MF X-P200 recap
Jul 16, 2020 9:16:36 GMT
Post by gotanster on Jul 16, 2020 9:16:36 GMT
With Mike’s helper support, I performed the first recap of my life: the X-10 v3 upgrade.
What can I say: both the action and the victory are swept away.
So I also looked into the X-P200 power amplifier.
Instead of the 4 Jamicon 10,000 uF 63V, Mundorf Mlytic comes with 10,000 uF 63V
Instead of the Jamicon 220uF 16V, a piece of AN Kaisei 220uF 16V arrives
Instead of 5 NP 10uF 63V, I "designed" 10uF 100Vdc Elna RBD bipolar
Instead of 2 pieces of Jamicon 100 uF 35V, 100uF 35V Elna Cerafine arrives
2 Jamicon 470 uF 35V instead of 470uF 35v Elna Cerafine arrives
Instead of 2 pieces of Jamicon Non polar 100 uF 16V, Nichicon ES type 100uF 16V arrives
And so far I have not been able to obtain these:
2 pieces of Jamicon 1uF 63V
As far as I know, Panasonic has 1uF 100V or more Volt capacitors.
Being an absolute beginner in the field, I discovered or could identify these “replaceable” parts.
Yet the pcb is also full of orange "capacitors" (for example, between fuses). What they should be replaced with, or how I can identify their "performance," "capacity," at all?
Plus there are even opamps.
I am particularly interested in the two JRC5532. With them, I plan to make it interchangeable with a DIP8 enclosure, and Burson or other delicacies can go into it.
These are long-term plans. The capacitors are coming soon (except for 1uF because I haven’t been able to get them yet).
ps:
For some reason, image upload doesn’t go here, and then I try at home.
ps:
