Post by freddypipsqueek on Aug 10, 2013 13:56:15 GMT
Guys. I would appreciate a bit of advice and a few comments. Even if you think I’m being a bit silly. My Chiarra/Andante wasn’t working last night; in fact it was given out very low valume. A quick look inside the amp showed the 15v LED wasn’t on so I opened up the Andante power supply and finding black marks around the 7815 (7815CSP) voltage regulation measured and fount no output voltage (the input voltage measured at 24v). I assume the 7815 has failed. I am happy to go to Maplin and simply pick up a replacement. I was wondering however if it was worthwhile fitting one of the fancy regulators – say this – www.hificollective.co.uk/components/nclassd_reg.html. I need something pretty simple as I am pretty simple. Cheers, Adrian
Post by Deleted on Aug 10, 2013 15:06:53 GMT
Hi Adrian, I think I'd be rather concerned as to why the 7815 cooked itself in the first place. There may be a problem upstream causing the fried reg. I found this reference to a blown PSU by someone we all know May be worth a read, for eample the part about... Does yours the same as this pic?
Post by freddypipsqueek on Aug 10, 2013 15:38:27 GMT
Yes that is the same as my board however mine is the original box and thus has the edge connector.
I have looked through the wires and joints for a short but can't find one.
Given your comments however it may be better not to waste £'s on anything fancy and refit a 7815 and see what happens.
Cheers,
Adrian.
Post by Deleted on Aug 10, 2013 22:04:15 GMT
Hi Adrian, I think I'd be rather concerned as to why the 7815 cooked itself in the first place. There may be a problem upstream causing the fried reg. I found this reference to a blown PSU by someone we all know May be worth a read, for eample the part about... Does yours the same as this pic? You need to remove the 7815 and check with a DMM for any very low ohms readings on the output side of the voltage regulator. It is possible, but not likely, that it was due to long term overheating. Alex
Post by freddypipsqueek on Aug 11, 2013 12:07:43 GMT
Alex.
I get a reading of circa 64ohms.
The 7815 was not fitted with a heatskin. I assume one was not supplied with the kit at that time (1995).
I have ordered a replaced with a heatskin and will see what happens.
I assume getting something better is unlikely to make much of a difference ?.
Cheers,
Adrian.
Post by Deleted on Aug 11, 2013 16:10:02 GMT
The 7815 was not fitted with a heatskin. Adrian. Aha! A better chance that the reg just died of over heating then Make sure you pop a heat sink on the other reg too, before it goes the same way.
Post by Deleted on Aug 11, 2013 21:23:40 GMT
Alex. I get a reading of circa 64ohms. The 7815 was not fitted with a heatskin. I assume one was not supplied with the kit at that time (1995). I have ordered a replaced with a heatskin and will see what happens. I assume getting something better is unlikely to make much of a difference ?. Cheers, Adrian. Hi Adrian I would just use a standard 7815 with a small heatsink fitted, and cross my fingers that there has been no further damage. Regards Alex
Post by freddypipsqueek on Aug 11, 2013 22:27:41 GMT
I have ordered the bits. I am away for a few days so will update when I get back and I know if it has worked !!.
Post by freddypipsqueek on Aug 17, 2013 13:49:43 GMT
Fitted a new 7815 with a heat skin and the Chiarra is back to life.
I will leave it off and swap over the 7915 (with a heat skin) to ensure this does not fail before I power it up in full.
I also propose replacing the caps as I am assuming the originals are 17/18 years old.
Any other ideas for improvement greater appreciated.
