X-DAC v3 mods (another one)
Sept 25, 2019 11:21:00 GMT
Post by puggie on Sept 25, 2019 11:21:00 GMT
I have just bought an X-DAC V3, had a little listed (stock PSU wall wart) and it sounds pretty decent to my ears... but I believe from reading SandyK's threads there is more to come. I've had a little look under the hood and the assembly is somewhat hap hazard, caps at funky angles and the like. So my intention is to do some sound basic mods to this and not go crazy, I don't have a great listening room so frankly the point of diminishing returns will be met fairly soon. My plans are:
Build a PSU for it, 30-50VA transformer and a regulator/capacitance multiplier. Aiming for 17v rails.
Acoustically dampen the casing as I have some sound deadening.
Replace electrolytics as per the mods guide, I have a selection of Panasonic FCs and Rubycon ZLs, they are my go-to amp powersupply caps for car audio stuff.
remove the internal bridge rectifier and fit ultra fast diodes with snubbers elsewhere on the board
Replace the ceramics for Op-Amp PSU decoupling for decent film caps (Red boxy Wimas or do you have other recommendations?)
Replace the op-amps, I'm looking at the OPA1612 as I have some, Just need SOIC to DIL adapters, I may fit a decoupling cap directly across the pins under the SOIC adapter PCB, I have done this before to good effect. The jury is still out on this one, everyone has their preferences.
Further thoughts:
is there a nice drop-in replacement for the regulators on the heatsinks?
Has anyone considered the NDK NZ2520SDA Oscillators as a replacement for what is on there? I've read of the 'Vanguard' ultra low PPM gold plated oscillators being used, the NDK units seem to concentrate more on minimising phase distortion rather than just outright clock stability (although that isn't shabby either). They seem to be a new serious oscillator with Allo running them on a lot of stuff, and not stupid money. An adapter board may be required as they are SMD.
So any thoughts and suggestions? I'm going to start amassing components shortly and will update this thread with pics as I go.
Further thoughts:
