jkeny
Post by jkeny on Mar 14, 2010 23:43:08 GMT
Is this wadding just dialling down the bass & thereby bringing the mids & HF into better balance overall - I don't think it will have any direct effect on the Mids or HF.
Post by Deleted on Mar 14, 2010 23:54:35 GMT
Is this wadding just dialling down the bass & thereby bringing the mids & HF into better balance overall - I don't think it will have any direct effect on the Mids or HF. John The correct amount of suitable dampening material helps to reduce case resonances too. Alex
jkeny
Post by jkeny on Mar 15, 2010 0:04:17 GMT
John The correct amount of suitable dampening material helps to reduce case resonances too. Alex Yes, I guess I'm in loudspeaker mind-set.
Post by clausdk on Mar 15, 2010 0:05:29 GMT
My experince with wadding is that it does not hurt the bass but brings the mids more forward and dampen the high a tiny bit.. Behind the driver that is.. It also makes the driver work harder, i think..
I front of the driver it works different adding bas and hurts the treble, depending on the density of the foam piece.
I have absolutely no "real" knowledge just my ears and experiments over the last decade or so..
Post by videoguy on Mar 23, 2010 0:13:06 GMT
Blue Tac has been mentioned in this post as well as others on other forums. My question is; what is the official name of this material?
Went to the local office supply superstore & asked for Blue Tac; no one at the store knew what I was talking about. Would appreciate either the name of the manufactrer or the correct name of the material.
Thanks in advance for the answer to this question.
Post by Deleted on Mar 23, 2010 0:19:58 GMT
Blue Tac has been mentioned in this post as well as others on other forums. My question is; what is the official name of this material? Went to the local office supply superstore & asked for Blue Tac; no one at the store knew what I was talking about. Would appreciate either the name of the manufactrer or the correct name of the material. Thanks in advance for the answer to this question. en.wikipedia.org/wiki/Blu-TackHope this helps. Mick.
Post by clausdk on Mar 23, 2010 0:22:04 GMT
Blue Tac has been mentioned in this post as well as others on other forums. My question is; what is the official name of this material? Went to the local office supply superstore & asked for Blue Tac; no one at the store knew what I was talking about. Would appreciate either the name of the manufactrer or the correct name of the material. Thanks in advance for the answer to this question. lmgtfy.com/?q=blu+tak+%2B+wikipedia
Post by clausdk on Mar 23, 2010 0:23:23 GMT
Mick: My link is so much more fun
Post by Deleted on Mar 23, 2010 0:25:39 GMT
Mick: My link is so much more fun Yes it is!! how did you do that Claus?!!!!!!
Post by clausdk on Mar 23, 2010 0:32:11 GMT
Mick: My link is so much more fun Yes it is!! how did you do that Claus?!!!!!! lmgtfy.com/?q=let+me+google+that+for+youThe hits just keeps on comming Was in the correct language ?? here it shows up in danish
Post by Spirit on Mar 23, 2010 1:16:47 GMT
Ah Claus UTFG? (yes, the language was correct)
Post by clausdk on Mar 23, 2010 1:36:36 GMT
UTFG? Had to google that ;D ;D ;D
Post by Deleted on Mar 23, 2010 8:08:18 GMT
Certainly was!! very good!!
Post by videoguy on Mar 23, 2010 15:13:55 GMT
Many thanks to Claus & Heliharris for the info. on blu tac. I am now educated.
Post by covenant on Mar 23, 2010 19:49:48 GMT
Modifications carried out so far: Frans Filter externally mounted Cable replaced with Van Damme quattro michrophone cable Internal wiring renewed 2 pence pieces added Fish filter wool added to rear chamber Velcro sticky pad to rear of speakers. Velour ear pads Still to do: Aluminium ring set (get well Heliharris) Leather head pad. Very pleased with the improvements though the filter wool needs some trial and error to get it right. I used filter pads and cut them into the shape of a Polo mint. At first I lost the bass but by gradual reduction of the thickness found that about 8mm was enough. I still experience slight bass loss but everything is crisper and more accurate I think. Looking forward to receiving the Indeed G2 and comparing it to my Beresford dac.
Post by puffin on Mar 23, 2010 20:09:08 GMT
What's the Velco pad mod? Haven't heard of that one.
Post by covenant on Mar 23, 2010 20:50:31 GMT
Just an alternative to the Dynamat stuff mentioned in post 572-sticky pad with some wool stuff to absorb sound.
Post by Deleted on Mar 23, 2010 21:02:28 GMT
Should get most orders done by end of April, if my neck support doesn`t snap!!
Post by covenant on Mar 23, 2010 21:28:30 GMT
Post by clausdk on Mar 23, 2010 22:44:29 GMT
Should get most orders done by end of April, if my neck support doesn`t snap!! Don't rush it, it looks goofy running around whitout a neck, unless you are really fat..
Post by PinkFloyd on Mar 23, 2010 22:59:25 GMT
What's the Velco pad mod? Haven't heard of that one. You basically stick some Velcro onto your forehead. You then attach some velcro onto the base of your amp and slap it onto your head..... This is more commonly referred to as "the short signal path mod"..... You then cut your Superlux cable down to "2 inches" and connect into your "head" amp.... Viola! short signal path
Post by clausdk on Mar 24, 2010 0:01:41 GMT
What's the Velco pad mod? Haven't heard of that one. You basically stick some Velcro onto your forehead. You then attach some velcro onto the base of your amp and slap it onto your head..... This is more commonly referred to as "the short signal path mod"..... You then cut your Superlux cable down to "2 inches" and connect into your "head" amp.... Viola! short signal path One could make a Cmoy and mount it in the cups.. ;D ;D ;D ;D, even shorter and then the Velcro mod for the Ipod, then of you go trekking Give some jerk a headbut, when you want to skip songs.. And load the Ipod with 30 GB of crappy music.. That is the way to let some steam off
Post by PinkFloyd on Mar 24, 2010 0:13:15 GMT
Post by puffin on Mar 24, 2010 7:34:42 GMT
What's the Velco pad mod? Haven't heard of that one. You basically stick some Velcro onto your forehead. You then attach some velcro onto the base of your amp and slap it onto your head..... This is more commonly referred to as "the short signal path mod"..... You then cut your Superlux cable down to "2 inches" and connect into your "head" amp.... Viola! short signal path Very good!
Post by MaN227 on Mar 27, 2010 9:14:47 GMT
what on God's Green Earth is this? just when I had 100% given up on ever seeing these cans. The wife says you got a package from the Netherlands. I was WAY HAPPY and totally shocked why ? some may ask. well these left the Netherlands 5 complete weeks prior and were given up as lost or stolen, fallen off the face of the earth. Mind you the box looked like it was just packed by me ready to ship that is how great the shape of package was I sh!Tt you not and here's said happy camper and here is his third cousins, best friends, Daddy's, buddy's, buddy, Bubba honest ;D and don't gimme no lip about either .... ;D will post more later on my impressions. all I will say now there have been a few changes since. in looks, sounds and impressions, more photo's to follow, u have been warned last but not least a HUGE THANKS to Frans, Mick and Mike !! who all helped make my happiness possible. Much Gratitude for all your hard work and kindness. Above and beyond coolness. nuff said Peace, MaN227
