Post by Deleted on Dec 9, 2009 18:52:40 GMT
Matt, Here are the pretty pictures (which I always like!) of what Will said... BD139 & 2SC5171
Post by mattcalf on Dec 9, 2009 23:04:12 GMT
Awesome, thanks for the quick clear up.
Post by mattcalf on Dec 11, 2009 0:46:00 GMT
Wow, the DIYing is trashing my room. Low PAF (parents-acceptance-factor)  . Just want to confirm my power wire-up as this is my first time dealing with AC (will get my ex-electrician father to inspect before I turn anything on, and if he's unsure I will go back into Jaycar  ). Could someone please confirm my lovely paint mockup? This is the combo IEC switch I'm using, if you'd like a photo of the back to clear things up just let me know. Also I'm using the M205 .5a fuse that came in the kit, however, was omitted for the mod. Thanks again for all your help! Matt.
Post by Deleted on Dec 11, 2009 1:19:27 GMT
matt I think we may have been through this before with this kind of combo switch. I have never used this one before, and from memory the rear isn't too helpful either.CouId be a wise move to get your father to identify for sure, which tag connects where. I could work it out if I had one of them, but unfortunately I don't have one. I prefer my on/off switches on the front panel, as they are easier to get to, and I don't believe in leaving things like this on 24/7. Alex P.S. The rest of the wiring seems O.K. but get advice about the correct way to wire the combo switch, and insulate that metal strip. It is likely to be alive at all times.
Post by mattcalf on Dec 12, 2009 4:41:23 GMT
To insulate the 'live' metal strip, is it worth hot glueing to completely cover it and then heatshrinking over the top? Or just one or the other? Thanks, Matt. P.S. Just have to wire it up now and do the initial tests, all the case work is done.
Post by Deleted on Dec 12, 2009 5:45:15 GMT
Post by mattcalf on Dec 20, 2009 13:45:00 GMT
Can't take 100% credit for it, however: Progress
Post by Spirit on Dec 20, 2009 13:55:49 GMT
Looking good Matt
Post by mattcalf on Jan 8, 2010 11:35:18 GMT
Finished!!  Listening to it now, great stuff. It's fully loaded with amp/psu Sandyk mods and a JLH. Only thing I'm missing is a LM4562HA. So will look into that once I can bring myself to spend a bit more money. Will post photos when I have access to a good camera, hopefully before the end of the month  . Thanks to all for your help.
Post by Deleted on Jan 8, 2010 11:56:31 GMT
Finished!!  Listening to it now, great stuff. It's fully loaded with amp/psu Sandyk mods and a JLH. Only thing I'm missing is a LM4562HA. So will look into that once I can bring myself to spend a bit more money. Will post photos when I have access to a good camera, hopefully before the end of the month  . Thanks to all for your help. Matt Look forward to seeing the photos when you have finalised it. The LM4562HA is worthwhile for extracting that extra little bit from it. Don't forget some kind of heatsink for it . e.g. TO5 type, and that the metal can is connected to the -VE rail. So turn it off before fitting a heatsink clip. Regards Alex
Post by Spirit on Jan 8, 2010 14:03:12 GMT
 Good to hear Matt. Enjoy
Post by Spirit on Jan 22, 2010 13:48:28 GMT
How's she sounding now? Got the 4562HA yet? ;D
Just out of curiousity, how did you come by the JLH?
Post by mattcalf on May 23, 2010 2:41:53 GMT
Haven't got a 4562HA yet, keep getting distracted.  Will hopefully get one from robertkd. The JLH was a kind donation from a member at Headfi.
Post by Spirit on May 23, 2010 13:05:38 GMT
Shoot him a pm - he's a good bloke  Lucky!
Post by mattcalf on May 24, 2010 8:42:47 GMT
Yeah we've been in fragmented PM contact, posted in the thread to see if he can hook up up with an appropriate heatsink as well. See how it turns out.
Post by Will on May 24, 2010 8:55:41 GMT
Matt, If all else fails, you could try something similar to this: www.zalman.com/ENG/product/Product_Read.asp?Idx=136for heatsinking your lm4562ha. I use one on mine, and it drops the temp appreciably. I guess that you may need something beefier in Oz, but something along the same tracks would do. Plenty to be found cheap in eBay and in pc overclocking/cooling shops.
