Post by Deleted on Aug 20, 2011 12:19:54 GMT
Very tasty Jeff. With plenty of room for add ons
Post by Deleted on Oct 13, 2011 6:37:08 GMT
UPDATED PHOTO. This coming Sunday, we hope to have a listen to 2, or perhaps even 3 SC DACs from Sydney RG members. There is also the possibility that we may be able to do a comparison against Allan Pagan's new Buffalo 3, which the last time I spoke with Allan, was sounding very nice indeed, but needed to be tidied up a bit yet, as it was still in bread board layout. These DACs will also be compared with david2vk's 24/192 capable W4S, and we will also be able to hear the Steve Nugent "OffRamp" in action, as well as direct playback from an Oppo 95 which has a Sabre DAC inside ,and also using it's USB input with a Corsair Voyager, and via Digital Out into the various DACs. Alex Attachments:
Post by Spirit on Oct 13, 2011 8:39:44 GMT
This coming Sunday, we hope to have a listen to 2, or perhaps even 3 SC DACs from Sydney RG members. There is also the possibility that we may be able to do a comparison against Allan Pagan's new Buffalo 3, which the last time I spoke with Allan, was sounding very nice indeed, but needed to be tidied up a bit yet, as it was still in bread board layout. These DACs will also be compared with david2vk's 24/192 capable W4S, and we will also be able to hear the Steve Nugent "OffRamp" in action, as well as direct playback from an Oppo 95 which has a Sabre DAC inside ,and also using it's USB input with a Corsair Voyager, and via Digital Out into the various DACs. Alex Looking forward to hearing of the results
Post by Deleted on Oct 20, 2011 23:44:57 GMT
UPDATED PSU WIRING. Attachments:
Post by Deleted on Oct 21, 2011 6:46:27 GMT
Alex,
With a transformer that has the same colour primary leads, is it safe to assume that using the same corresponding physical entry points of the leads (i.e. left & right) would suffice?
Chris
Post by Deleted on Oct 21, 2011 7:22:08 GMT
Alex, With a transformer that has the same colour primary leads, is it safe to assume that using the same corresponding physical entry points of the leads (i.e. left & right) would suffice? Chris Hi Chris I would imagine so. If you wanted to experiment you could try reversing one and see if you can notice any difference in "focus". I found the way that the secondary windings were connected to the PSU PCBs made quite a notieable difference. I replaced a toroidal with orange primary wires with one the same as the other.i.e. brown and blue wires . I was surprised by the improvement. Did you try replacing the 10K resistor in the JLH sections that feed +5V with a 3.3K to 4.7K, or a 1.5mA CCD ? Alex
Post by Deleted on Oct 21, 2011 9:05:08 GMT
Hi Alex,
to make life easy I think I'll replace the existing transformer as well. The original will always be handy elsewhere!
Aha, CCDs, I'd forgotton. I'll pop some on my next order.
Cheers,
Chris
Post by jeffc on Oct 21, 2011 22:44:33 GMT
Post by leo on Oct 22, 2011 19:21:21 GMT
Should be ok I'd have thought Jeff, I've used 2SK174 and J309's before with a resistor across gate and source to set the required current.
Post by Deleted on Oct 23, 2011 19:36:27 GMT
Jeff In the absence of more suitable FETs, or the proper CCDs ,it may be easier, and probably just as effective to replace the 10K with a 3.3K to 4.7K resistor where the JLH is used at 5V. Alex
Post by Deleted on Oct 23, 2011 20:23:21 GMT
The J506 CCDs seem pretty tough to find, there is the ebay seller that I think Shaun found and there is also this mob; www.utsource.net/j506.htmlThey supply small quantity, I've just ordered 10 x J506 (@ $1.50 ea) and we'll see how good their supply is.
Post by Deleted on Nov 3, 2011 13:19:15 GMT
The J506 CCDs seem pretty tough to find, there is the ebay seller that I think Shaun found and there is also this mob; www.utsource.net/j506.htmlThey supply small quantity, I've just ordered 10 x J506 (@ $1.50 ea) and we'll see how good their supply is. They just rolled in! Look good to me. Attachments:
Post by Deleted on Nov 8, 2011 0:02:27 GMT
Alex,
I just popped a couple of J506 on the two 5vdc boards.
I could swear your correct! There seems to be a tad more clarity, granted I can't A-B but...
Plus, two new 15vac transformers have arrived today but I need to mount the whole kaboodle back into the old test chassis to wire them in, the box I had squeazed it all into won't accommadate a fag paper more, let alone another tranny!
Post by jeffc on Nov 8, 2011 1:12:03 GMT
Good to here Chris as I also have some on their way. Price is creaping up though, $2 ea now for a lot of 10. cheers.. jeffc
Post by Deleted on Nov 9, 2011 8:07:49 GMT
More progress; the psu has had a second tranny (new pair) added as per Alexs configuration a few posts above. Not so much another small step forward as a leap! Mostly a sense of width, openess and sheer power when needed.Multi layered, busy pieces are filed out with great authority. Only one down point is that it also makes my mains borne buzz more obvious during quiet parts and silences, oh well, warts and all! I think that only leaves the xtal mod to do, out of the current tried and tested list? Plus a new box Which brings me to the question; What is the easiest/best way to implement the xtal change from the point I'm at now? In the meantime
Post by Deleted on Nov 9, 2011 8:57:28 GMT
Hi Chris It really does give the big names a run for the money now, doesn't it ? It goes to show that it's not whether it's USB or SPDIF, but the way it is implemented , and the quality of the power supplies, as well as the isolation between Analogue and Digital areas as far as PSU is concerned. I am not completely convinced about the external Xtal oscillator, as in theory it shouldn't matter.I did that after Alfred recommended it. Perhaps others who have done this too could offer comments here ? Personally, I would be doing the 3.3V Paul Hynes regulator mod to the Input PCB first, although a Leo bodge to a JLH using a 5V to 3.3V regulator in the front may also do the trick without the PH regulator. Syd can give you info about the regulator type, as Syd very kindly sent me a couple to play with. Regards Alex
Post by Deleted on Nov 9, 2011 9:04:43 GMT
Chris Perhaps you could provide some more info about that problem , as some of the smarter people here like Frans, may be able to suggest a fix for you.You should be able to get rid of that completely with a bit of work. Alex
Post by Deleted on Nov 9, 2011 18:46:55 GMT
Sorry Alex, a bunch of questions follow Hi Chris It really does give the big names a run for the money now, doesn't it ?
Yep, it's pulled away from my Meridians on board DAC very convincingly now!
I think most were unsure, as you are and it was only myself remaining to add the Xtal at such a late stage to see if there was any difference or not?
I assume that's the shunt version?
Is that any better than my current JLH->cricket set up? ref. Q I know exactly what causes it Alex. It is the SMPSs on most especially my laptop if used on the same radial circuit (no ring circuits here), amoungst other units. If they are off/running on battery or on another circuit there is no problem. I was just pointing out how much more "stuff" was audible/more audible Cheers, Chris
Post by Deleted on Nov 9, 2011 21:17:03 GMT
Hi Chris A good mains filter in line with the audio gear MAY help here, but I can't guarantee it. Alex
Post by Deleted on Nov 9, 2011 21:24:55 GMT
Hi Chris It is a small shunt type on a small ,but fairly tall PCB with 3 leads. The leads are as for a LM317, so a couple need to crossover to fit the original 3.3V reg place on the PCB. You can see it bent over a little in my most recent photo.The other idea may not be feasible due to the different pinout of the LM317 as used by Leo in his bodge, and the pinout of the 3.3V reg which is the same as a 78XX. Added to that you would need another single JLH and find space to fit it. I shouldn't have mentioned that without fully thinking it through. The PH reg gives a further small improvement, but whether it is worth the additional cost over the dual Crickets is debatable.I am still using half of the original dual Cricket to supply the DAC PCB via the cable from the Input PCB. Alex Attachments:
Post by Deleted on Nov 9, 2011 23:24:35 GMT
Alex, Thanks for the info. The PH regs look pretty crude for £30! Now that we're all SMD pros ;D maybe we should do some aka RG regs
Post by Deleted on Nov 9, 2011 23:41:31 GMT
Chris The main reason for the success of the PH regs is the speed of some of their opamps. I understand that they may be 1GHZ types. P.H. obliterates the type numbers.We are paying for his knowledge and personal assembly and testing time.You will have noticed that it is a 150mA shunt type. IIRC, it should have no more than around +6V at the input, so +5V from a JLH supply is ideal. Alex
Post by Deleted on Nov 11, 2011 18:32:11 GMT
I pulled my part-completed project out of storage yesterday. Its had, I think, all of the cap mods carried out but I refrained from putting the 40910 metal cans in just yet. I had a few Jaycar PSU kits so built one up and used that for a trial run. As expected I have a few blips. I think i must have initially put the third channel selector button upsidedown, it selects the SPDIF channel OK but no light. The other two light up fine. I'm getting yellow and green lights as I should. However, , I'm getting low sound in the left channel and none in the right. (I have since discovered there's a minute sound from the right if I listen to just it). If I advance the volume control slowly volume increases OK until there's a click in the right channel and all sound stops. Sounds like a relay clicking. Lower the volume and the left channel returns. It never gets near a listenable level. I'm working my way through everything so early days. I've checked the continuity of the ribbon cables and all is well. One strange thing, when I was examining the board with a loupe I noticed an SMD had a tiny piece of solder across two legs. I really don't think I did it but removng it changed nothing. I'm just wondering if this peculiar sympton might point to one particular area? I didn't mount the Toslink devices but I assume that wouldn't affect anything. Undaunted I'll carry on...... Syd
Post by Deleted on Nov 11, 2011 20:20:57 GMT
I pulled my part-completed project out of storage yesterday. Its had, I think, all of the cap mods carried out but I refrained from putting the 40910 metal cans in just yet. I had a few Jaycar PSU kits so built one up and used that for a trial run. As expected I have a few blips. I think i must have initially put the third channel selector button upsidedown, it selects the SPDIF channel OK but no light. The other two light up fine. I'm getting yellow and green lights as I should. However, , I'm getting low sound in the left channel and none in the right. (I have since discovered there's a minute sound from the right if I listen to just it). If I advance the volume control slowly volume increases OK until there's a click in the right channel and all sound stops. Sounds like a relay clicking. Lower the volume and the left channel returns. It never gets near a listenable level. I'm working my way through everything so early days. I've checked the continuity of the ribbon cables and all is well. One strange thing, when I was examining the board with a loupe I noticed an SMD had a tiny piece of solder across two legs. I really don't think I did it but removng it changed nothing. I'm just wondering if this peculiar sympton might point to one particular area? I didn't mount the Toslink devices but I assume that wouldn't affect anything. Undaunted I'll carry on...... Syd Hi Syd Getting the yellow and green LEDs is a good sign as it indicates the DSD1796 has locked to a signal.I had a problem initially with the blue LEDs due to the very fine wires, and solder not flowing around them properly due to the gap between the wire and the outside of the hole.Have you checked the voltages around the output I.C at the output of the DAC PCB ? Alex
Post by Deleted on Nov 11, 2011 22:05:09 GMT
Syd Something else to check. With at least some of the earlier Jaycar DAC boards, there is a missing short track between pin 3 of IC12 and the 180R resistor. Regards Alex
