Post by Defecitve Audio Component on Oct 11, 2020 17:57:58 GMT
Today, I got a "ringing" sound when connecting the headphone plug to the v3 (from around 2004, all as it was, except for a little pinkie psu). There is also some ringing when I move the headphone cable around. No ringing whatsoever, if daisy-chain the v3 (switched off), and use a different headphone amp (NwAvGuy O2). Any ideas what might be going on with the v3?
Post by PinkFloyd on Oct 12, 2020 11:32:09 GMT
Today, I got a "ringing" sound when connecting the headphone plug to the v3 (from around 2004, all as it was, except for a little pinkie psu). There is also some ringing when I move the headphone cable around. No ringing whatsoever, if daisy-chain the v3 (switched off), and use a different headphone amp (NwAvGuy O2). Any ideas what might be going on with the v3? Sounds like a valve (or both valves) are microphonic...... tap the amp enclosure and if you hear a ringing sound then it's 100% a failing valve. Mike.
Post by PinkFloyd on Oct 12, 2020 11:46:48 GMT
Actually...... if you've been running the same valves for 16 years it's most certainly knackered valves. The 6922 valves have an in spec lifespan of 5000 hours.
Post by Defecitve Audio Component on Oct 12, 2020 15:44:23 GMT
Thank's for the quick diagnosis! Then I'll order a new pair of Valves (hoping that you have some in stock).
Post by Defecitve Audio Component on Oct 12, 2020 19:22:07 GMT
I have sent the mail Also, there seems to be a bit of a power surge when I switch the xcan on. I have it connected to the same power strip as my monitor, and it goes dark for a second when I switch the xcan on. Is that the same issue also the tubes, or are they all like that?
Post by Defecitve Audio Component on Oct 22, 2020 20:07:13 GMT
Got the new Valves. Easy swap, Sounds great, Thanks!!
Post by Defecitve Audio Component on Oct 23, 2020 21:38:59 GMT
So if you see this thread (even if that is a few years down the line) and are on the fence here on the valve swap, just go for it. DEEPLY recommended ( perhaps if you just still have the stock valves, just swap, but then swap to these valves)
Post by PinkFloyd on Oct 24, 2020 19:58:38 GMT
Got the new Valves. Easy swap, Sounds great, Thanks!! Glad you like them Jonas....... give them a couple of hundred hours to cook and the sound will be even better Happy to help mate. Mike.
