a legitimate question.
there is a big difference in crosstalk and crossfeed.
Also there is a big difference between normal crosstalk and the 'nasty' crosstalk in the Indeed/Bravo thingies.
In the Bravo/Indeed there is always a bit of 'normal' crosstalk between the 2 channels which only narrows the stereo but only slightly.
Above a certain voltage in one half of a sinewave the crosstalk becomes MUCH larger from that point on and is a-symmetric and non linear.
This can be clearly heard when the bias is set too low as 'unpleasant distortion' and sounds nothing like the typical non feedback triode distortion which most people find pleasing because of the spectral distribution and amplitude of harmonics generated in this kind of 'distortion'.
Crosstalk is a technical term for bad channel (left and right) separation.
Like the sort you get with vinyl and sometimes tape recordings where the recording head and playback head had a different height position on the tape and tuners.
a small part of the left signal enters the right channel in this case and vice versa.
If there is 100% crosstalk the signal is mono.
It's mostly frequency independant so bass mids and treble have an equal amount of crosstalk AND there is no phase shift/delay in the signal.
In crossfeed (Xfeed) only the lower frequencies are a bit 'monofied' (a certain percentage) and the mid to high frequencies increasingly less and get a slight phase shift when transferred to the other channel.
a totally different effect on the sound.
On higher frequencies with a speaker located on the right, the right ear hears the speaker as normal and the left ear has the sound slightly delayed because of the bigger distance of the LS to the ear and the speed of sound and frequency also because our ear is slightly shielded by the head and the ear is listening 'outwards' there is also a smaller HF part compared to the LF part.
From this info our brain can reconstruct where the sounds came from.
this delay phase shift for the higher frequencies is done by the capacitors/resistors.
For the left speaker the same principle.
as X-feed is an
approximation of this phenomenon the sound separation is perceived as 'more natural'.
Doesn't work on artificial head/2 mic recordings with a Jecklin disc for instance as this already has real X-feed embedded in the recording.
On mixed music where every instrument got it's place by the pan adjustment on the mixing console there is an effect.
Wheter one likes the effect or not is indeed more of a personal nature.
