Post by puffin on Dec 28, 2011 9:31:49 GMT
Post by PinkFloyd on Dec 28, 2011 9:46:57 GMT
Nice one I didn't bother with the amp boards but bought one of those insane power supplies instead
Post by Deleted on Dec 28, 2011 16:21:43 GMT
Good idea and good marketing.
I just don't need another headphone amp at the moment and nothing else on the site appealed right now BUT popped into favourites...
That psu is probably worth it for the caps alone!
Post by ninkasi on Dec 31, 2011 5:21:35 GMT
Please forgive my n00bness, but is this the same as the JLH Ripple eater?
Cheers
Post by Deleted on Dec 31, 2011 5:37:01 GMT
Please forgive my n00bness, but is this the same as the JLH Ripple eater? Cheers ninkasi. No. It is a clever ploy to sell other items associated with the JLH amplfier. Have you constructed a SC HA from the Altronics kit yet ? Alex
Post by ninkasi on Dec 31, 2011 5:53:28 GMT
ninkasi. No. It is a clever ploy to sell other items associated with the JLH amplfier. Have you constructed a SC HA from the Altronics kit yet ? Alex Hi Alex, I have the kit on the workbench, waiting for my solder to get here in the new year. Looked at the AK Mod BOM and then saw this. I was hoping. Cheers.
Post by Deleted on Dec 31, 2011 6:07:39 GMT
ninkasi I have a handful of the PCBs left, so PM me your full mail details and I will stick one in an envelope for you F.O.C. Regards Alex
Post by puffin on Jan 8, 2012 14:41:44 GMT
Got my boards yesterday. Good quality ;D (no, really)
Parts count is low - nice. Anyone know where I can get TO220 2N3055s? Preferably without large postage costs for just 4 of them.
Rob.
Post by Deleted on Jan 8, 2012 21:27:04 GMT
Got my boards yesterday. Good quality ;D (no, really) Parts count is low - nice. Anyone know where I can get TO220 2N3055s? Preferably without large postage costs for just 4 of them. Rob. Hi Rob Look for TIP3055. They should be readily available from RS and Element14 (Farnell) too.They aren't TO220 , so check the dimensions in the data sheets for compatability. Regards Alex
Post by puffin on Jan 8, 2012 23:02:32 GMT
OK will do.
Post by puffin on Mar 18, 2012 11:28:16 GMT
Getting there.....
Post by puffin on Jan 26, 2013 9:52:52 GMT
Post by Deleted on Jan 26, 2013 11:54:20 GMT
Hi Rob Nice work i really like the chassis. where did the Aluminum come from? take care
Post by Deleted on Jan 26, 2013 12:42:02 GMT
That's quite tatsty looking Understated "Does what it says on the can" type look and I'm a sucker for those allen head bolts, I think I'll buy a big a sack of them and rub them all over me and.......
Post by puffin on Jan 27, 2013 7:26:54 GMT
Hi Rob Nice work i really like the chassis. where did the Aluminum come from? take care Thanks. A mate on Diyaudio sourced the very nice heatsinks and got some Ali off cuts so that we could construct a case. As my mantra is is "measure once and then bugger it up", I don't think it went too badly, as I also had to line up all the tapped holes in the sinks and then drill the top and bottom panels.
Post by Deleted on Jan 27, 2013 9:42:27 GMT
That's quite tatsty looking "Tatsty"? What's that? That Greek yoghurt, cucumber and mint dip thing? Or maybe a poorly put together Cornish meat and vegetable pie? ;-) Derek
Post by Deleted on Jan 27, 2013 12:07:48 GMT
"measure once and then bugger it up", ;D ;D
Snap on that
Post by Deleted on Jan 27, 2013 12:37:57 GMT
That's quite tatsty looking "Tatsty"? What's that? ;-) Derek Maybe I was thinking, could have turned out tatty but looked great instead? OR Isn't that installing a new sky-box? Tzatziki
Crispy
500+
Post by Crispy on Jan 27, 2013 19:52:48 GMT
"measure once and then bugger it up", ;D ;D Snap on that X3 I thought I was the only one ;D
Crispy
500+
Post by Crispy on Jan 27, 2013 19:58:51 GMT
Hi Rob Nice work i really like the chassis. You have done a fantastic job there Rob, I hope my XA-50 power amp project comes out half as good when I eventually get around to starting it.
Post by puffin on Jan 29, 2013 13:49:00 GMT
Hi Rob Nice work i really like the chassis. You have done a fantastic job there Rob, I hope my XA-50 power amp project comes out half as good when I eventually get around to starting it. Thanks very much. I always feel that DIY is worth it and if it works at all it sounds soooo much better than the commercial stuff
Post by Deleted on Jan 29, 2013 15:00:40 GMT
You have done a fantastic job there Rob, I hope my XA-50 power amp project comes out half as good when I eventually get around to starting it. Thanks very much. I always feel that DIY is worth it and if it works at all it sounds soooo much better than the commercial stuff Hi Rob any chance of some specifications? power OP, DC offset and so forth. take care
Post by puffin on Jan 30, 2013 15:09:33 GMT
Shaun, here is a link to the Diyaudio thread on this amp. Will take a lot of reading so in short it is a 10W Class A design. DC offset should be as near to 0mv as possible. There are 3 variable resistors that take care of reducing the offset and setting the gain. It is quite a time consuming business to get it right. www.diyaudio.com/forums/solid-state/3075-jlh-10-watt-class-amplifier.htmlRob
Post by Deleted on Jan 30, 2013 15:18:41 GMT
hi Rob thanks for the link and the above info. i'll get reading take care
Post by Telstar on Jan 30, 2013 17:51:54 GMT
I have a couple boards in kit mode (PCB was free but the shipping not, so the kit was a better deal). I'll build it sooner or later, but i'm definitely not fond of the BD output transistors i got with it. Every part look original, though.
