Post by dhoggan on May 5, 2007 10:23:53 GMT
I was just sitting down to start modding the amp board on my v2 when I had a bit(!) of an accidnet. I was disconnecting the cable that connects the amp board to the PSU board when the black cables came away from the connector at the PSU board end. So now I have a real problem: which black cable goes into which pin of the connector?
Can someone help out? I guess the best way would be to look at SK2 on the amp board and considering the red connector to be pin 1, measure the continuity of each black cable to the PSU connector. My guess is it's simply a case of pin 2 - pin 2, pin 3 to pin 3 etc, but don't want to risk mis-wiring it..
Any help greataly appreciated!
Dave
Post by dhoggan on May 5, 2007 17:07:15 GMT
Yes, that's the one.
Actually, in the end I took an educated guess and assumed that the designers mapped the pins of the connector on a like-for-like basis. It seems to work - at least no smoke so far :-)
Thanks again,
Dave
