Post by maggotbrain on Jan 7, 2009 11:51:32 GMT
Post by Deleted on Jan 7, 2009 12:07:56 GMT
maggotbrain Have you had a good read of the user's manual ? The specs say 1-20V at 0-5Amps. You should be able to set a user defined maximum current at, for example 1 Amp, or as high as 5A, depending on the actual output voltage setting. Perhaps the bass previously was artificial, and not accurate ?
SandyK.
Post by leo on Jan 7, 2009 13:45:08 GMT
The Beresford uses a couple of high capacitance caps on the input before its internal regulation, depending what output the bench psu uses it may not go well with it
Also added colouration especially from smps's can seem like more bass
Post by maggotbrain on Jan 7, 2009 14:29:33 GMT
Hello and my sincerest thanks. I've spent the last hour trying to sort this out. I've read & re-read the instructions. I've also checked technical defintions (online) to ensure that i've followed the instructions precisely. Its frying my maggots and they are not happy. Even the bespectacled bearded gurus at maplin could not help. Im now drinking beer and listening to musak style jazz in an attempt to stay smooth. I think this psu is defective. It sounds GREAT, but 100mah is way short. Stan Beresford advised the current should be 500mah.
Im not happy, but strangely am happy (damm musak). Im going to take this psu back to maplin and engage in warfare till this is resolved.
Perhaps the bass sounds light as its much more cleaner and clearer i.e less boomy?
My thanks again.
Gavin.
