How do I activate my account?
Post by pagan on Feb 3, 2008 12:36:26 GMT
Leo I'll see what posts i can find
agree, never put dc servo feed back to input. no good.
The pcm1794 is hard to implement. That was one of Jocko Homo's comments also well worth it when done right. There is some clues referenced to in "Simple I/V Converter". but Jocko only gave clues, for others to nut out. rboer did about the most work on it.
I havn't had a current output dac to play with yet so i didn't investigate to much.
Probably will be the next dac though.
Post by leo on Feb 3, 2008 12:44:20 GMT
Thanks Allan, from what I've been hearing from this dac so far, it is capable of producing excellent sound, I have the clock,regulation etc sorted out, its just the output stage that needs working on
I've not tried the Opus but have had access to play about with a couple of the newer Arcam cdp's which use the same chip but its not really fair to make a judgement going by those
BTW I did try Jocko's simple I/V stage with a different current output dac , I've not used it with the PCM yet
Post by pagan on Feb 4, 2008 8:18:03 GMT
BTW I did try Jocko's simple I/V stage with a different current output dac , I've not used it with the PCM yet Rboer's version?
Post by leo on Feb 4, 2008 9:36:24 GMT
BTW I did try Jocko's simple I/V stage with a different current output dac , I've not used it with the PCM yet Rboer's version? It was the simple version, I'll find the link and post it
Post by pagan on Feb 4, 2008 10:06:03 GMT
Leo I was reading some stuff on the pcm1794's and it was about the dac likes to drive a low impedance. referring to lower than 1k Rboers dac input impedance is about 3k3?
Post by Deleted on Feb 4, 2008 10:20:11 GMT
Allan TI application notes show it with an opamp feedback resistor of 750 (or 820) ohms and 2200pf in parallel. Alex
Post by pagan on Feb 5, 2008 9:48:27 GMT
Alex Whats the output impedance 20-20k?
Post by Deleted on Feb 5, 2008 11:01:11 GMT
Allan Doesn't appear to be stated. The attached may be of interest, as you can then work out what happens with those previously mentioned FB resistors. Alex
APPLICATION CIRCUIT The design of the application circuit is very important in order to actually realize the high S/N ratio of which the PCM1794 is capable. This is because noise and distortion that are generated in an application circuit are not negligible. In the circuit of Figure 24, the output level is 2 V RMS, and 127 dB S/N is achieved. The circuit of Figure 25 can realize the highest performance. In this case the output level is set to 4.5 V RMS and 129 dB S/N is achieved (stereo mode). In monaural mode, if the output of the L-channel and R-channel is used as a balanced output, 132 dB S/N is achieved (see Figure 26). I/V Section The current of the PCM1794 on each of the output pins (IOUTL+, IOUTL–, IOUTR+, IOUTR–) is 7.8 mA p-p at 0 dB (full scale). The voltage output level of the I/V converter (Vi) is given by following equation: Vi = 7.8 mA p–p × Rf (Rf : feedback resistance of I/V converter) An NE5534 operational amplifier is recommended for the I/V circuit to obtain the specified performance. Dynamic performance such as the gain bandwidth, settling time, and slew rate of the operational amplifier affects the audio dynamic performance of the I/V section. Differential Section The PCM1794 voltage outputs are followed by differential amplifier stages, which sum the differential signals for each channel, creating a single-ended I/V op-amp output. In addition, the differential amplifiers provide a low-pass filter function. The operational amplifier recommended for the differential circuit is the Linear Technology LT1028, because its input noise is low.
Post by leo on Feb 6, 2008 22:03:35 GMT
I like the look of this one, may try building a pair for each channels +/- output and then feed into the discrete differential to line out. I think the JLH would be good for this circuit www.pedjarogic.com/1541a/pdf/discrete_I-V.pdf
Post by Deleted on Feb 6, 2008 22:17:38 GMT
Leo I don't know how stable the 1.8mA (approx) from the FET would be with temperature. There may be better ways to null the DC offset. Alex
Post by leo on Feb 6, 2008 23:58:14 GMT
Yes, that nulling will drift a bit using a fet but it was mainly the active I/V stage I liked I'll redraw the circuit how I'd like to try I'm not going back to op-amps now, they sound too cruddy to my ears
Post by pagan on Feb 8, 2008 11:36:57 GMT
Yes, that nulling will drift a bit using a fet but it was mainly the active I/V stage I liked I'll redraw the circuit how I'd like to try I'm not going back to op-amps now, they sound too cruddy to my ears Leo Once you go discrete............... it's hard to go back..
Post by leo on Feb 8, 2008 14:31:32 GMT
I've got some free time today so making the most of it
Post by ryssen on Jul 18, 2010 2:01:02 GMT
Wondering how large the outputsignal is in the schema in post 1?
Post by leo on Jul 18, 2010 9:34:33 GMT
Just alter the pair of lower resistors on the differential input transistors to change the amplification
I no longer have the dac I used this output stage with
Post by leo on Jul 18, 2010 9:43:31 GMT
Its very quiet on the forum lately, nobody else done any projects or whatever they want to share ?
Post by Deleted on Jul 18, 2010 9:55:27 GMT
Its very quiet on the forum lately, nobody else done any projects or whatever they want to share ? Leo Hopefully, Jeff and Will will soon have further to report with their SC DACs. Will has been a bit preoccupied with JLHs, and should soon be able to fit another one of them to his SC DAC now that he has changed to the simpler filtering ,and LME49710HAs.Jeff intends fitting another PSU PCB as work load permits. Alex
Post by Deleted on Jul 18, 2010 10:10:27 GMT
Alex,
Could you clarify please, I'm not up to speed with this, unless you mean the "crickets", in which case they are next-up, time permitting.
Thanks,
Chris
Post by Deleted on Jul 18, 2010 10:25:11 GMT
Alex, Could you clarify please, I'm not up to speed with this, unless you mean the "crickets", in which case they are next-up, time permitting. Thanks, Chris Hi Chris I mean the change of components on the Output PCB to the simpler circuit used by the PCM1792. It involved changing a few components, and even removing a few capacitors also. The changes were given in the "Tweaks" thread. Alex
Post by Deleted on Jul 18, 2010 10:35:07 GMT
Oh! Thanks Alex, I'm nearly there on that one. Chris
Post by pagan on Jul 18, 2010 11:29:57 GMT
I decided to knock this output stage to try with my diy based PCM1794 I just need to tweak the gain by altering the 330R resistors as its a bit high output. Results took me by surprise, where the hell did that bass come from!!! Any comments on what I should try or change? sorry the schematic is a bit rough, it was quickly done also a bit small but is the largest I can post This can also be used for the DSD1796 in the SC DAC. Leo Did you try the input CFP?
Post by Deleted on Jul 18, 2010 11:47:51 GMT
Allan
I can think of at least 4 good reasons why not. 1. Lack of a PCB. 2.FETs should be matched for best results. 3.Output coupling capacitor, not a low impedance direct coupled output. 4. Insufficient filtering could cause problems with some amplifiers. Anyway, it would need to be damn good to beat the current I.C. combination, especially with LME49710HA at the output. Alex
Post by leo on Jul 18, 2010 12:30:13 GMT
You could even configure IVYIII with the SC dac if you was bored OPA1632 is extremely good for a dac with differential output . I certainly agree with the idea of going with the pcm1792 output stage, it looks loads better than the that config used with the stock SC dac, I've not heard it myself but imagine the improvement you get with altering to the PCM1792 values would be quite noticeable sonically
Post by leo on Jul 18, 2010 12:37:51 GMT
I decided to knock this output stage to try with my diy based PCM1794 I just need to tweak the gain by altering the 330R resistors as its a bit high output. Results took me by surprise, where the hell did that bass come from!!! Any comments on what I should try or change? sorry the schematic is a bit rough, it was quickly done also a bit small but is the largest I can post This can also be used for the DSD1796 in the SC DAC. Leo Did you try the input CFP? Hi Alan, No, I'd got rid of that dac before the CFP idea was posted, I might knock another one of these stages up and try it with the Sabre, just for the laugh of course If I do I'll try the CFP, I did try the CFP with the Monica3 dacs output stage and noticed it brought an improvement in high frequency detail We can use transistors or jfets in this stage, anybody building one should compare both
Post by Will on Jul 18, 2010 21:37:50 GMT
Will has been a bit preoccupied with JLHs... That should read 'preoccupied with the chuffing, sodding JLH's CL section' Nevermind, it'll all come good in the end. One of the other things that I've been playing with is this design, which I hope to test at the end of August/September, known as Will's Super-Duper Sabre Dac Born out of the need for an easily had I2S signal.
