layums
Thank you for the untips
Post by layums on Aug 29, 2012 15:23:12 GMT
Hej, Is anyone willing to part with their project sunrise II?
Post by Deleted on Aug 29, 2012 15:52:36 GMT
I have a Sunrise-II WITH auto tube select (sets the correct heater voltage by itself !) AND autobias (set's the bias by itself). It's a unique prototype. You can also set the output resistance on the front panel AND the on/off switch WITH on/off indicator is on the front. Also it can be used as a pre-amp as it has a realistic gain and output voltage ! rockgrotto.proboards.com/index.cgi?board=b&action=display&thread=7968&page=4 (post #78) a unique amplifier with on top of it all extra heatsinks !
layums
Post by layums on Sept 5, 2012 23:09:56 GMT
Fantastic! I have some of these tubes from a Leak troughline stereo I have as a spare should my trusted go down.
Would they work in this amp? I'm not too familiar with tube specifications.
2xECF80, ECC88, ECC85, EF80, EM84, EZ80.
They are Mullard original 1960's
Post by Deleted on Sept 6, 2012 7:42:05 GMT
ECC88, ECC85: yes
ECC88 and ECC85 are double triodes
2xECF80 EF80, EM84, EZ80: no
EM84 is an indicator tube EZ80 is a full wave rectifier (double diode equivalent) EF80 is a pentode ECF80 is a triode and pentode in one tube
layums
Post by layums on Sept 6, 2012 9:57:07 GMT
Great stuff that I shall be able to try 2 of them.
The fun starts soon!
Have you any good links you can recommend for a beginners guide to tube technology?
Post by Deleted on Sept 6, 2012 14:48:54 GMT
