gsphukd
The Sultan Of Swing.
Veda-Audio
Post by gsphukd on Feb 2, 2005 1:32:47 GMT
Fantastic looking amp!! I like the reflective glossy shell and the personal touch with the serial number and autograph...looks very "chic" I also like the external heatsinks this amp sure does get warm and it can use every ounce of circulation available... Reminds me of Rudi's amps...anyone for gold plated volume knobs etc. A few chrome accents can make this thing really run away in the looks department. ninnymuggins... (just had to use that word - its from ELF...the movie )
gsphukd
Veda-Audio
Post by gsphukd on Feb 19, 2005 16:58:18 GMT
Have you received it already? Any more pics? Impressions?
Kudos to trevor for unleashing his creativity. If each piece of his is a one-off in terms of "style" and "execution" then it will be totally worth it.
gs
Post by dc on Apr 20, 2008 9:22:09 GMT
all the images in this thread are shot!
Post by Deleted on Apr 20, 2008 9:45:53 GMT
dc The thread is dated 2005 ! I delete images some time after the posts have passed out of sight. Otherwise places like Image Shack etc. will end up wanting to charge you for the extra bandwidth. Alex
Post by dc on Apr 20, 2008 12:08:09 GMT
yeah i know. i only posted here because mike pointed to it from another thread.
although searching back up to 4 years is a great feature, you can end up with unusable threads like these
Post by FritzS on May 25, 2008 11:43:09 GMT
Post by FritzS on May 26, 2008 15:03:55 GMT
Post by horsy888 on Jun 1, 2008 10:34:26 GMT
Post by FritzS on Jun 1, 2008 11:18:37 GMT
horsy888 nice building! From where you get the PCB's?
Post by horsy888 on Jun 1, 2008 12:14:47 GMT
building myself
Post by FritzS on Jun 1, 2008 12:43:37 GMT
Did you sell a set of them to group members?
insomniac
Team Zopiclone
Post by insomniac on Jun 1, 2008 22:50:23 GMT
Nice amp horsey888 Nice solid chunky case......I think SandyK was looking for a case like that with heatsink sides.
Post by Deleted on Jun 1, 2008 23:36:08 GMT
Insomniac I was looking for a similar style case , but much bigger. This amplifier could also drive very efficient speakers ? But it could also be dangerous as far as ear damage goes, because there does not appear to be any limiting factors to prevent hearing damage due to excessive levels. Or am I missing something ? BTW, I don't like the fairly heavy loading of only one half of the complementary input stages by 2 parallel transistor driver stage transistors. It seems to me , also, that one driver transistor per side , and a reduction in the number of output devices would have been better. Minimal loading of the front end transistors normally results in an improvement in sound quality. Looks very impressive though .
Post by leo on Jun 2, 2008 0:06:21 GMT
I guess some people like their headphones loud, VERY LOUD It makes you wonder though how an amp as complex as this would compare sonically against something like the modified cheapo Jaycar HA Nice work on the build though
Post by horsy888 on Jun 2, 2008 11:29:03 GMT
Insomniac I was looking for a similar style case , but much bigger. This amplifier could also drive very efficient speakers ? But it could also be dangerous as far as ear damage goes, because there does not appear to be any limiting factors to prevent hearing damage due to excessive levels. Or am I missing something ? BTW, I don't like the fairly heavy loading of only one half of the complementary input stages by 2 parallel transistor driver stage transistors. It seems to me , also, that one driver transistor per side , and a reduction in the number of output devices would have been better. Minimal loading of the front end transistors normally results in an improvement in sound quality. Looks very impressive though . SandyK My dynahi no dangerous, because I used the speaker protection, the lower deck in the middle is the pcb
Post by Deleted on Jun 2, 2008 11:52:18 GMT
horsy888 I wasn't referring to protection in case of a fault condition. I was referring to protecting people's ears by limiting maximum volume to the headphones to a reasonably safe level.
Post by horsy888 on Jun 2, 2008 11:59:15 GMT
horsy888 I wasn't referring to protection in case of a fault condition. I was referring to protecting people's ears by limiting maximum volume to the headphones to a reasonably safe level. SandyK I understand what you meant But maximum volume problem, is a personal conduct, It is difficult to avoid
Post by FritzS on Jun 2, 2008 12:16:38 GMT
Post by horsy888 on Jun 2, 2008 14:34:42 GMT
Right, is this version However, I change the output transistor a1358 c34211 to mje15030 15031 or tip41 42 already (REMARK: Printed on the PCB is wrong) In addition, the dc servo is same but I use the opa445bm op directly for 30v voltage, no use 7815 7915
How do I activate my account?
Post by pagan on Jun 3, 2008 12:59:25 GMT
Right, is this version However, I change the output transistor a1358 c34211 to mje15030 15031 or tip41 42 already (REMARK: Printed on the PCB is wrong) In addition, the dc servo is same but I use the opa445bm op directly for 30v voltage, no use 7815 7915 Why not the 2SA1358/2SC3421's ? Much better trannies than the others. What psu are you using for it? Gilmore's? allan BTW, very nice build ;D
Post by horsy888 on Jun 4, 2008 17:00:59 GMT
Right, is this version However, I change the output transistor a1358 c34211 to mje15030 15031 or tip41 42 already (REMARK: Printed on the PCB is wrong) In addition, the dc servo is same but I use the opa445bm op directly for 30v voltage, no use 7815 7915 Why not the 2SA1358/2SC3421's ? Much better trannies than the others. What psu are you using for it? Gilmore's? allan BTW, very nice build ;D Because the 15030 031 or tip41 42 easy to buy , also very good performance ;D I am use this psu
