Post by Deleted on Jan 23, 2008 22:27:24 GMT
Leo Quite likely, but as it's only an emitter follower (if bipolar) the audible improvement may be hard to pick, compared to what you have already achieved! ;D Alex
Post by leo on Jan 23, 2008 22:41:14 GMT
Maybe I should try a valve stage, get Miguel interested
How do I activate my account?
Post by pagan on Jan 25, 2008 13:25:21 GMT
Post by leo on Jan 25, 2008 16:12:15 GMT
Thanks for those, I'll have a read now
Post by jonclancy on Jan 26, 2008 23:20:04 GMT
Maybe I should try a valve stage, get Miguel interested Lampization? ;D
Post by leo on Jan 28, 2008 20:06:46 GMT
Maybe I should try a valve stage, get Miguel interested Lampization? ;D It did cross my mind
Post by pagan on Jan 29, 2008 10:49:14 GMT
Lampization? ;D It did cross my mind "Lampization" Does this mean valve? If yes. Just use Fet's and increase 2nd harmonic untill it sounds like a valve. At least you can do it at 1/10 of the voltage
Post by leo on Jan 29, 2008 21:28:30 GMT
It did cross my mind "Lampization" Does this mean valve? If yes. Just use Fet's and increase 2nd harmonic untill it sounds like a valve. At least you can do it at 1/10 of the voltage Sorry Allan, I was just having a little joke, people who know me already know I've tried a valve output stage in one of the TDA1541A based dacs I built a while ago, its not really the sort of sound I want now although back then it was interesting to try it out
Post by Deleted on Jan 30, 2008 0:44:45 GMT
Post by leo on Feb 2, 2008 14:30:51 GMT
Decided to have a look at two totally different dacs outputs on the scope, signal used was a 1k 0dBFS Square wave cd Notice the pre- post ringing on the second one
Post by pagan on Feb 3, 2008 4:21:40 GMT
Post by pagan on Feb 3, 2008 4:26:53 GMT
"Lampization" Does this mean valve? If yes. Just use Fet's and increase 2nd harmonic untill it sounds like a valve. At least you can do it at 1/10 of the voltage Sorry Allan, I was just having a little joke, people who know me already know I've tried a valve output stage in one of the TDA1541A based dacs I built a while ago, its not really the sort of sound I want now although back then it was interesting to try it out A while ago, ay, valves, ay. what turn of the century? SandyK, remembers I know, I Know delayed responce, but better late than never
Post by leo on Feb 3, 2008 11:28:53 GMT
Sorry Allan, I was just having a little joke, people who know me already know I've tried a valve output stage in one of the TDA1541A based dacs I built a while ago, its not really the sort of sound I want now although back then it was interesting to try it out A while ago, ay, valves, ay. what turn of the century? SandyK, remembers I know, I Know delayed responce, but better late than never Heres parts of one I was making, the sound was actually not bad at all, I may do something else valve based a little later for the laugh
Post by leo on Feb 3, 2008 11:30:18 GMT
Interesting, looking at the schematic it appears it can be set for voltage out dacs and current output
Post by pagan on Feb 3, 2008 11:40:20 GMT
Interesting, looking at the schematic it appears it can be set for voltage out dacs and current output Leo I'm using one at present on a voltage output dac, wm8740 dual diff. Solder the bubbles to set for either voltage out dac or current dac. also either balanced or single ended inputs. No caps on in or out, think it uses a servo. also onboard reg. It's a pain in the but dam things nearly all SMT
Post by pagan on Feb 3, 2008 11:43:16 GMT
Decided to have a look at two totally different dacs outputs on the scope, signal used was a 1k 0dBFS Square wave cd Notice the pre- post ringing on the second one If thats input signal and output signal it's not good
Post by leo on Feb 3, 2008 11:44:09 GMT
I can't see any servo on the schematic, so what sort of price do these things cost? not cheap I'd imagine. I could do a layout for through hole but its going to be big, could try SMD but they are always a pain in the arse to etch out yourself
Post by leo on Feb 3, 2008 11:46:14 GMT
Decided to have a look at two totally different dacs outputs on the scope, signal used was a 1k 0dBFS Square wave cd Notice the pre- post ringing on the second one If thats input signal and output signal it's not good You tried looking at yours? you'd be surprised what OS does The first pic is the output of the AYA, perfectly flat, not bad for the ye old TDA1541A
Post by pagan on Feb 3, 2008 11:47:23 GMT
Leo the TDA1541A just sound very musical, seems to be a character of the dac. Add a tube (personal preference) for flavor. Hee Hee Like adding salt into the wound
Post by leo on Feb 3, 2008 11:48:24 GMT
The second one if of the PCM dac with its OS and upsampling
Post by leo on Feb 3, 2008 11:49:12 GMT
Do you have a scope Allan?
Post by Deleted on Feb 3, 2008 11:56:28 GMT
Allan The CRO photos were the outputs of 2 different DACs . Leo was using a test CD. The one with the ripples was typical of earlier generation CD players.
Leo Which DACs were the outputs from, and more details please of type of DAC and technology used . Did you try both with a higher frequency test tone ? (Test disc permitting) Alex
Post by pagan on Feb 3, 2008 12:05:12 GMT
I can't see any servo on the schematic, so what sort of price do these things cost? not cheap I'd imagine. I could do a layout for through hole but its going to be big, could try SMD but they are always a pain in the arse to etch out yourself I saw another schematic or someone discussing it on diyaudio IIRC, A dc servo was mentioned, but I thought the opamp was for an onboard reg.? I'll see if I can find it. It's not cheap www.lcaudio.com/index.php?page=6but it is good, but there is always better. I use it as a reference output stage, to compare others. please no SMT, it's a pain in the but. Thought hole better, try different component easlier. I'm having enought difficulty reading normal components let alone smt. Besides someone mentioned putting a ccs in it. need to find the post again. Yes I have a scope, but an old 20Mhz one
Post by leo on Feb 3, 2008 12:08:00 GMT
The first was on the output of the AYA dac, TDA1541A S2 common base I/V output stage, it also uses compensation circuitry to deal with NOS
The second one with pre and post ringing is of the output stage of the much newer PCM dac, if I add some filtering on the dacs output it should improve things BUT adding this filtering usually hurts the sound IMHO
The PCM is the one I'm still working on, I'm only limited by the output section so far so this is something thats giving me the biggest headache I've tried the recommended circuit in the datasheet using op-amps. After trying the simple discretes I found them to have the best potential sound wise but are harder to get right
Post by leo on Feb 3, 2008 12:14:57 GMT
I can't see any servo on the schematic, so what sort of price do these things cost? not cheap I'd imagine. I could do a layout for through hole but its going to be big, could try SMD but they are always a pain in the arse to etch out yourself I saw another schematic or someone discussing it on diyaudio IIRC, A dc servo was mentioned, but I thought the opamp was for an onboard reg.? I'll see if I can find it. It's not cheap www.lcaudio.com/index.php?page=6but it is good, but there is always better. I use it as a reference output stage, to compare others. please no SMT, it's a pain in the but. Thought hole better, try different component easlier. I'm having enought difficulty reading normal components let alone smt. Besides someone mentioned putting a ccs in it. need to find the post again. If its a fet based input op-amp you can see on the board I'd imagine it will be the servo. One thing we have to watch with Servo's is where exactly they are fitted, some people inject their output into the amps input pair transistors which is a bad way IMO, it feeds the noise into the circuit and also the type of op-amp used has an influence on the sound so it solves one problem of eliminating signal DC blocking caps but adds another problem. A badly implemented servo can have more sonic signature than properly DC biased coupling caps I'll try and find a high res pic of the Zapfilter, I would like to know how things are implemented before buying such a thing
