oldson
Older than a well used glove
Post by oldson on Apr 25, 2008 19:01:28 GMT
anyone on here care to give their views on these two as a comparison? the mkv seems to have a mass of components compared to the solo, and is dual mono (whatever that is). does this mean it is "technically" superior? any comments appreciated! thanks
oldson
Post by oldson on Apr 26, 2008 18:48:31 GMT
maybe i should just "toss a coin" best of 3, or 5 what do you think???
Post by Deleted on Apr 26, 2008 22:51:02 GMT
oldson
I will have to let others comment on how they compare, but dual mono suggestion is normally where both channels are completely separate, and share no components,not even the power supply. Different manufacturers usually twist this around to suit their own marketing needs, some even using a shared power supply, or even both channels on the same PCB, without common components. This usually, but not always, results in better isolation between channels, and MAY be technically superior. However, many dual I.C.s made to day, have excellent isolation between both channels, and provided a good power supply is used , it may be hard to pick the difference between both methods.
Post by tfarney on May 24, 2008 2:10:17 GMT
maybe i should just "toss a coin" best of 3, or 5 what do you think??? There's what? 500 difference? Better use a pretty big coin. Tim
Post by banned on Jun 19, 2008 5:58:47 GMT
Cadillac vs Chevrolet, if you can afford the Solo then get it. Then you will never be looking at amps again.
Nigel
Post by Nigel on Jun 19, 2008 16:49:09 GMT
if you can afford the Solo then get it. Then you will never be looking at amps again. For a few months at least.
