Post by PinkFloyd on Mar 29, 2008 12:32:05 GMT
Post by PinkFloyd on Mar 29, 2008 12:49:24 GMT
and here it is guys....... the famous BELTED shpongle disc which remains a reference recording to this very day...... it has also been treated with creme electret.....
Post by PinkFloyd on Mar 29, 2008 12:51:21 GMT
Actually...... now I have it in front of me I'm gonna green pen it too
Post by PinkFloyd on Mar 29, 2008 13:06:35 GMT
Post by PinkFloyd on Mar 29, 2008 13:07:45 GMT
Aligning the slots in screw heads.
Align the slots in all screw heads so that the slots are parallel to the earth's surface. ALL screws - screws fastening light switches to the wall, screws fastening AC power sockets to the wall, screws fastening shelves to the wall etc. Listen to some music for a short time and then move any of the screw slots away from being parallel to the earth's surface and see if you can listen to the same music with the same pleasure !!
<races to get screwdriver>
Post by PinkFloyd on Mar 29, 2008 13:09:06 GMT
Plain piece of paper under one of four feet.
Place a plain piece of paper under any ONE of the four feet of a piece of equipment. This applies to any piece of equipment, even if it is not an item of audio equipment. Listen to some music for a short time, then remove the piece of paper and see if you can listen to the same music with the same pleasure - without the plain piece of paper in position !!
<runs to get a ream of paper>
Post by colin1958 on Mar 29, 2008 13:53:10 GMT
YEAH....o.k. is this some kind of early April fools day prank?.....nice one Mike
Post by Deleted on Mar 29, 2008 15:26:54 GMT
JC! Is this raving lunatic still around?
Tie your cables in special knots, screwheads, bits of paper, flip your lp three times, in reverse rotation to the planet, while clicking your ruby slippers?
Don't forget to repaint your listening room with the paint back to front! All logical, sensible stuff.
As soon as I can get the padding off my walls and remove the bars from the window, I'll be sure implement all his recommendations.
Trouble is, my jacket sleeves are too long and buckle up behind my back......
Chris (I think)
Post by rickcr42 on Mar 29, 2008 15:37:03 GMT
looks like ol' Peter found a new label for his product
Post by PinkFloyd on Mar 29, 2008 15:54:16 GMT
JC! Is this raving lunatic still around? Tie your cables in special knots, screwheads, bits of paper, flip your lp three times, in reverse rotation to the planet, while clicking your ruby slippers? Don't forget to repaint your listening room with the paint back to front! All logical, sensible stuff. As soon as I can get the padding off my walls and remove the bars from the window, I'll be sure implement all his recommendations. Trouble is, my jacket sleeves are too long and buckle up behind my back...... Chris (I think) Are you suggesting Peter's concepts are slightly off the wall?
Post by PinkFloyd on Mar 29, 2008 16:02:26 GMT
Post by PinkFloyd on Mar 29, 2008 16:08:47 GMT
Post by Deleted on Mar 29, 2008 17:25:36 GMT
He has a mix of both sensible and senseless.
Anything that effects the listening enviroment, the equipment involved or the listener is obviously going to impact on the music in said enviroment. This is nothing new and proven.
Mr Belt seems to cross past the grey area where the listener WANTS to perceive a difference/improvement after performing any of his less obvious suggestions.
I have in the past, attended one of his demonstrations, leaving very unimpressed.
Just like a good evangilist there has to be a healthy dollop of truth in order for people to accept anything outside proven norms.
IMO if you give your ears a good clean, relax and settle down with your favourite tipple, you will acheive a much greater improvement to your listening experience than any of PB's more obscure "teachings" can.
Post by charleyphogg on Mar 30, 2008 3:22:45 GMT
One drop drop? Edit, man, whats going on with my browser, I hit one nutton and it goes to who knows where and ,well, and. I got enough problems gettimng lost, I don't need no help. This time it took me to the fruom page, usaullu it posts in some other section I have no clue.
Post by charleyphogg on Mar 30, 2008 3:27:52 GMT
Edit agiam which I forgot to add. Looks like some tiedie shit to me.
Post by charleyphogg on Mar 30, 2008 3:34:43 GMT
OOk, now my postrs aren't even going through. I'm taking my monitor and pc and crushing them and going home. ? Bad enough when your shit don't work, but who know,s it may be posting to the NSA Or Al-Quida, screw both of them
insomniac
Team Zopiclone
Post by insomniac on Mar 30, 2008 11:25:20 GMT
JC! Is this raving lunatic still around? Tie your cables in special knots, screwheads, bits of paper, flip your lp three times, in reverse rotation to the planet, while clicking your ruby slippers? Don't forget to repaint your listening room with the paint back to front! All logical, sensible stuff. As soon as I can get the padding off my walls and remove the bars from the window, I'll be sure implement all his recommendations. Trouble is, my jacket sleeves are too long and buckle up behind my back...... Chris (I think) Don't forget to put on a tinfoil hat prior to trying any of these.
Post by Deleted on Mar 30, 2008 15:35:25 GMT
new one on me! At least it has some reasonable thought process. I lwould love to see the insides (or rather someone knowledgable see) ! One point of doubt is that they claim "each unit ia individually tuned"... to what? There are so many sources of mains noise, of different types and don't forget the different voltages and cycles around the world. Would they be able to provide one tuned to my particular mains noise, not to mention my supply that, rated at 220v, rarely fulfils this, I've measured it as low 185v. With all the shifts that causes to current etc. how could this thing cope? I fear it may become just an erratic flashing nightlight. End of ramble. More info. here psaudio.com/products/noiseharvester_overview.asp
Post by colin1958 on Apr 2, 2008 18:40:39 GMT
;Dgot me free foil today.... ;D hmmmmm...honestly not impresssssssed,sorry i think a snake slithered into the room. :-[sorry its not for me but worth a try.
Post by Deleted on Apr 2, 2008 20:09:01 GMT
Miguel and other members.
Just skimming through, when I noticed the above line. This item was thoroughly debunked in Silicon Chip for what is is several months ago. It is a Peter Belt type invention, that flashes a LED with mains pulse interference. (simplified) It does NOT do what it is claimed to do! It is just like all the other simple concoctions aimed at gullible people after a quick fix to all the world's problems ! People like Peter Belt, and the designer/promoter of this rubbish should all rot in the same jail cell as Russ Andrews!
Post by Deleted on Apr 2, 2008 23:02:06 GMT
Let's hope that you don't try and sell them to those assholes that you work with ! Otherwise you may zoom past Rick down that long highway, being chased by a pack of assholes.
Post by leo on Apr 3, 2008 0:58:33 GMT
Post by Deleted on Apr 3, 2008 1:15:19 GMT
Leo Room animator ? Yeah, right ! The other products at least have a tiny grain of truth about them. Alex
Post by leo on Apr 3, 2008 1:25:14 GMT
Amazing the amount of crap floating about
Post by PinkFloyd on Apr 3, 2008 3:36:24 GMT
;Dgot me free foil today.... ;D hmmmmm...honestly not impresssssssed,sorry i think a snake slithered into the room. :-[sorry its not for me but worth a try. Rainbow foil needs a good 700 hour burn in........ give it time Colin.
