification when I'm PMed? Looked all through my profile but can't see any relevant field. Mike Perhaps I forgot to take my "smart pill" , because I couldn't work it out either, BUT I do get auto notification of waiting PMs. How do other members enable this facility ? Alex
jkeny
Post by jkeny on Aug 10, 2009 22:54:43 GMT
Thanks Alex, is it because I've <100 posts?
Just a noob who knows Jack Schitt
Edit: another thing not working for me - signatures - I just put one on my profile but this is all that appears
Post by robertkd on Aug 11, 2009 6:08:36 GMT
I had a long reply ready for sending but I re-read your post and realised that addressing each point would only dig us deeper into the digital mire. c'mon in the mire is great perhaps timing, related to clock accuracy/jitter certainly will have an effect on playing the CD directly, agreed. However the way I see it for ripping, the data structure of a CD DA is defined so time relationship is defined as in, the data "sample" location within the data structure is fixed. That is the ordinal position of a sample is known so we can rip at almost any speed and reassemble the the data in it's correct location not an issue. This makes it possible to read a CD DA or CD D (CD Rom) at greater then *1 except we're talking a wave file that contains PCM data, and data is either correct or it's not there is no in between it was either decoded and assembled into a .wav file correctly or it wasn't. ( I am assuming it's uncompressed PCM, either way the files are identical,.. ) acquisition and presentation sure, within a digital system sample n is sample n time is meaningless,... which still leaves acquisition and presentation where type/make and implementation of ADC and DAC, clock accuracy, jitter, sample rate conversion, bit depth conversion, to dither or not to dither and so forth all make a difference. yes and no, really depends on implementation and hardware. true psychoacoustics is an interesting subject, the human auditory faculity is also the most unreliable and inconsistent faculty we have Robert
Post by PinkFloyd on Aug 11, 2009 6:49:28 GMT
Thanks Can I ask what setting I use to get auto-email notification when I'm PMed? Looked all through my profile but can't see any relevant field. I don't know to be honest, I'll have a look under the bonnet and see if I can work it out
jkeny
Post by jkeny on Aug 11, 2009 14:12:28 GMT
Robert, My last post on this: Do you then agree that there is a situation whereby the playback of one recording can cause more system effort than the playback of another recording i.e different CD copies of the same source?
If you do then just change the substrate/media on which the recording is done & we have the same situation for HDD, BR, DVD, SDD?
If you do then is'nt it feasible that these sound different even though they are considered digital facsimile?
Don't tell me that the data is first read off disk into a buffer & therefore the original state in which it is stored is irrelevant. Because in that argument your binary mindset is blinding you to the blindingly obvious - while the system is playing back from the buffer it may well be trying to read (with difficulty) the next block into the buffer. The buffer is part of the machine & so one part of the machine affects another.
I Said And you said
You are still assuming that every bit is recorded at exactly the same voltage level, pit depth, etc which would be a miracle! So there is a tolerance range built into the system. So see my argument above!
Post by robertkd on Aug 11, 2009 14:45:32 GMT
Robert, My last post on this: Do you then agree that there is a situation whereby the playback of one recording can cause more system effort than the playback of another recording i.e different CD copies of the same source? If you do then just change the substrate/media on which the recording is done & we have the same situation for HDD, BR, DVD, SDD? If you do then is'nt it feasible that these sound different even though they are considered digital facsimile? Don't tell me that the data is first read off disk into a buffer & therefore the state in which it is stored is irrelevant. Because in that argument your focus is blinding you to the blindingly obvious - while the system is playing back from the buffer it may well be trying to read (with difficulty) the next block into the buffer. The buffer is part of the machine & so one part of the machine affects another. well depends, the buffer implementation should allow data to be written in as well as read out simultaneously much as any iostream ios::foobar implementation. but the actual level of a "one" is irrelevant as long as the level conforms to the interface requirement i.e. above the threshold to be considered a "one" then it doesn't matter. Nor could these propagate in digital systems otherwise computers just wouldn't work. if an interface be it gate, latch buss i/o presented logic levels that didn't conform then it is faulty simple as. if and that is if there is an explanation i'm not thinking it's here, but contrary i do have an open mind,... i simply don't believe in magic Robert
jkeny
Post by jkeny on Aug 11, 2009 15:07:41 GMT
I know I said it was my last post but Again you're failing to get the point because of thinking of just data - I'm not saying the bit isn't correctly interpreted (it's bit perfect) but that it takes more system effort to do so (because it's "badly" recorded). This additional system effort, if occurring while the system is playing back audio will effect it. So, in this case, audio is different to data because it has a very high requirement for correct timing during recording & playback & this has to be factored into the whole picture.
jkeny
Post by jkeny on Aug 11, 2009 15:12:44 GMT
This doesn't answer any of the points I raised - let's take it slowly: Do you agree that there is a situation whereby the playback of one recording can cause more system effort than the playback of another recording i.e different CD copies of the same source?
Can you answer this question?
jkeny
Post by jkeny on Aug 11, 2009 15:16:06 GMT
None of what I'm saying is magic - are you suggesting it is?
Post by Deleted on Aug 11, 2009 21:57:03 GMT
Thousands of people in various forums have modified their CD and DVD players, or had them modified for them by specialist organisations. Part of every modification is the improvement by various means of chassis and transport dampening. Even the highly respected names in the industry like Marantz etc. , offer models with chassis constructed using different types of metal etc.("honeycomb" etc.) to reduce vibration and resonances,and far better quality transport mechanisms . Most people would be aware of not only an improvement in Analogue Output, but an improvement in SQ via SPDIF and HDMI with these upmarket and modified machines. Is this magic too ? Are the binary bits output from these machines different to what they were before modification when playing the same material ? Does anybody except perhaps Robert ,seriously believe that you can take the SPDIF OUTPUT from the cheapest and nastiest CD player available, most likely not even using a transformer at the SPDIF output,and expect a PC to miraculously transform its extracted .wav files into the absolute sound equivalent of an upmarket Marantz or Wadia etc. ? That would indeed be magic.
Post by leo on Aug 11, 2009 22:18:18 GMT
Come on Bob, just try the bloody thing Its got to waste less time than these continued posts why it shouldn't make a difference, if you try it and hear no difference thats fair enough
jkeny
Post by jkeny on Aug 11, 2009 22:23:18 GMT
I agree, you're a self proclaimed open-minded guy - what's stopping you from giving it a try?
Post by PinkFloyd on Aug 11, 2009 22:32:58 GMT
Anyone tried a strip of rainbow foil on the drive?
jkeny
Post by jkeny on Aug 11, 2009 22:41:44 GMT
Ah now come on, we all know it wont work - unless it's carefully placed over the word "disc" on the CD - I looked it up for confirmation
