How do I activate my account?
Post by pagan on Jan 17, 2008 6:10:29 GMT
Hi Leo I havn't tried the ALW's yet, been meanig too, just never got around to them. been using audiocom's, 5v for the dac's etc
experiment time maybe! If theres a difference between low impedance and ultra low impedance caps? Audable difference that is.
Post by leo on Jan 17, 2008 9:21:07 GMT
Hi Leo I havn't tried the ALW's yet, been meanig too, just never got around to them. been using audiocom's, 5v for the dac's etc experiment time maybe! If theres a difference between low impedance and ultra low impedance caps? Audable difference that is. Another bonus with the VBE replacing the LM3*7 pre reg in the ALW, low ESR caps do not cause stability problems. Those PFM flea's work nicely for a dacs 5v supply too, I have one supplying a Tent XO and another for the dacs 5v They are not as compact as Audiocoms though Heres a cdp I was playing about with, a flea'd Tent XO, Audiocom reg on the right fixed to the black heatsink and VBE's normal regs on the bottom supplying the dacs +/-5 and -15v Burson regs for the output section
Post by leo on Jan 17, 2008 9:26:24 GMT
VBE modded ALW, the VBE is diy Sziklai pair
Post by pagan on Jan 17, 2008 11:29:14 GMT
Leo I've been trying to get some those PFM flea's pcb's for a while now.
VBE pre reg, ? might worth a try. Whats the noise out of the pre reg like compared to the LM's?
Post by leo on Jan 18, 2008 2:06:05 GMT
Pagan,
Yes I'm also waiting for the next batch of Flea pcbs, hopefully they should be available soon.
The VBE is just a cap multiplier or common name gyrator built using either Darlington or Sziklai pair, these are much better than the LM3*7 used in the pre regulation at filtering out higher frequencies . You need the bigger t0220 transistors rather than the small to-92 packages so higher loads are suitale, problem is they are less gain so we build the darlington or sziklai to make up for it
The Flea also uses a gyrator on the input, it works well in that so made sense to try similar in the ALW
Post by Deleted on Jan 18, 2008 2:25:27 GMT
Leo A gyrator can work very well as long as you avoid bloody Audiophile type capacitors. I hate waiting weeks to see how good a circuit will eventually sound ! Alex
Post by PinkFloyd on May 19, 2008 20:49:13 GMT
I think the Jaycar amp is pretty much covering this Leo
Post by leo on May 19, 2008 21:15:51 GMT
I think the Jaycar amp is pretty much covering this Leo Soon as I can get a Jaycar pcb this Kumisa will be the first amp I compare against it
Post by pagan on May 20, 2008 11:15:18 GMT
I think the Jaycar amp is pretty much covering this Leo Soon as I can get a Jaycar pcb this Kumisa will be the first amp I compare against it That could be interesting I suppose, I could, but I might be a bit biased. Allan
Post by Deleted on May 20, 2008 11:34:40 GMT
Allan Was it the Kumisa 3 that I heard ? Alex
Post by leo on May 21, 2008 1:54:59 GMT
Theres also another amp I want to compare the Jaycar against
