TRMS Autoranging Multimeter with USB...
Nov 7, 2008 15:17:52 GMT
Post by insomniac on Nov 7, 2008 15:17:52 GMT
True RMS Autoranging Multimeter with USB PC Interface
I picked up one of these from Maplin for £29.99 normally £59.99.
They are running this offer until 24/12/2008 - Order Code: N56FU
Just a heads-up for anyone looking to buy or replace one atm.
Product Features:
* True RMS
* Autoranging
* USB PC interface and software
* Large 6000 count LCD with analogue bar
* Blue backlight
* AC/DC voltage and current
* Resistance, frequency, capacitance, temperature, transistor, diode, duty cycle and continuity
* Relative mode
* Data hold
* Auto power off
* CAT III 600V CAT II 1000V
Technical Specification
Specifications:
Basic functions: Range Best Accuracy
DC voltage: 60mV/600mV ±0.5%
° 6V/60V/600V/1000V ±0.8%
AC voltage: 60mV/600mV ±1.0%
6V/60V/600V/750V ±1.2%
DC current: 600µA/6000µA, 60mA/600mA ±1.2%
6A/20A ±1.5%
AC current: 600µA/6000µA, 60mA/600mA ±1.5%
6A/20A ±2.0%
Resistance: 600Ω, 6kΩ, 60kΩ, 600kΩ, 6MΩ ±1.0%
60MΩ ±1.5%
Capacitance: 4nF, 40nF ±2.0%
400nF ±0.5%
4µF ±1.0%
40µF ±1.5%
400µF, 4000µF(30 sec) ±2.0%
Frequency: 9.999Hz,99.99Hz,999.9Hz,9.999kHz,99.99kHz,999.9kHz, 9.999MHz ±1.0%
Temperature: -20 to 1000°C
Continuity: in 600Ω range. Buzzer sounds < 30Ω
Duty cycle: 0.1%~99.9%
Max.displayed value: 6000(frequency: 9999), with analog bar (61 segments)
Sampling rate: 3 times/sec, (30 times/sec for analog bar)
Range exchange: autoranging/manual
Polarity indication: automatic
Data output: RS232(2400bps)
Auto power off: after 30 minutes (this function can be disabled)
Power: 9V battery, order code: L46AL
Dimensions: 86(w) x 180(l) x 44(d) mm
Weight: 380g (with battery)
Includes: Test leads
Temperature probe
Battery
Holster
User''s manual
USB cable
Software
Transistor test/K-type probe adaptor
It looks much better and sleeker with the blue rubber protective cover removed. Not too bad for under thirty quid....time to charge the laptop
Edited to remove monster size image...with IE...Firefox/3.0.1 does not like the Modify post button
Product Features:
* True RMS
* Autoranging
* Blue backlight
* Relative mode
* Data hold
* Auto power off
Specifications:
6A/20A ±1.5%
6A/20A ±2.0%
60MΩ ±1.5%
400nF ±0.5%
4µF ±1.0%
40µF ±1.5%
Temperature probe
Battery
Holster
User''s manual
USB cable
Software
