Post by noss on Aug 9, 2014 11:42:46 GMT
Hi,
Yes it is working and sounds good.
I would note two things thought, a] the adaptor that connects to the MF unit is not a very snug fit and b] when you turn off the adapter you get a horrible noise through the amp as it powers down. I don't know if this is meant to happen. It certainly did not with the MF unit?
Post by PinkFloyd on Aug 9, 2014 20:22:18 GMT
Hi, Yes it is working and sounds good. I would note two things thought, a] the adaptor that connects to the MF unit is not a very snug fit and b] when you turn off the adapter you get a horrible noise through the amp as it powers down. I don't know if this is meant to happen. It certainly did not with the MF unit? A kind of "wheeeeeeow!" "neeeyah!" sound? Perfectly normal.
bullpup
Post by bullpup on Aug 30, 2014 14:16:53 GMT
I am interested that these are now gettting the nod as when I originally suggested using them they were deemed to be unacceptable?
Post by Deleted on Aug 30, 2014 23:16:50 GMT
I am interested that these are now gettting the nod as when I originally suggested using them they were deemed to be unacceptable? Personally, I wouldn't use a transformer with poor regulation, and hope that the output voltage drops to the specified voltage of the equipment when loaded. Mike only uses transformers that have tighter specifications and higher quality iron in them for his Little Pinkies.
bullpup
Post by bullpup on Aug 31, 2014 16:28:32 GMT
Thanks Sandy.
I was tempted to use the Maplin unit - now lost in the garage somewhere. Unfortunately a Little Pinkie isn't an option at the moment and the Rapid Wallwarts Mike used to recommend are no longer available. Anything else worth looking at?
jc
Post by jc on Aug 31, 2014 17:39:00 GMT
How far are you perpared to stretch£ ? There is a LP you could make an offer on here .
bullpup
Post by bullpup on Aug 31, 2014 18:29:16 GMT
Thanks CJ - I will give it some serious thought i.e. consult the chancellor!
