Post by fault151 on Oct 3, 2007 11:34:39 GMT
Is there anything i can do to modify my HD 595 Headphones? They have once cable that runs in to the left headphone and provided sound to the right headphone. Can the cable be replaced with ease?
Post by fault151 on Oct 4, 2007 11:31:55 GMT
Anyone have any ideas??? Please.
insanitybeard
My head feels like a frisby, like a football.....
Post by insanitybeard on Oct 4, 2007 18:13:05 GMT
I think the cable is detatchable for ease of replacement as it is with the other "top of the range" Sennheisers- HD650/600/580 etc although they have a cable to each transducer instead of the 595s' single sided one. As for modifying them, I wouldn't advise it as any errors could be expensive! Aside from the cable, what would you want to replace/modify? Paul
Post by fault151 on Oct 4, 2007 18:48:16 GMT
[quote what would you want to replace/modify? [/quote]
It was mainly cable that i was thinking of. Maybe some thicker higher quality wire. I just didn't know if i could pull the bottom out. I not sure how it would work though, as you said the cable feeds both ear pieces from the one side. I tried pulling the bottom wire out but it didn't seem to want to move, i didn't want to force it!
Anyone else have a set of HD595?
insanitybeard
Post by insanitybeard on Oct 4, 2007 23:38:34 GMT
I don't own the 595s personally (I've got the 600s). If you're not sure it may be worth making a call to Sennheiser UK to clarify. I thought the cable was detatchable. As for whether anybody does a cable upgrade for it (as they do for the HD650/600) is another matter.
Post by fault151 on Oct 5, 2007 10:29:10 GMT
Ok i'll give them a call. The wire may pull out but I didn't want to risk it. Knowing my luck I would force it out and then realise, oh, oh dear, it wasn't meant to come out! ha ha.
Cheers
Post by Deleted on Oct 5, 2007 11:01:12 GMT
fault151 According to the Sennheiser website, the cable is : single sided, changeable. All the others in the 500 series are also single sided, changeable. SandyK
Post by fault151 on Oct 5, 2007 11:09:43 GMT
Ah well you have just saved me a lot of time, Thank you! Why didn't i even consider looking on their official website first? Having said that, a lot of the time the official websites of companies can be as much use as a third nipple! Forums are the way forward!
Post by PinkFloyd on Oct 5, 2007 11:21:54 GMT
I think you'll find the cable is terminated with a 2.5mm jack plug?
Post by fault151 on Oct 5, 2007 11:27:25 GMT
To upgrade any cables would you need to find a proper supplier of that particular cable or can you make your own?
