oldson
Older than a well used glove
Post by oldson on Jan 27, 2013 18:54:52 GMT
simple question- do these degrade the sound quality at all?
got 2 sources but my buffer amp has only 1 set of inputs. hence using 2 amps at the moment.
Post by pagan on Jan 28, 2013 0:16:25 GMT
Simple answer Anything extra that the signal has to go through could possibly degrade it. ie contact capacitance of the switch for one thing.. quality of switches. But then, this could/would be less than the capacitance of the interconnect.
Whether you would notice the difference is the question.
The other side of that is,, Constant unplugging/plugging interconnects will degrade their contact surfaces.
Post by Deleted on Jan 28, 2013 2:05:57 GMT
Especially if you need to use another interconnect of the same length to use it.Keep the interconnect from the switchbox to the amp as short as possible.
oldson
Post by oldson on Jan 29, 2013 19:23:38 GMT
trouble is i have 2 sources and only 1 x10-d so i guess i have no choice but to try.
Post by mrarroyo on Jan 30, 2013 10:51:27 GMT
You could buy another X10-D!
oldson
Post by oldson on Feb 2, 2013 18:51:40 GMT
You could buy another X10-D! which would then need modding! is Mike paying you comission?
Post by mrarroyo on Feb 3, 2013 11:12:29 GMT
No, but MF is!
