hiFace Hi-End S/PDIF Output Interface Highest quality digital audio up to 192kHz/24bit S/PDIF audio format available from your PC or MAC Very low jitter oscillators and proprietary drivers Compact size (2x2.2x10.2cm) with hi-end performances hiFace USB interface has been conceived to obtain the highest quality digital audio signal using a PC or MAC. hiFace input format is a data stream signal with sampling frequency/resolution up to 192kHz/24bits, available from a PC or MAC USB port. A very high quality S/PDIF stereo audio output signal is available from hiFace for your Hi-Fi system DAC (Digital to Analog Converter). HiFace looks like a small USB pendrive, featuring a very compact size. Internal very low jitter oscillators and proprietary drivers allow for playing 192kHz/24bits audio files that feature the best signal quality.
ctimmins: Hi- Just purchased a Musical Fidelity X-Can V3 without the power supply. I have a toroidal transformer with 12-0-12 vsecondary windings and hope to build a power supply. Could anybody tell me the 3 din pin connections that would need to be connected
Jul 13, 2023 19:59:12 GMT
louro: Olá pretendo saber quais são as melhores válvulas para o musical fidelity X-10D.Obrigado
Jul 16, 2023 15:18:17 GMT
pingu: Just a quick one, does anyone know, remember a thread on modding the Darkvoice HA on here?
Jan 24, 2024 17:41:28 GMT
