Post by Deleted on Apr 9, 2007 15:12:00 GMT
I've just finished a lot of the X-can V3 mods, including new valves. I'm really delighted with the transformation. With my HD650s all the 'soft base' is away and much cleaner sound. But the final recommendation is to remove the 10uf capacitors if no DC offset is present in my output device. I have Musical Fidelity A3 and Bi-amp A308CR amps. How do I tell if they have Dc offset or not?
thanks
Post by PinkFloyd on Apr 9, 2007 19:23:37 GMT
I've just finished a lot of the X-can V3 mods, including new valves. I'm really delighted with the transformation. With my HD650s all the 'soft base' is away and much cleaner sound. But the final recommendation is to remove the 10uf capacitors if no DC offset is present in my output device. I have Musical Fidelity A3 and Bi-amp A308CR amps. How do I tell if they have Dc offset or not? thanks The other MF gear you mention will almost certainly have output caps fitted so safe to remove the 10uF input caps from the V3. Check like this but probe the outputs of the equipment to be connected to the V3 input (ie probe each channel between ground and signal) see here: www.rock-grotto.co.uk/dcoffset.htm
