pjc68
You dissin me?
Post by pjc68 on Feb 18, 2017 23:10:51 GMT
I am selling my record doctor vacuum record cleaning machine due to upgrading to a moth mk2 pro The Disc doctor is based on the nitty gritty 1.0 machine You put the cleaning fluid on the record and turn the platter manually while using the disc doctor brush to clean the record, then after 2 minutes to let the fluid do it,s work, you turn it over and vacuum the wet side of the record leaving it spotless This is boxed with a brand new DD cleaning pad, 1 litre of disc doctor cleaning solution with handy dispenser bottle and also the KAB platter platter upgrade kit that allows the record to get right to the vacuum slot Here is the machine, there is a video half way down snvinyl.co.uk/epages/eshop943300.sf/en_GB/?ObjectPath=/Shops/eshop943300/Products/RDRCMThis is the cleaning fluid that you fill to the line with distilled water, i will do that for the buyer as i have a few litres of distilled water left I used something else so this is totally unused, you simply vacuum it off snvinyl.co.uk/epages/eshop943300.sf/en_GB/?ObjectID=3966579The kab upgrade platter stops the record wobbling as the original bearing is too small, this has the original platter that is too high, this is best used cleaning the record as it stops the record touching the vacuum slot, then use the kab platter to suck the fluid off as this gets right down to the slot I am after £130 for the lot, would rather someone nearish buy it as i could demo it Paddy
pjc68
You dissin me?
Post by pjc68 on Feb 18, 2017 23:19:01 GMT
I forgot to say it is in excellent condition and still has the original box Paddy
pjc68
You dissin me?
Post by pjc68 on Mar 7, 2017 22:11:45 GMT
SOLD to a guy i work with Pady
