Post by Deleted on Dec 29, 2011 17:22:44 GMT
Felices Fiestas y próspero año nuevo John!
I don't think they are on an update spree again, probably a little bug fix that went unnoticed.
Edit:
What I have found is that in neither of the last two versions the HDCD icon lights up when such material is played, also volume doesn't half so I assume they have broken it and it doesn't decode HDCD anymore which gets played as regular 16/44.1
Corrected the above because it is incorrect. It was my fault as I had moved the volume slider in Foobar without noticing and that is enough to lose the "bit perfectness" causing the Musiland to fail the HDCD code signaling detection. When I found out and moved the slider to max all went back to normal and HDCD playing great again.
Post by Deleted on Jan 1, 2012 16:53:54 GMT
Now i have my new pc up and running, all the latest musi drivers are working perfect and with ease, sacd is great, superb sound through foobar, really impressed.
Thanks Javier for yor help in achieving the above, pleased i dont change my pc`s too often, i will be deaf by the time my next change is due, so no worries then.
Mick.
Post by sandr77 on Jan 23, 2012 13:37:09 GMT
Hi, i have a monitor 01 us, i have tried to install the new drivers , but i recevied "invalid license message"on top of controlpanel, i have dowload the firmware flash utilty MycmonAct,,and i have send to activate@musiland.com the file "license.dat", but when i recevied the file license key and i have flashed device i have already, "license invalid" message P.s. Sorry for my poor english
Post by Deleted on Jan 23, 2012 13:59:39 GMT
Hi Sandr
Have you checked the fimrware version displayed in the control panel and verified it has changed? maybe the update didn't go well. Did you write down original version?
Post by sandr77 on Jan 23, 2012 18:30:35 GMT
Hi Sandr Did you write down original version? Hi javier , I don't write down the original version, but i suppose is not changed The device work perfect with original driver 1.0.2.5,when i try to flash firmware in the compuer when this driver is installed i recevied the message "device not found" If flash with the new driver i look this: #################################################################################### Press key to continue.... But i have already "invalid license" message
Post by Deleted on Jan 23, 2012 20:39:02 GMT
The firmware request lic file has to be generated with the new drivers installed. If you generated it while the old drivers were installed I'm afraid you will have to generate and send the lic file to Musiland again. Have you tried any itermediate drivers like the 1.0.12?
Post by sandr77 on Jan 23, 2012 21:23:48 GMT
The firmware request lic file has to be generated with the new drivers installed. If you generated it while the old drivers were installed I'm afraid you will have to generate and send the lic file to Musiland again. Have you tried any itermediate drivers like the 1.0.12? I try all drivers 1.0.xx the device only works with its driver I have tried to re -send the file. dat for having an other .key but mine provider me dive who does not succeed to deliver the mail to activate@musiland.con.cn and the musiland forum is writed in chinese
Post by Deleted on Jan 23, 2012 21:32:01 GMT
Yep, you can try to use Google translation or Google's Chrome browser to translate their forum and get an idea of what is going on though sometimes the translations don't make any sense.
It takes some time to get answer from activation email and some times you get no answer, I'm afraid you'll have to keep trying.
Post by sandr77 on Jan 24, 2012 13:20:30 GMT
Yep, you can try to use Google translation or Google's Chrome browser to translate their forum and get an idea of what is going on though sometimes the translations don't make any sense. It takes some time to get answer from activation email and some times you get no answer, I'm afraid you'll have to keep trying. I have created a account in the forum musiland and have expressed my problem
Post by Deleted on Jan 24, 2012 13:47:14 GMT
I don't know if they answer to questions in English, lets wait and see.. good luck.
Post by sandr77 on Jan 30, 2012 10:38:58 GMT
I don't know if they answer to questions in English, lets wait and see.. good luck. Up, they have answered to me
Post by Deleted on Jan 30, 2012 13:44:58 GMT
Did you try to flash the 01 with the latest driver installed as they say?
Post by sandr77 on Jan 30, 2012 14:30:02 GMT
Yes, i try to flash with...228 driver installed i have run mycmonprog and i have the message Writing the eeprom please wait ################################################### Press key to continue But the message "invalid license" is already in control panel P.S. with the original driver the program to flash don' t running i have the message device not found Thanks
Post by sandr77 on Feb 1, 2012 9:31:47 GMT
Post by Deleted on Feb 22, 2012 20:59:31 GMT
Post by Deleted on Mar 30, 2012 17:12:03 GMT
After a long while without official updates Musiland has released a new driver for the Monitor series. As always, no change log and probably just adds support for the new models (02 US Dragon, 03 USD, 03 US Dragon -not available yet- and the revised 01 USD). I've installed and played with it and found no visible changes from previous version. Direct link: www.musiland.com.cn/downloads/drivers/MlCyMon_2.3.0.0_build20120302.exe
Post by Deleted on Apr 17, 2012 9:07:27 GMT
There is a new beta drivers version available, I've been using it for 3 days and no problems whatsoever with it. As solid as any official one. Can be downloaded from here: www.musiland.com.cn/downloads/drivers/beta/MlCyMon_2.3.0.0_build20120413.exeI've been doing some comparisons between the 02 and the Xonar ST since the Musi 2.3.0.0 driver series came out. Truth is they sound so close to each other it is quite difficult to say which one is which in a blind test (under same conditions for both cards). Really impressive considering the Musiland costs nearly a third of the ST.
Post by Deleted on Aug 5, 2012 19:36:30 GMT
Don't know if anyone else is still using the 02 but anyway, new version 2.4 driver available from here: dl.musiland.cn/MlCyMon_2.4.0.0_build20120731.exeI have installed it without any problems. Changes/Fixes (according to Google translate): - support WIN8. - Concentrate on solving the authorized invalidity. - Settlement and a MD11 \ 30 the firmware MULINK digital signal compatibility issues
Post by JohnnyBlue on Aug 14, 2012 9:59:50 GMT
Hi Javier
Been away on holiday so have only just seen this post. I'm still using my 02 and am grateful for these posts! Keep up the good work.
PS Your link is moribund. Now on build .......0806
Post by JohnnyBlue on Aug 14, 2012 10:35:51 GMT
Damn! When will I ever learn to leave well alone?
New driver installed OK, but no sign of blue M in the system tray, even after reboot, and running 02 Control Panel from Start does nothing.
I have been here before...
Post by Deleted on Aug 14, 2012 11:09:40 GMT
Hi John
I'm running the latest 0806 and so far all perfect but then I'm running W7 and maybe there is some incompatibility with XP. Have you considered upgrading?
Post by JohnnyBlue on Aug 14, 2012 12:23:54 GMT
I'm on Vista. Managed to sort things out (as previously) by fiddling around in Device Manager. All AOK now.
Post by Deleted on Aug 15, 2012 0:23:45 GMT
Glad you managed to fix it, have you noticed any difference in SQ? Funny you mentioned holidays, it is when I'm away on holidays like now when my 02 gets most use. When I'm home I tend to use the Xonar ST nearly all the time.
My experience with Vista wasn't too good, it is really a resource hog and quite slow compared to W7. If you are not afraid and/or too lazy I'd suggest you give some serious thought to upgrading, it really is worth the effort.
Post by JohnnyBlue on Aug 15, 2012 6:43:48 GMT
I have 5 year old Dell Dimension C521, with an AMD Athlon 64 3800+ (32 bit) CPU, 3GB RAM fitted and a 250GB HDD. It just isn't worth my while to spend the €100 on W7, never mind all the hassle.
