Post by gover1 on Jun 7, 2006 18:49:29 GMT
hi, good chance for you to flext your diy audio knowledge, i brought a small six watt amplifier (prebuilt diy project) the other day, largely because i wanted to use the enlcosure for other things, however i would like to use the amp as well if possible. all the wyring seems a bit strange to me it was sold to me as an intergrated but theres no volume pot , and dont even ask about the way the rca jacks are wired, all seems very weird to me, anyway, its not working ( despite being sold as working) so i lifted up the pcb board where it says icsamp2 iss1488 , does this mean anything to anyone? im trying to find as much about it as possible in order to fix it, thnaks, for any help, mark. ps if no one has a clue i might post pictures later
Post by rickcr42 on Jun 7, 2006 19:32:08 GMT
can you identify the onboard active device (s) ?
Would be more telling than any in house pcb numbering system
Post by PinkFloyd on Jun 7, 2006 20:23:50 GMT
That would be the best idea, that way we'd have a better chance identifying it..... plus, some of the members here get turned on by PCB's (myself included) so get those pics up!
Post by gover1 on Jun 8, 2006 17:12:50 GMT
hi, heres some pictures, the problem im having at the minute: as you can see there are two set of input pins each with l,r and ov the set which were originaly in use gave no output, but the second set, when given a mono input upmix to stereo, and only the left input chanel works, therfore it acts essentially as a mono amp with two sets of speakers on however looking at the lay out i would say it has potential grater than this, if it doesnt work its not the end of the world only payed £5 and its the case i really wanted, see what u think, mark p.s, just tried to add images, cant get it to work, how you do it in this forum ?
Post by gover1 on Jun 8, 2006 19:21:37 GMT
hi , pictures probably be most usefull( still cant work out how to get them on here) but have had a look around and found a tda1521 chip and 2x ssm2018 as i say not expecting anything awsome but if i can get it to work in stereo for a bedroom system that barely gets used then it would be good, cheers for any help
Post by PinkFloyd on Jun 8, 2006 19:30:40 GMT
where's the pictures? ( URL of picture here [/img] )
Post by rickcr42 on Jun 8, 2006 20:40:05 GMT
you need to bracket the web address of the pics with the image meta tags which are bracket-img-bracket then address of the picture then bracket-slash-img-bracket (looks like this [/img])
Post by rickcr42 on Jun 8, 2006 20:41:17 GMT
BTW-if you just post the link we can still see the pictures in another window so if it works I can add the meta tag for you after
