Post by pandapops on Aug 13, 2012 15:41:51 GMT
2.4ohm, 2,400( 2k4) and 2,400,00( 2M4, 2.4M) are all standard values, each 1000 times the resistance of the previous one but looking the same except for the print which is difficult to read.
layums
Thank you for the untips
Post by layums on Aug 13, 2012 21:30:14 GMT
Had a huge leg up from headfi member. Part says 2R40 as seen on photo. Anybody quick able to post the farnell product number for me.
Post by Deleted on Aug 13, 2012 22:03:44 GMT
layums
Post by layums on Aug 14, 2012 6:07:16 GMT
layums
Post by layums on Oct 10, 2012 8:01:48 GMT
ok, i want to get this fixed. There are so many little sm resistors out on the net. i need one that conforms to 1%
"All resistors chosen are of the highest .1% tolerance SMD “Dale Vishay” can offer"
2R40 is what i need. Does anybody have any of these kicking about. it would be easier for me to order direct from you, its just a little part and im not interested in ordering more parts........but perhaps a stereo switch for changing channels.
look forward to hearing from anyone with these in there toyboxes.
Post by Deleted on Oct 10, 2012 8:52:01 GMT
2.4 ohms isn't a commonly stiocked value in metal film resistors in metal film, whether surface mount or hole insertion types. The chances of any member having this value in SM type is quite remote. Alex
layums
Post by layums on Oct 10, 2012 18:00:10 GMT
worth a shot though. i will order one from conrad, a 2.2 as they dont have 2.4. its 5% instead of 1%, but its just the battery circuit. it cost 0.08 euro.
Think i need to beef out my order a bit to make postage worth while.
Ray are you reading this? sound good to you :-)
Post by Deleted on Oct 11, 2012 1:06:48 GMT
worth a shot though. i will order one from conrad, a 2.2 as they dont have 2.4. its 5% instead of 1%, but its just the battery circuit. it cost 0.08 euro. Think i need to beef out my order a bit to make postage worth while. Ray are you reading this? sound good to you :-) If you have a decent DMM, at that price why not buy 10 or so of them, and select one with the highest resistance reading ? One with 5% variation on the high side will give you 2.31 ohms. Alex
layums
Post by layums on Oct 11, 2012 5:26:37 GMT
O I C. Good advice. Thanks.
layums
Post by layums on Oct 30, 2012 9:54:54 GMT
Post by gommer on Oct 30, 2012 10:35:42 GMT
A bit late on the resistor, but you could stack 2,7E and 22E (in parrallel) and you'll get 2,405E. These are E12 values and more common.
Cheers, Marc
Post by Deleted on Oct 30, 2012 11:15:39 GMT
Another possible fly in the ointment. A 9V NiMH battery is actually only 8.4V
