DIY Interconnects
Sept 7, 2006 1:49:54 GMT
Post by xerxes on Sept 7, 2006 1:49:54 GMT
I recently bought some silver plated copper wire with PTFE insulation from Farnell for use as hook up wire.
I thought it would be interesting to see how it sounded made up into an interconnect cabe, so here's what I came up with:
I used a similar construction to that of many of the Kimber cables with 3 plaited strands. The third strand is connected to ground at the "source" end and left free at the "amp" end. I used some Eichman Bullet plugs and the wire is a single core, 0.4mm diamater contuctor. The resultant cable is rather weedy and a litle delicate. Later I will buy some PVC tubing, something about 8mm OD with a 6mm ID will fit nicely into the opening of the Bullet plugs which have a grub screw which will hold the PVC tube secure and protect the thin conductor wires and act as a cable strain relief.
I was able to compare the cable with an set of fairly expensive Isolda DCT300 interconnects I have by connecting both outputs of my CD player with different inputs on my amplifier, so that I could do a quick A-B comparison with the remote control.
I've tried various interconnects in the past using this method and as expected the differences are quite subtle. However, I think my home made cables just about win. It seems the bass is slightly tighter with a little more "texture". The leading edge of a bass guitar seems better defined, as if you can hear the finger on the string slightly more when it's plucked. Vocals have a little more presence and there seems to be more space around individual voices and instruments.
All in all, this is a pretty good result for a wire that costs around 30 pence per metre. The most expensive thing was the Eichman Bullet plugs at around £25.00 for four. In any case a set of 1 meter interconnects will cost under £30.00, less than one tenth the price of a 1 metre pair of the Townshend cables.
Needless to say, I will not be buying any more exotic interconnect cables. In fact, I'm thinking of selling the little collection of ready made cables I have and replacing them with my own. The sale should more than pay for the additional sets of bullet plugs I will need to replace them.
