Post by scooby on Mar 11, 2012 14:10:46 GMT
Post by scooby on Mar 11, 2012 17:31:47 GMT
Anyone??
Post by pete on Mar 20, 2012 0:00:47 GMT
Bit of a russian roulette with ebay.
Post by scooby on Mar 26, 2012 10:36:53 GMT
I have decided to get the little dot 1+ hybrid amp for my grado 325is.
Post by XTRProf on Apr 3, 2012 10:48:22 GMT
I have decided to get the little dot 1+ hybrid amp for my grado 325is. Might as well get a MF X-Can V2 as Dot1 is an OTL and don't take too well to low ohmage HPs. Also, I would say it's rather dangerous for your HP since it is OTL. You see, in OTL, there is no coupling traffo to protect your expensive HPs if ever it decided to throw it's tantrum. Bye, bye HPs.
Post by Deleted on Apr 3, 2012 14:51:30 GMT
The little dot 1+ is a hybrid and is specifically designed for low Ohmic HP's.
It is OTL just like the Bravo/Indeed/sunrise/HA10 thingies. These are all no more 'dangerous' than an Xcan V2.
Post by XTRProf on Apr 3, 2012 17:10:09 GMT
The little dot 1+ is a hybrid and is specifically designed for low Ohmic HP's. It is OTL just like the Bravo/Indeed/sunrise/HA10 thingies. These are all no more 'dangerous' than an Xcan V2. Hmm, so the DOT 1 is different from DOT 3 here? Technical Specifications: SEPP (Single-Ended Push Pull) OTL in Class-A Frequency response: 12 hz~100 Khz (-1dB) THD+N: 0.15% (80 mW @300 ohm) Power Output: 350 mW @ 300/600 ohm 300 mW @ 120 oh 100 mW @ 32 ohm Variable Gain: 3,4,5, or 10x Recommended Load Impedance: 32 ohm~600 ohm Input Impedance: 50K ohms Pre-Amplifier Output Impedance: 600 ohms Pre-Amplifier Gain: 3-10x (also controlled via gain switches) Pre-Amplifier Voltage: 10V RMS Power Consumption: 30W (228V * 0.130A) Pre-Amplification circuit includes both driver and power tubes Driver Tubes: 2x GE5654 Power Tubes: 2x Soviet 6H6PI (6H6n, 6H6nN) High quality aluminum chassis Dimensions (Metric): 270mm deep by 175mm wide by 123mm high Dimensions (English): 10.6 inches deep by 6.9 inches wide by 4.8 inches Weight: 3 Kg or 6.6 lbs Vacuum tubes are subject to availability, so please inquire as to the current included “stock” vacuum tubes if in doubt. Little Dot reserves the right to substitute equivalent or better tubes in the case “standard” tubes are not available. Available in either 120VAC or 220VA Reference: headphonesamplifier.com/little-dot-mk-iii-headphone-amplifierpre-amp/
Post by UzminiNu on Apr 3, 2012 17:15:18 GMT
;D no comments...
Post by Deleted on Apr 3, 2012 18:25:38 GMT
The dot 1 + is completely different. They are nothing alike. www.littledot.net/forum/viewtopic.php?t=819All tube (on high voltage) vs hybrid on low voltage. Input: Gold-Plated Unbalanced Phono (RCA) Jacks Output: 1/4" Gold-Plated Stereo Headphone out Tube Options: 6JI - standard Replace standard tubes with EF92 - additional $20 USD Replace standard tubes with WE408A - additional $50 USD Frequency Response: 10HZ - 50KHz (-3 dB) THD+N: 0.2%: 1Vrms @ 1000Hz 0.6%: 3Vrms @ 1000Hz 1.0%: 5Vrms @ 1000Hz Signal-to-Noise: 92dB Suitable Headphone Impedance: 8 - 600 ohms Input Impedance: 50K ohms Power Output: 150mW @ 300 ohms 300mW @ 120 ohms 800mW @ 32 ohms User variable gain settings: 6.5x or 3.25x Power Consumption: 15VA Measurements: Metric: 180mm (L) by 97mm (W) by 100mm (H) English: 7.08 inches (L) by 3.81 inches (W) by 3.93 inches (H) Weight: 1.5 kg or 3.3 lbs. Available in Black Available in either 120VAC or 220VAC 1 Year Little Dot Warranty
Post by PinkFloyd on Apr 3, 2012 19:19:24 GMT
You can't even say "it LOOKS good" can you? Not much info about it either apart from "Alan" who said "Apex arrived, connected Apex, now I'm listening to superb sound through my headphones, AKG 280, AKG K340 electrostatics". Yeh ok.... what about a look under the bonnet? It's probably a Cmoy under the hood?
Post by XTRProf on Apr 4, 2012 0:34:21 GMT
The dot 1 + is completely different. They are nothing alike. www.littledot.net/forum/viewtopic.php?t=819All tube (on high voltage) vs hybrid on low voltage. Input: Gold-Plated Unbalanced Phono (RCA) Jacks Output: 1/4" Gold-Plated Stereo Headphone out Tube Options: 6JI - standard Replace standard tubes with EF92 - additional $20 USD Replace standard tubes with WE408A - additional $50 USD Frequency Response: 10HZ - 50KHz (-3 dB) THD+N: 0.2%: 1Vrms @ 1000Hz 0.6%: 3Vrms @ 1000Hz 1.0%: 5Vrms @ 1000Hz Signal-to-Noise: 92dB Suitable Headphone Impedance: 8 - 600 ohms Input Impedance: 50K ohms Power Output: 150mW @ 300 ohms 300mW @ 120 ohms 800mW @ 32 ohms User variable gain settings: 6.5x or 3.25x Power Consumption: 15VA Measurements: Metric: 180mm (L) by 97mm (W) by 100mm (H) English: 7.08 inches (L) by 3.81 inches (W) by 3.93 inches (H) Weight: 1.5 kg or 3.3 lbs. Available in Black Available in either 120VAC or 220VAC 1 Year Little Dot Warranty Hmm, thanks. I wonder why a complete change to full tube from hybrid?
Post by Deleted on Apr 4, 2012 0:49:19 GMT
:-*For people with more money than sense ?
Post by scooby on Apr 19, 2012 9:09:26 GMT
:-*For people with more money than sense ? Interesting view , could you expand . I decided to get the Little Dot 1+ hybrid after a lot of research. To me after reading all the info and the cheap price tag it seemed like a good choice. I am open to any suggestions as it is all a learning curve for me. I will eventually get myself a Xcan v2 in the future , but this will have to wait until i can fully return to work after my mini strokes , which have hindered my cash flow. Cheers Paul
Post by Deleted on Apr 19, 2012 9:22:48 GMT
:-*For people with more money than sense ? Interesting view , could you expand . I decided to get the Little Dot 1+ hybrid after a lot of research. To me after reading all the info and the cheap price tag it seemed like a good choice. I am open to any suggestions as it is all a learning curve for me. I will eventually get myself a Xcan v2 in the future , but this will have to wait until i can fully return to work after my mini strokes , which have hindered my cash flow. Cheers Paul Hi Paul As you will have gathered from the little "red devils", I was mainly stirring the pot. Briefly, a hybrid amplifier gives the best of both worlds. You get the typical warmth of a valve amplifier due to a higher proportion of even order harmonics, a lower output impedance, and wider bandwidth. Alex
