Post by dotnet on Jul 3, 2008 15:30:08 GMT
So, it turns out the 702 is the same as the 701, but in blue and with a detachable cord. Fair enough, and it seems the 701 will continue to be made. I kind of liked the white-gray design of the 701, but the new blue looks cool. The detachable cord will make cable modding/swapping a lot easier. www.akg.com/site/press_center/powerslave,id,163,nodeid,0,_language,EN,nodeid,33.html Cheers Steffen.
Post by FritzS on Jul 3, 2008 16:09:19 GMT
So, it turns out the 702 is the same as the 701, but in blue and with a detachable cord. Fair enough, and it seems the 701 will continue to be made. I kind of liked the white-gray design of the 701, but the new blue looks cool. The detachable cord will make cable modding/swapping a lot easier. www.akg.com/site/press_center/powerslave,id,163,nodeid,0,_language,EN,nodeid,33.html Cheers Steffen. As AKG fan (and I live in Austria, near Vienna; the AKG manufactory are in Vienna) - I hope I can hear one soon AKG tells me - the K701 are for consumer - but some audio professional use them - so the K702 created for professional user.
insomniac
Team Zopiclone
Post by insomniac on Jul 3, 2008 21:10:50 GMT
I like the look of those. Hopefully the three pin plug on the cable is a standard easily available type.
Anybody know the euro price tag on the 702?
Post by merton on Jul 4, 2008 4:31:58 GMT
the new one has a superior color.
toad
Post by toad on Jul 12, 2008 7:02:33 GMT
the new one has a superior color. Yeah but you won't look like a Cyberman in a pair of the blue ones ;D
How do I activate my account?
Post by pagan on Jul 12, 2008 8:06:45 GMT
Hopefully the three pin plug on the cable is a standard easily available type. 3 pin plug.... Looks like XLR
Post by pagan on Jul 13, 2008 0:46:12 GMT
3 pin plug.... Looks like XLR I wish! they are using a common ground. I wished that AKG would stop the practice of using the frame to carry the common ground from the side to side. When I re-cabled my K501 I asked for dual side entry which is not ergonomically the nicest but it was the most elegant way to avoid the frame to carry the ground. Not having tried the AKG's myself... The frame is metal and is being used as the ground? The two frame rails must be hollow to run the + to the other side. are they?
Post by pagan on Jul 13, 2008 3:26:56 GMT
Yes the rail is hollow and the wire is inside. Both rails are hollow? One rail has a wire inside already, probably the + for the speaker. Is the other rail hollow? And it doesn't use a wire inside, just the rail is used for ground? If both rails are hollow, and they use a XLR plug. you could rewire the headphones for single wire in each rail. the XLR plugs are available in 3, 4, or 5 pin arrangements. www.altronics.com.au/index.asp?area=srch&search=xlr&option=and&list=0&pg=7&sort=code
Post by rickcr42 on Jul 14, 2008 0:13:38 GMT
probably not but just maybe a real good shot at "Cider" man ?
