Post by pmac on Dec 10, 2008 15:55:33 GMT
Hi,
First post and all that.........
I have my X-CANS v3 connected via the tape output loop from my Tri-Vista 300 amp. I was wondering if it was possible to put my X-10 v3 buffer in between. Have any of you tried this? If so,
Will it work without damaging anything?
Does it have any sonic benefits?
I will be interested in your views. I`m not that technically minded, so I am reluctant to try this without advice!
Post by dejanm on Dec 11, 2008 8:19:00 GMT
Hi, First post and all that......... I have my X-CANS v3 connected via the tape output loop from my Tri-Vista 300 amp. I was wondering if it was possible to put my X-10 v3 buffer in between. Have any of you tried this? If so, Will it work without damaging anything? Does it have any sonic benefits? I will be interested in your views. I`m not that technically minded, so I am reluctant to try this without advice! Yes, it will work without damaging anything. Try by yourself with and without this buffer and then you will see what suits you better ...
Post by pmac on Dec 11, 2008 8:37:52 GMT
I always intended to try it and make my own mind up, just wanted to be sure that I wouldn`t blow anything up! I have used the X-10 between the CD and amp, but it is now redundant as I use a Tri-Vista DAC (which apparently has the same output stage as the X-10). Really, I was just wondering if it would have any effect at all between the amp and the X-Can. I`ll try it at the weekend and let you know what I think. Maybe I`ll also try it between my X-LPS and the amp as well, don`t know if that will do anything, but I`ll soon know! Thanks for the advice, it is good to know there are other MF fans/users out there (I would have been slaughtered by the MF bashers for this on some forums I could think of!!!)
